Old 05-17-2014, 03:17 PM   #3121
Taylor Shinobu
Taylor Shinobu's Avatar
Taylor Shinobu is an unknown quantity at this point
Originally Posted by akatom47 View Post
Hey I'm super new to fitment and suspension, but I'm getting some weds kranze lxz's and i have coils, no pull or rolls on front or back fenders so i was wondering what i would need minimum to slam on these wheels pretty good,
the specs are 18x11 +11 and 18x10 +14
with tires 215/40 and 255/35
so im guessing 15mm spacers up front and what else? how much fender pull or roll if i need it etc on a stock body?
With those sizes on stock body and wanting to slam your car, each fender is going to need a roll and massive pull, there's a chance the rears might not even fit, and you might need more then a 15mm for the front but I'm not sure
Taylor Shinobu is offline   Reply With Quote
Old 05-17-2014, 05:56 PM   #3122
Vicious Beaner!
Vicious Beaner!'s Avatar
Trader Rating: (38)
Vicious Beaner! is an unknown quantity at this point
Feedback Score: 38 reviews
Just picked up some 17x9 +0. & 17x9.5. -1 work Meister's for my s13 . Need some opinions on tire sizes . I don't want a super hella flush/stretched tire or crazy camber . I will be ordering PBM rucas and toe arms . to try and pull out most of the camber . will I need a big pull? I'm afraid of my quarter panel buckling in . unless you guys also know someone that does clean fender rolling work in Socal ! Want like a some what meaty stance that still handles well . I would appreciate the help fellas !
Vicious Beaner! is offline   Reply With Quote
Old 05-17-2014, 06:31 PM   #3123
wussmonster
wussmonster is an unknown quantity at this point
Just get a buddy to help you pull your fenders with a baseball bat. As long as you go slow and use a heat gun it'll be fine. I just did mine for 17x9.5 +15. Hammer the lip flat in the wheel well first.
For tires I run 235/40/17 rt615k
Sent from my XT603 using Tapatalk 2
wussmonster is offline   Reply With Quote
Old 05-17-2014, 07:03 PM   #3124
Mishkin_707
Mishkin_707's Avatar
Mishkin_707 is an unknown quantity at this point
Ok, so I got a set of euroline DH's fronts are 18x7.5 +30 and the rears are 18x8.5 +35, yes I know not super hella fresh n flush blah blah blah, I always liked eurolines and I got an awesome deal on them, I have an S13 coupe, stock body, no rolls pulls or over fenders, I'm not too low nor do I care for slamming and cambering all crazy, what tire sizes would you guys recommend for them? Not really going too low so I don't think I need the stretched sizes, also, I'm sure they'll be sunken in a bit, I want to run spacers too, right now I have some 16x8 +25 and I do like how they sit, not sunk but not flush, I'd like to stay in that range, I figured i would run a 5mm spacer up front and maybe a 10mm in rear? What would you guys suggest? Just to get out the way, no I will not sell these and get bigger sizing. I don't care if you don't like the wheels.
Mishkin_707 is offline   Reply With Quote
Old 05-18-2014, 10:45 PM   #3125
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
205/40-18s up front or square 215/40-18s.
CLICK HERE!!!
Old 05-19-2014, 12:22 PM   #3126
d_nice
d_nice's Avatar
Trader Rating: (39)
Feedback Score: 39 reviews
is this on a s14 or s13
Old 05-20-2014, 05:02 PM   #3127
Mishkin_707
Thanks fliprayzin, I actually decided going 205 and 225
Old 05-22-2014, 08:30 AM   #3128
Black R
Black R's Avatar
Black R is an unknown quantity at this point
S13: 18x10 et+18 on 285's.
How much spacer to clear coilovers up front?
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers
Black R is offline   Reply With Quote
Old 05-22-2014, 09:37 AM   #3129
fliprayzin240sx
Wont know till you put it on...depends on what coilovers you're using. I've cleared mine on those exact sizing. Also, if your coilover has a notched upper mount hole, you can pull the knuckle as far away from the strut as possible to give your wheel some extra clearance but will give you more positive camber.
