Old 04-06-2006, 04:37 PM   #31
Dousan_PG
Dousan_PG's Avatar
weight savings? w/ cast wheels i wouldnt worry about it
get some forged wheels if u really care about weight savings.
yeah it hurts the budget but all cast wheels will mostly be w/in a bit of eachother and then w/ the tire u want...some tires are heavier then others
if u care about weight you wouldnt be rocking cast wheels.
Aaron
Pink GodziRa
Old 04-06-2006, 06:16 PM   #32
gumbygrys15
gumbygrys15 is an unknown quantity at this point
well the wheels Im planning on getting are the ssr type c or type c-rs, which only weigh about 14lbs for the 17x8 and the 17x9 are about 15lbs. But after reading all of your responces i think i will go with the 17x9 but now which offset should i go with. Now before you guys go crazy about really low offsets, that doesnt matter to me I just want them to fit and not stick out to much. Im running 20mm larger front fenders, and only if i have to i will roll the rears, jic FLTA2 coilovers and stop tech big brake kit w/ z32 in the rear. Thank you guys again for your help.
gumbygrys15 is offline   Reply With Quote
Old 04-06-2006, 06:17 PM   #33
gumbygrys15
sorry for got the offsets hear they are 21, 28, 35, 40
Old 04-06-2006, 06:56 PM   #34
Dousan_PG
Dousan_PG's Avatar
wide fenders?
depends on camber
but definitely +21 and a 10-25mm spacer depend on the camber and tire size and what u want.
Aaron
Pink GodziRa
Old 04-06-2006, 07:13 PM   #35
nokeone
on strike three.
nokeone's Avatar
nokeone is making a name for him/her selfnokeone is making a name for him/her self
Send a message via AIM to nokeone Send a message via MSN to nokeone Send a message via Yahoo to nokeone
yeah you will most definately need spacers if you are running wide fenders...
i think it's gonna look weird though if you have wide front fenders with decently flushed wheels and then stock rear fenders...it's gonna look off...
maybe go back to stock front fenders?
panda; rockin your socks from the Bay to LA to SD, yay!
Pink GodziRa
nokeone is offline   Reply With Quote
Old 04-06-2006, 07:34 PM   #36
!Zar!
!Zar!'s Avatar
Originally Posted by i8yourfwd
How heavy are those mustang wheels? And what's 4x114.3 converted to "standard" sizing?
It's 4x4.50 for 4x114.3
It's 5x4.50 for 5x114.3
Old 04-06-2006, 08:52 PM   #37
gumbygrys15
245 size width tires is what plan on. Sorry the fenders are not 20mm wider my mistake.
Old 04-06-2006, 08:53 PM   #38
Dousan_PG
Dousan_PG's Avatar
+21 is still fine. just roll the fenders. you'll be cool
any higher and u wont clear coilovers up front.
Aaron
Pink GodziRa
Old 04-06-2006, 09:03 PM   #39
Ricks15
Ricks15's Avatar
Ricks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud ofRicks15 has much to be proud of
Instead of rolling the fenders someone told me a trick so you dont rub you're tires, if you cut the inner rim thats inside of the rear fenders with either some metal shears or a electrical grinder, you slice pieces of metal to half of a inch and then with a rubber malet you hit those pices of metal intill there somewhat flush. I have done this on my S13 I dont know if any S14's have that piece of metal which I stated that the S13 has in the fenders. But its a cheap man's way to avoid paying 50 bucks for each rolled fender. trust me Zero offset wheels and blown shocks= sick tire rubbing.
Ricks15 is offline   Reply With Quote
Old 04-06-2006, 09:09 PM   #40
Dousan_PG
Dousan_PG's Avatar
its free when u use a hammer and muscle
only dummies use the fender roller or pay someone
takes 10 mins
and it DOESNT crack the paint (on the outside)
has the same effect as fender roller
pay 20 bucks and get a propane torch and it folds faster and easier.
Aaron
Pink GodziRa
Old 04-06-2006, 09:16 PM   #41
Ricks15
Ricks15's Avatar
How about with a bat? I saw that crap on stupid street. With a hammer it can be done but you got to be real carefull because the nissan fenders are tough as fuck so you need good hand and eye cordination
Old 04-06-2006, 09:22 PM   #42
kay_arsen
kay_arsen's Avatar
kay_arsen is on the path to ruinkay_arsen is on the path to ruin
Send a message via MSN to kay_arsen
takes 10 mins
has anyone here actually used a hammer?
pics? i might just try it, does it look ghetto
kay_arsen is offline   Reply With Quote
Old 04-06-2006, 10:21 PM   #43
TheTimanator
TheTimanator's Avatar
have you seen the pics of Dousan's rear fenders?
