Ok so I wont be totally be taking out the Amp? I'll still be using it as a power source but the signal wires (pos., neg.) will be cut and then I'll run new wires just for the signal wires? Becuase the colors you gave me are for +/- not for power/ground. Here is a pic from that link above.
What else then? Just so you know I'm only going to be doing the fronts for now. The rears will get dont alittle later.
http://www.zilvia.net/f/showthread.php?t=10025 In this thread the guy talks about neg. inputs and outputs, pos. inputs and outputs. I also dont get what he means when he says splices: 1 to 3. Which are (1) Left Front neg. input and (3) Left Front neg. output. Splice means connect right? So why would you connect a neg. input and neg. output? Plus on top of that I didn't know ever know you had a pos. input/output and neg. input/output. I thought that + was pos. and - was neg. Thats all. Help me out lol.
