![]() Join Date: Jun 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 5 reviews
electric fan
was wondering if any of you guys tried using these fans in comparison to the F-A-L
http://infinite-auto.com/index.html |
youd probably be in good shape with that, I run 2 permacool 14" like that, but different, with a stock SR/stock rad, summitracing for 99.95 iirc, I think mine move more air than that though (me>2x1750cfm). just get 2, wire one to come on automatically and run a switch for the other one in case of traffic/track/overheat.
i wonder if 2 14's of these fans would fit on the sr koyo rad. i was thinking 2 12's like the FAL. How much are the altima fans and the permacools? should i get junkyard altima fans or new ones?
If I'm not mistaken the cfm rating on fans is done w/no resistance(ie no radiator in front of it). I have gone the universal fan route and it seems to be a waste of money. For what you pay for 1 universal you could get the dual altima fans setup and they have been tested/shown to be as effective as the FAL fans and other higher end fans. Now if your dealing w/a space issue(ie you have an rb installed in your 240) then you wouldn't be able to use the altima fans but for the money they are the best option out there...read this comparison on fans/radiator setups, its old but has a ton of useful info
http://home.satx.rr.com/nissanweb/RadTest/RadTest.htm |
after reading that link, I guess id reccommend the altima fans...
those guys did a serious test... I wish I read that before fan shopping:hammer: regardless, my fans keep me at around 185 in stopppppped traffic on the grand central, on 90degree days. Doesnt really get much warmer than that here. (water sprayers installed for high boost running, also very effective/cheap) |
#12 | |
Where have you guys ordered the altima fans? also did you hook it up to a switch, or have it running all the time, or find a way to hook it up to the thermostat?
#14 | |
Edit Here you go...I found it http://www.zilvia.net/f/showthread.p...ar+altima+fans |
