Old 04-26-2014, 12:32 AM   #3091
Vicious Beaner!
Vicious Beaner!'s Avatar
Trader Rating: (38)
Vicious Beaner! is an unknown quantity at this point
Feedback Score: 38 reviews
Will an 18x9.5+12 on a 225/40 clear ? My main concern is rubbing the harness on full lock. Im sure a 215 will clear but IMO its too much of a stretch for me . maybe even 225/35?
Vicious Beaner! is offline   Reply With Quote
Old 04-26-2014, 08:22 AM   #3092
PostScript
PostScript is an unknown quantity at this point
I'm running a 235/40/17 on a 9.5w/+12. It's tight on the coilover but works. Move the harness?
PostScript is offline   Reply With Quote
Old 04-27-2014, 09:21 AM   #3093
GL Chrillz
GL Chrillz's Avatar
GL Chrillz is an unknown quantity at this point
not sure if this 100% fits this thread, but semi related. i have PBM adjustable spacers on the front. using the 20mm bolt on, and then 7mm slip on (the 5mm and 2mm) with xxr wheels. since the spacer is hubcentric, thats all good. but the wheel is also hubcentric, but the other side of the spacer is not. as i'm sure you guys can guess, bad things happen at speed. is there some fix for this? machine a ring that would center on the spacers?
GL Chrillz is offline   Reply With Quote
Old 04-27-2014, 02:17 PM   #3094
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Honestly, I've never used hub centric spacers and have never had any vibration issues. I always just make sure my slip ones are centered by feeling it around the hub. I'm on extended studs and running 2 10mm stacked slip ons.
CLICK HERE!!!
Old 04-29-2014, 06:34 AM   #3095
S14_kouki504
S14_kouki504's Avatar
S14_kouki504 is an unknown quantity at this point
Send a message via MSN to S14_kouki504
what would you guys suggest for tires and spacers for a 17x7.5 konig backbone wheel? im not sure what the offset is on the wheel. i want a tire with a little bit of meat on it but not too tall. also dont want to be "hellaflush" just want to fill the wheel well up a bit better and have clearance from my coilovers.
S14_kouki504 is offline   Reply With Quote
Old 04-29-2014, 07:13 AM   #3096
simmode1
simmode1's Avatar
simmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfectionsimmode1 is close to perfection
Send a message via Yahoo to simmode1
Holy Honda wheels, Batman! Gonna need huge spacers on those. Googling for about 5 seconds revealed that those come in either +35 or plus +45 offset, as typical of FWD wheels. A 25mm hubcentric spacer should help, but I'd highly recommend a wheel that actually fits, like a 17x9+20 with 245/40 rubber.
simmode1 is offline   Reply With Quote
Old 04-29-2014, 08:06 AM   #3097
S14_kouki504
i havent found a set of wheels that i like that come in 17x9 as of yet. all of the ones i have found are 17x7-17x8
Old 04-29-2014, 08:22 PM   #3098
K crazy
K crazy is an unknown quantity at this point
I have 15mm and 38mm spacers with built in adapters. Ichiba V2's for sale. If anyone of you guys are interested to fix your fitment issues.
K crazy is offline   Reply With Quote
Old 04-30-2014, 06:09 AM   #3099
fliprayzin240sx
You have these...but can't find similarly styled wheels that has better fitment?
You're kidding me right?
CLICK HERE!!!
Old 04-30-2014, 06:51 AM   #3100
S14_kouki504
never said i had them nor did i say i was looking for a similarly styled wheel.
Old 04-30-2014, 07:21 AM   #3101
fliprayzin240sx
You Sir, don't make any gaaawdamn sense. So why would you ask about tires and spacers for them if you dont have them already or plan on getting them? If you havent found anything you like, why waste money on shitty ass rims?
CLICK HERE!!!
Old 05-01-2014, 12:56 PM   #3102
STR3TCH
STR3TCH's Avatar
STR3TCH is an unknown quantity at this point
Just picked up 18x9 +25 for the front and 18x10.5 +25 for rear. Is anyone running the same or similar set up? What tires are you going with? Thanks!
Sent from my SCH-I535 using Tapatalk
STR3TCH is offline   Reply With Quote
Old 05-01-2014, 01:17 PM   #3103
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
^^^215/40 f and 235/40 r
Old 05-02-2014, 03:39 AM   #3104
fliprayzin240sx
Sounds good but you can run wider if you want a meatier look since you'd have more space.
CLICK HERE!!!
Old 05-02-2014, 04:27 AM   #3105
STR3TCH
STR3TCH's Avatar
You think just a good roll and maybe a slight pull in the rear?
Old 05-02-2014, 12:30 PM   #3106
fliprayzin240sx
With the stretched 235, you probably wont even need to pull.
CLICK HERE!!!
