![]() Join Date: Jan 2004
Trader Rating: (115)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 115 reviews
that is the stupidest thing I've heard in a while. To decide what PSI you need isnt just a number that anyone can give you. It depends on what tires you are using and how the tires react with certin PSI levels. An easy way to see how much sidewall deflection and roll over you are getting is to get some white shoe polish and put it on parts of your tires sidewalls. Drive hard and see where the polish wares off. If it wares off to much on the sidewall you need more pressure. If it doesnt ware on the side wall at all take the pressure down a bit. You want it somewhat to use the sholder of the tire, but not the whore sidewall. This is assuming that you are running street tires, but judging by the question I dont think I have a problem assuming that. For auto x its a bit different. You want to focus more on lateral transition rather than lateral grip because the corners are so small and close together. You should run slightly higher PSI than you would for a HPDE or something like that.
![]() Join Date: Jan 2006
![]() ![]() Feedback Score: 3 reviews
if you wanna talk shit get a decent car first... i dont do autocross... sorry for not knowing something, like you since you dont know that your car is fuckin gay as all types of shit.... fuck off
![]() Join Date: Apr 2003
wow homeboy chill the fuck out. a million factors determine tire pressure.
What kind of car are you running, HP, susp, tires used, ect
#5 | |
![]() Join Date: May 2005
#9 | |
![]() Join Date: Oct 2003
I run like 80psi in my truck tires, it works really good for me.
BTW thread starter, Chill out, its the internet.
yo first of all i have an s13 too... second that wasnt me that sent that reply... so mybad for that... i just wanted an average of what people run so i could get close to what i needed...
Multiple personalities WTF!?
What tires do you have? A good starting point is to look at the max psi on the side wall then put the pressure to about 10psi less. After that, you will need to be using the shoe polish/chalk on the sidewall trick. Or a laser thermometer if you want to go high tech. Every tire brand/type will be different. |
hey im really sorry about that post... it was one of my friends who has the most riced out car on earth(car is made of bondo)... i do have an s13 and i love them all even if they arent the best looking... i know it was a stupid question to ask but i didnt know... thanks for the info tho... that really wasnt me tho. your advice helped me out i ran 9 sec behind a guy with a vette with over 850hp... thanks sorry for my friend
#14 |
![]() Join Date: Apr 2004
The general rule of thumb is adding 5 PSI to the factory recommended cold pressure (measured with tyres at ambient temperature) for general performance. For track use you can experiment with +10 and up to the tyre's max pressure.
Just make sure you don't exceed the tyre's max pressure printed on the sidewall. |
#15 |
![]() Join Date: May 2004
Trader Rating: (26)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 26 reviews
check your tire pressure after each run. as the tires heat up the air also heats up and expands causing higher pressure. be sure to let some pressure out if it exceeds the maximum for that tire. play around with your tire pressure after each run and see what you feel is best.
