Old 05-28-2002, 07:48 AM   #1
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
First - let me begin by thanking bbp for planting the seed of adventure in me! &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
Okay, background: &nbsp;a) I'm tall; b) I drive an s14; c) I like to wear a helmet in the car as much as possible. &nbsp;If you are like me, then you know that "a" + "b" does not equal "c" b/c there's just no headroom! &nbsp;It is bad enough w/o a helment and not sitting in attack position. &nbsp;After seeing bbp posting about his racecar's lower s13 passanger seat, I decided to do an experiment this weekend.
Results - I got about .5" or so of headroom by removing padding (my hair used to graze the roof, now it has about .5-.75" of space). &nbsp;Not a lot, but every little bit helps! &nbsp;Besides the extra head room, it also provided a little deeper of a hole to sink my a$$ into, so I feel the seat is holding me better. &nbsp;So far, I haven't found it uncomfortable for lack of foam (although the newfound pressre on the sides of my cheeks is hard to get used too <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> ).
Process - Not hard at all. &nbsp;
1. &nbsp;Remove the seat (four bolts - 1.5 minutes&#33<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''> and don't forget the little seatbelt light wire/clip. &nbsp;Be prepared for the track/ slider to scare the hell out of you when it releases (it will - and it will do it when you least expect it (not as soon as it unbolts)). &nbsp;And while you are at it, clean that hard to reach area and retrieve all loose change <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
2. &nbsp;Take the seat bottom off. &nbsp;Remove the plastic trim on the sides (two screws per section + remove seatback release lever plastic). &nbsp;Unbolt the bottom from the chassis (two screws on the door side, three screws + the big seatbelt buckle bolt on the tunnel side). &nbsp;Fidget with the clips that hold on the wires again (3 total) and Presto! &nbsp;
3. &nbsp;Open seat/ remove foam. &nbsp;The basics of this process it to take the cover off the seat so you can reach in and take out some foam. &nbsp;I found that this is a bit more complex than I would have liked b/c I kept opening up the wrong section (there are multiple bolsters - thigh, each hip, center, back). &nbsp;Still, it only took me about 30 minutes. &nbsp;What I should have done was remove the hog rings on the rear half of the seat (including the flap at the back). &nbsp;Remove the hog rings that separate the center foam from the rear bolster (found under that flap on the bottom). &nbsp;Pull that section up and out of the way. &nbsp;Reach in and start grabbing handfulls of foam. &nbsp;I was lazy and didn't take it all the way apart and don't have a uniform foam surface now, but I can't feel the difference when I sit on it - so being anal will get you few rewards. &nbsp;Uncompressed, there is about 2.5" of foam in there. &nbsp;I removed about 1.5" worth. &nbsp;When you are done pulling, close it up. &nbsp;I used zip ties (a la bbp's suggestion) and reused some of the hog rings (squeezed together w/ pliars). &nbsp;
4. &nbsp;Reassemble.
Easy, free, and more rewarding than I imagined.
HippoSleek is offline   Reply With Quote
Old 05-28-2002, 02:39 PM   #2
bbp
bbp's Avatar
bbp is an unknown quantity at this point
I am glad to hear it worked out for ya! &nbsp;I fit a 6'2" guy with a helmet on in my passenger seat this weekend. &nbsp;I'm not so sure he would have fit with all the padding.
I'm happy it worked out for ya!
bbp is offline   Reply With Quote
