Old 05-18-2014, 08:57 PM   #3121
defcon86nwh
defcon86nwh's Avatar
defcon86nwh is an unknown quantity at this point
Love this thread.
Sent from my SCH-I545 using Tapatalk
defcon86nwh is offline   Reply With Quote
Old 05-19-2014, 10:29 AM   #3122
ka-titties
ka-titties is an unknown quantity at this point
Originally Posted by ykemma View Post
Impeccable fitment and you didn't have to get crazy with the camber: )
Sent from my LG-LS980 using Tapatalk
probably rubs like a motherfucker.
ka-titties is offline   Reply With Quote
Old 05-19-2014, 11:13 AM   #3123
Sumslapper
Sumslapper's Avatar
Sumslapper is an unknown quantity at this point
Thanks it took a little work to get it to fit right. I was just having problems with it hitting the coilover in the rear. I had to make a spacer where the coilover mounts and put in an extra long bolt.
Actually, it doesn't rub at all. The car is not super dumped. I like to drive my car through canyons and backroads so it has to be functional, especially on shitty roads.
Sumslapper is offline   Reply With Quote
Old 05-19-2014, 11:43 AM   #3124
Sumslapper
Sumslapper's Avatar
Old 05-19-2014, 04:45 PM   #3125
Broadfield
Broadfield's Avatar
Trader Rating: (163)
Broadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to allBroadfield is a name known to all
Feedback Score: 163 reviews
^^^^Perfect^^^^^
Follow Along For My Latest Work
My Portfolio
Please Share
Check Out My Builds
Broadfield is offline   Reply With Quote
Old 05-19-2014, 08:04 PM   #3126
Sforteen
Sforteen is an unknown quantity at this point
Ahhh i love wingless S14's
Sforteen is offline   Reply With Quote
Old 05-19-2014, 08:48 PM   #3127
Sumslapper
Sumslapper's Avatar
Originally Posted by Broadfield View Post
^^^^Perfect^^^^^
Thanks! You have one of the most well built coupes I've seen. Also really like gsracers car, that is some serious meat.
Old 05-20-2014, 05:05 AM   #3128
ka-titties
yeah your s14 gives me good feelings. well done, sir.
whats up with the stock exhaust?
Old 05-20-2014, 11:02 AM   #3129
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
^ because CA..
Car looks great, you seem to just keep increasing the tire width under the stock metal lol
spooled240 is offline   Reply With Quote
Old 05-26-2014, 01:17 PM   #3130
Sforteen
Weld RTS, 17x4 front
15x9.25 6.5BS rear
275 50 15's rear fenders rolled, no pull
Old 05-26-2014, 06:02 PM   #3131
ka-titties
looks bad ass. what's it trap?
Old 05-28-2014, 02:36 PM   #3132
Sforteen
Best trap was 128mph pump fuel 17psi
Car is full weight even AC
Old 05-30-2014, 09:12 AM   #3133
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
^^^^ any issue with the tire hitting the biody during launch/squat?
2muchboost is offline   Reply With Quote
Old 06-01-2014, 09:07 PM   #3134
Sforteen
No issues with tire rubbing
Old 06-02-2014, 11:27 PM   #3135
Om1kron
Om1kron's Avatar
Originally Posted by gsracer View Post
Throwback...
front
18x10 +18
275/35/18
You don't happen to have any pictures of the wheel wells do you?
I upgraded from stupid stretch tires to 265/35/18 (Yokohama S-Drives) on an 18x10 wheel with a -3 offset. I have about 1.5 degrees of negative camber up front last I checked. I have yet to get the car corner balanced. Obviously having problems with full lock now, not that I race or anything. But navigating into driveways and parking have become a see saw affair.
I'm not rubbing the front tubs, just the inside where the seam line is, and it looks like it's tugging at the harness now, so going to have to relocate that.
Here are some pictures.
I know some negative camber will fix any of the rubbing issues I'm having such as the passenger side. But I'm also sure a corner balance would fix this as well since I've never gotten one. Always eyeballed it.
Clearly a sledge will help, but I'm wondering if I should do anything more than that?
This damage is only on the passenger side, so far it's cut pretty deep into the tire i'm afraid, so I've parked the car until I figure out what I'm going to do besides break out thor's hammer. Hopefully it didn't compromise the sidewall at all.