CLICK HERE!!!
Old 05-22-2014, 02:07 PM   #3130
Black R
Black R's Avatar
I have Kts coilovers - I think they're 60mm springs.
I needed a spacer to clear 18x9.5 +25 because the wheel touched spring even though the tire didn't, so I'll likely need at least 5-10mm to be safe.
Old 05-22-2014, 05:21 PM   #3131
stuckonfresh
stuckonfresh's Avatar
stuckonfresh is an unknown quantity at this point
Has anyone here successfully mounted a 245/40 tire onto a 12.5" wide wheel?
stuckonfresh is offline   Reply With Quote
Old 05-25-2014, 05:03 AM   #3132
fliprayzin240sx
I needed a spacer to clear 18x9 +25 because the wheel touched spring even though the tire didn't, so I'll likely need at least 5-10mm to be safe.
How much spacer did you need to clear the 18x9? Just by comparison and using the 9j +25 as a reference, the 10j +18 inner clearance will be 6mm less (closer to the springs). Safest bet would be add how much you used before + 6mm more on top of that.
CLICK HERE!!!
Old 05-25-2014, 12:48 PM   #3133
Almosttt
Almosttt is an unknown quantity at this point
Hi I don't know too much about wheel fitment but I was inspired by this picture:
I really like this as opposed to the stretched tire with max camber thing that everyone seems to be doing these days.
According to where I saw it posted the wheel specs are 18x9.5 + 22 with (255-40-18)'s. So would those fit just fine or do they need some modification/adjustments or anything? Noob question I know, but I'd appreciate the help!
Almosttt is offline   Reply With Quote
Old 05-26-2014, 10:57 AM   #3134
ZenkiDeven19
ZenkiDeven19 is an unknown quantity at this point
Your defiantly going to need a roll/pull in the front maybe even spacers. As for the back you should be find though
Sent from my SCH-I535 using Tapatalk
ZenkiDeven19 is offline   Reply With Quote
Old 05-30-2014, 12:12 AM   #3135
Black R
Black R's Avatar
I think it was either 1/4" or 1/8".
I had a typo on my previous post - fixed now, they were 18x9.5 +25.
So that's where I was getting 5-10mm estimate from.
Old 05-30-2014, 08:38 AM   #3136
theericsmith
theericsmith is an unknown quantity at this point
Recently I've decided to sell my s14 and purchase a z33. Wheel and tire fitment for s-chassis was pretty simple given all the information on this site, however I can't seem to find much info on 350z wheel fitment on Zilvia or through google. There are a few examples here and there, but nothing like the wheel fitment thread or anything like that.
This is getting long, but basically I was wondering if you guys had any good examples of 350z's running 18x9.5s? I haven't picked an exact wheel yet but I'm assuming I'll go with a simple size like that. I've also never had wheels bigger than 17's so I'm not too sure what size tire to run either. The car will definitely be as low to the ground as chicago/midwest roads allow.
Much appreciated!
theericsmith is offline   Reply With Quote
Old 05-31-2014, 01:55 AM   #3137
fliprayzin240sx
Z33s have bigger wheel wells, you can run more aggressive fitments (wider/lower offsets) than S14s. Go into wheeltuck.com and see examples of Z33s that you like and follow their setups.
CLICK HERE!!!
Old 05-31-2014, 09:32 AM   #3138
theericsmith
thanks fliprayzin! googled it I assume you mean rimtuck?
Awsome website, thanks again
Old 06-02-2014, 11:21 PM   #3139
ZenkiZenki14
ZenkiZenki14's Avatar
ZenkiZenki14 is an unknown quantity at this point
anyone on here have the Work Cr Kiwami's in 18x10.5 and 18x9.5 with tires mounted on them?
ZenkiZenki14 is offline   Reply With Quote
Old 06-03-2014, 09:29 AM   #3140
theericsmith
not sure why so kiwami specific but there are a plethora of 18x9.5/10.5 wheel set ups on basically every page.