Old 04-06-2006, 10:22 PM   #44
Dousan_PG
Dousan_PG's Avatar
i wouldnt use a bat
nissan fenders are tough as shit maybe you need to hit the gym.
i used hammer on some peoples cars. you cant even tell form outside i did. its faster and just as good as a rip off fender roller. which i own as wel but never use anymore.
bats are better for pulling, not rolling.
Aaron
Pink GodziRa
Old 04-06-2006, 10:43 PM   #45
s13coupedude
s13coupedude's Avatar
s13coupedude is an unknown quantity at this point
Does the 240 community frown on using Cobra's? Cause here in Wisconsin Cobra's are everywhere. I actually found 2 sets of 4 lug cobra's at work today just asking around. And I actually like the simple design of Cobra's.
s13coupedude is offline   Reply With Quote
Old 04-06-2006, 10:44 PM   #46
nokeone
on strike three.
nokeone's Avatar
have you read the thread?...lol..
everyone i know has used a hammer initially...lol..and then if you want it actually pulled you use a roller...
keep in mind...the only thing this guy needs to do is get rid of the annoying little lip on the inside of the fender...he's not trying to pull his fenders or anything...
one example:
Pink GodziRa
Old 04-06-2006, 10:47 PM   #47
Dousan_PG
Dousan_PG's Avatar
man that bumpers seen better days...oh that was when i had it hahahahaha
old times.
Aaron
Pink GodziRa
Old 04-06-2006, 10:52 PM   #48
nokeone
on strike three.
nokeone's Avatar
old times.
hahha so awesome...best hand-me-down aero ever!!
Pink GodziRa
Old 04-06-2006, 10:55 PM   #49
s13coupedude
Hmm can't seem to find any on ebay with 4.50 only 4.25.
Old 04-06-2006, 11:07 PM   #50
240shorty
240shorty's Avatar
240shorty is on a distinguished road
Yah, just to clarify. Mustang wheels are 4x4.25 bolt pattern. They don't work without spacers. Or you can go 5 lug and use 5 lug Cobras.
240= 4x4.5
Mustang= 4x4.25
Result= No worky
In case anyone was confused.
240shorty is offline   Reply With Quote
Old 04-06-2006, 11:10 PM   #51
s13coupedude
What size spacers would be needed? And about what price would I be looking at for the spacers? Lol added up I could probably just buy some better rims.
Old 04-06-2006, 11:10 PM   #52
Dousan_PG
Dousan_PG's Avatar
thats my s14 which gets wide fenders
if i cared i wouldnt have hammered on it w/ a metal 10lb mallet for 1/2 hour.
u wont even see it.
for rolls a hammer is the best bet
Aaron
Pink GodziRa
Old 04-07-2006, 03:24 PM   #53
mjjstang
mjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to beholdmjjstang is a splendid one to behold
Send a message via AIM to mjjstang
Pllease dude, what kind of question is that. why would you care what someone else thinks, if you like it do it. you could go put an aluminum wing on your car and stickers all over your windshield and I still wouldnt care, as well as many people here, the ones who do care are just whiny bitches who have nothing else to do but whine. If you like em then put them on your car. Great minds don't think alike, they think for themselves.
mjjstang is offline   Reply With Quote
Old 04-07-2006, 06:53 PM   #54
TheTimanator
u wont even see it.
yeah i knew that...I was just joking around.
Actually, I think you've convinced me to go grab a hammer and just start hammering my fenders. I assume this will work with the front and rear fenders. I've got a heat shrink gun which should help some.
As far as spacers go...you'll need the +21 offset to clear coilovers and since you said you "just wanted them to fit, and not stick out" I say forget the spacer for now. Put them on your car and if there not flush enough for you with your camber settings and ride height then figure out what size spacer you need and buy it!
Old 04-08-2006, 07:57 AM   #55
ROGER
ROGER's Avatar
ROGER is making a name for him/her selfROGER is making a name for him/her self
Send a message via AIM to ROGER Send a message via Yahoo to ROGER
s14
240= 4x4.5
Mustang= 4x4.25
Result= No worky
for anyone that likes the cobra wheel's and needs 4 lug, eagle alloys makes a cobra replica wheel i have been considering. it's called the eagle 168. it's offered in 17x9 +23 in chrome, silver, or polished, so says this website here:http://www.bigwheels.net/?location=w...el=Eagle%20168
that will worky hope that helps someone out......
ROGER is offline   Reply With Quote
Old 04-10-2006, 01:02 AM   #56
s13coupedude
Cool thanks for that link ROGER. I can't decide between those or 15" black mesh.
Old 04-10-2006, 04:29 PM   #57
ROGER
ROGER's Avatar
no problem. if u go to the sportmax section, they have those 15x8 +0 sportmax 002's as well. if u need an idea of how those would look, here u go......
http://www.imagestation.com/album/pi...?id=2107990482
found that on carolinanissans forum. guy has coilovers and 205-60's. i personally like the meshie's over all choices, but the cobra's would look good too i think.