Wayne Edwards
https://om1kron.blogspot.com
Old 06-03-2014, 01:16 AM   #3136
lalo167
lalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the roughlalo167 is a jewel in the rough
I had a similar problem. There's a lip up there that cuts into the tires. Just hammer it till its out of the way or till its flat. There really isn't much more you can do without major fabrication.
lalo167 is offline   Reply With Quote
Old 06-05-2014, 07:12 AM   #3137
kabukie
Trader Rating: (22)
kabukie is on a distinguished road
Feedback Score: 22 reviews
Send a message via AIM to kabukie
"Extreme" Grip Mode
Rolled and Pulled OEM Metal Fenders
265/35/18
295/30/18
kabukie is offline   Reply With Quote
Old 06-05-2014, 12:14 PM   #3138
Ruff Ryder 6
Ruff Ryder 6 is an unknown quantity at this point
^^offset/width please. I need some tire like this on my track car.
Ruff Ryder 6 is offline   Reply With Quote
Old 06-05-2014, 01:33 PM   #3139
spooled240
spooled240's Avatar
Get that harness out of the way of that tire, it looks pretty close.
Right where my harness comes out of the back of fender it's resting on a strip of steel that I tack welded in the fender well to push it way up out of the way.
Old 06-05-2014, 10:15 PM   #3140
BigKriss
BigKriss's Avatar
BigKriss is making a name for him/her selfBigKriss is making a name for him/her self
Car is no poser, gets used properly.
BigKriss is offline   Reply With Quote
Old 06-06-2014, 07:37 AM   #3141
kabukie
Trader Rating: (22)
18x9 +24 all around, with 7mm spacer in the front
Another pic of some acquired "hardware"
Old 06-06-2014, 08:45 AM   #3142
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
You have any better pics of your 295 hoosier fitment?
Old 06-07-2014, 12:46 AM   #3143
Om1kron
Om1kron's Avatar
I've had a steel skid plate above this wheel for the longest, only when I turn full lock going up a driveway have I noticed some rubbing. Unfortunately I took all of the slack out of this harness, so I can't.
Will have to relocate it.
Wayne Edwards
Old 06-14-2014, 09:48 AM   #3144
ka240de
ka240de is an unknown quantity at this point
hello, as you can see I am new here, I just read through this whole thread haha. I don't understand offset in what I think is metric? not sure what those numbers mean but I understand backspace in inches. I need some help with rear wheel selection.
s13 hatch
origin 50mm rear overfenders
weld 4 lug draglites (to be purchased)
replacement shocks and tenabe 1.25" lowering springs.
lots of room for tire I would like a 27x10x15 = 255/60-r15 mickey Thompson in the rear what backspacing should I order?
thing is a 27" tire with my ride height is still 3/4" from the stock metal.
I know I could tuck a 28" tire with some work but I want to maintain a 10" tread
I will update with pictures today
ka240de is offline   Reply With Quote
Old 06-15-2014, 01:22 PM   #3145
HighwaystarJC
HighwaystarJC is an unknown quantity at this point
s13 hatch
you may want to try this thread-------> http://zilvia.net/f/showthread.php?t=392494
HIGHWAYSTAR/TeamSUN*WORKS
@HighwayStarJC_sunworks #HSGS14
HighwaystarJC is offline   Reply With Quote
Old 06-15-2014, 09:51 PM   #3146
Duker
Duker is an unknown quantity at this point
Originally Posted by Sumslapper View Post
What's the disk on the Meisters??
Duker is offline   Reply With Quote
Old 06-16-2014, 09:29 PM   #3147
180driftersx
180driftersx is an unknown quantity at this point
Wow. This thread should be only 20 pages max. Makes me want a s14. The amount of extreme staggered set ups is unreal. With that said so many awesome looking cars. Broadfields s13 is so clean. Your pulled rears is fn perfection. You know your shit! I wish you could fit 265 in front. I know you've wanted it. I would love to see a s13 with 275f 295r. Plz post some more pics of the two tone fender flared s13. Love it! I'm at 17x 8.5+30 245. 17x9.5+40 265 kdw's. Stock fenders and quarters rolled. No need for a photo not worthy. Just looking for a new road race setup.
180driftersx is offline   Reply With Quote
Old 06-24-2014, 12:12 PM   #3148
drifter92
drifter92's Avatar
drifter92 is an unknown quantity at this point
Why do so many people run "maximum rubber (GRIP)" and then run 2-4* camber... wtf is the point then
Instagram: chinowith
https://www.youtube.com/user/untouchable361/videos
drifter92 is offline   Reply With Quote
Old 06-24-2014, 12:20 PM   #3149
HighwaystarJC
you need to learn more about cornering. camber actually adds grip to your setup if done correctly. only when you have extreme amounts of camber or camber with stretch does it really have an adverse reaction to grip.
even with a stock setup you dont want 0* camber. with tire roll and such you need camber so when your car rolls it will actually have more contact.
Old 06-24-2014, 01:13 PM   #3150
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
Even the tire manufacturers recommend some negative camber.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