Old 05-02-2014, 01:56 PM   #3107
frsh4
frsh4's Avatar
frsh4 is an unknown quantity at this point
Wow my thread got to put in the sticky section!!!
thanks you guys, keep to good info coming. I hope to be back here soon with my BRZ when its ready!
If anybody on here has info on the brz/frs it'd be cool if i can get some help fitting my old rezaxll. They're 18x9/10 +14 ima have to get adapters so they will become +4 all around. Ima got with same tire size as my s13 215/35 and 225/40 i think with a roll the fenders should be cool. any info would help im kinda confused with the fitments for this car.
http://thatistupid.tumblr.com/
frsh4 is offline   Reply With Quote
Old 05-02-2014, 02:18 PM   #3108
VNG704
VNG704's Avatar
VNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond reputeVNG704 has a reputation beyond repute
Aren't those frs 5x100? if the rezax are from your 240 you'll need conversion adapters not just spacers. Unless that was what you meant then...yea.
VNG704 is offline   Reply With Quote
Old 05-02-2014, 02:33 PM   #3109
fliprayzin240sx
Shitty part about BRZs...5x100, worst than 4x113.4.
CLICK HERE!!!
Old 05-02-2014, 04:02 PM   #3110
vJilly
vJilly's Avatar
vJilly is an unknown quantity at this point
18x9 +12 on stock s13 metal. i know a roll will be necessary but want a good flush fitment. what tire size? 225/40? wanna be pretty low.
vJilly is offline   Reply With Quote
Old 05-02-2014, 04:29 PM   #3111
corkscrew
corkscrew's Avatar
corkscrew is an unknown quantity at this point
or a 215/40. thats what i have on my 17x9.5s and im almost tucking in the rear
corkscrew is offline   Reply With Quote
Old 05-02-2014, 06:00 PM   #3112
TheRealSy90
TheRealSy90's Avatar
Trying to figure out what tires to run on my new wheels. Ordered 50mm rear overs. 17x10+0 17x11 +6 Would like a stretched tire, but with overs on the rear I don't really need to stretch it I guess. Planning on tucking a little rim out back.
Such a good signature.
Old 05-02-2014, 10:08 PM   #3113
simmode1
simmode1's Avatar
17x9 & greater wheels damn near grow on trees, dude. If you need suggestions, this is the place to ask.
Old 05-02-2014, 10:40 PM   #3114
frsh4
frsh4's Avatar
Ya my adapters are gonna me it +4 all around on a brz.
Old 05-02-2014, 11:19 PM   #3115
dnice78
dnice78's Avatar
dnice78 is an unknown quantity at this point
Hey guys, just picked up a set of Fabulous Profounds. They are 18x9.5+18 and 18x11 +24 I'm running Origin 40mm up front and unknown overs in the rear (assuming 30mm?) Both wheels need to be spaced out a bit.... What do you recommend? (for a spacer setup and tires)
How it sits with current eurolines @ 17x8/9 +38
dnice78 is offline   Reply With Quote
Old 05-15-2014, 06:48 PM   #3116
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
going to get tires in my rear of s13 with roll and pull. Wheel size is 17x10 +20.
Currently running 17x9 +12 with 215/45 and i like the bigger sidewall in the rear. Camber is -2.5 and id like it to stay at that.
Now should I run 225/45 or 235/40. Tires will be federal 595 as they are my drift spares.
joshchewuhh is offline   Reply With Quote
Old 05-15-2014, 06:57 PM   #3117
slideslidegnarslide
Trader Rating: (29)
slideslidegnarslide is an unknown quantity at this point
Feedback Score: 29 reviews
I have an s13 with a minor pull. Wheels are 17x9.5 +12 I originally wanted 215 40r17 but I'm thinking about michilen pilot super sports. They only come in 215 45r17 and I'm afraid it may be a little too much side wall. Opinions?
slideslidegnarslide is offline   Reply With Quote
Old 05-15-2014, 07:18 PM   #3118
fliprayzin240sx
PSS runs slightly larger/taller than other tires I've ran of the same size. I never scrubbed on Dunlop Star Specs, switched to PSS and hello rub-city. Had to bust out the hammer to beat in spots in the wheel well.
CLICK HERE!!!
Old 05-15-2014, 07:53 PM   #3119
slideslidegnarslide
Trader Rating: (29)
Which tire did you like better? I have a buddy swearing by the pilot super sports.
Old 05-17-2014, 02:12 PM   #3120
akatom47
akatom47 is an unknown quantity at this point
Hey I'm super new to fitment and suspension, but I'm getting some weds kranze lxz's and i have coils, no pull or rolls on front or back fenders so i was wondering what i would need minimum to slam on these wheels pretty good,
the specs are 18x11 +11 and 18x10 +14
with tires 215/40 and 255/35
so im guessing 15mm spacers up front and what else? how much fender pull or roll if i need it etc on a stock body?
akatom47 is offline   Reply With Quote