Old 06-03-2014, 09:49 AM   #3141
livelovesole
livelovesole is an unknown quantity at this point
Im currently running a 16x8 wheel up front on 205/50. Tires are going out so I'm going with a thinner tire. Am I going to run into any issues running a 205/40 tire? Any input helps, thanks.
livelovesole is offline   Reply With Quote
Old 06-03-2014, 07:33 PM   #3142
fliprayzin240sx
they're stupidly undersized...
CLICK HERE!!!
Old 06-05-2014, 04:55 PM   #3143
joshls2
joshls2's Avatar
joshls2 is a well-known jackass
Hey, does anyone have any info on the specs of these wheels? I'm guessing they're 17s but they sorta look like 16s.. it's hard to tell.
and what tires do you think hes running? I bet the rims are 9.5 width so tires might be.. 225/45? I've been trying to find info on this car for hours now.
pics: http://www.autongraphic.com/2013/11/zenki-x-te37v.html
joshls2 is offline   Reply With Quote
Old 06-19-2014, 09:02 AM   #3144
silnv
silnv's Avatar
Trader Rating: (39)
silnv is an unknown quantity at this point
Send a message via AIM to silnv
I have my first wheel fitment question.
I have a 98 s14 with stock metal, coilovers and fully adjustable arms.
I recently purchased a set of SSR Vienna wheels, and was lied to on the widths and offsets. They were supposed to be 18x10 +35 and 18x9 +35. I received them and they ended up being 18x9 +49 and 18x8 +49. They did have shit tires on them, 265/35 on the rear and 235/45 on the front, so I put them on to see how bad they were. They actually cleared the coilover, but neither the front nor rear will clear my brakes.
So I decided to just rebuild the wheels since I would lose my ass on selling them. I am going to add an inch to each wheel on the outer lip. This will make the wheels 18x9 +24 and 18x10 +24. I will need to run a 10mm spacer on the front and 5mm spacer on the rear to clear brakes. I also have a high HP build going on so I do not want stretched tires. Can I fit 275/35 on the rear and 255/40 on the front?
TLDR;
S14
18x9 +14 effectively
18x10 +19 effectively
Can I fit 255/40 on the front and 275/35 on the rear under stock metal?
Thanks
1997 Nissan 240sx
1991 Nissan 240sx hatch
silnv is offline   Reply With Quote
Old 06-19-2014, 12:33 PM   #3145
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
TLDR;
S14
Thanks
Provided you aren't really low, I don't see any reason why those sizes wouldn't fit. Although, I would recommend a 255/35 instead of the 40 series. 255/40 is a tall ass tire (IMO) and you might get some rubbing. But again, if you're not low, it shouldn't be tooooo much of an issue. Just a roll of the inner lip should be good. Check out the black kouki just a few posts up. It's running very similar specs up front.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 06-20-2014, 10:18 AM   #3146
MeGusta
MeGusta's Avatar
MeGusta is an unknown quantity at this point
will i have problems fitting a 17x10 -4 on a s14 rear ? roll , pull?
MeGusta is offline   Reply With Quote
Old 06-22-2014, 06:33 AM   #3147
fliprayzin240sx
Will need a pull, how much will depend on how much camber and stretch.
CLICK HERE!!!
Old 06-22-2014, 09:30 AM   #3148
mrfyzv
mrfyzv is an unknown quantity at this point
after tuning cars become more beautiful !!!
mrfyzv is offline   Reply With Quote
Old 06-24-2014, 10:16 AM   #3149
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
so i'm having an issue sizing up my new front setup since i relipped my meisters for the s14, i use to run a 215/35 up front and was planning on running a 225/35 this time around since they are now 18x10 with the new lips, but falken discontinued all of their 225/35's i really don't think a 225/40 is going to clear up front with how the car is sitting at the moment. any suggestions guys?
Slip Gypsies Blog
not sure if you realize this
Old 06-25-2014, 06:23 AM   #3150
I'm Redline
I'm Redline's Avatar
225 on a 10 is serious stretch, why not run a low profile 235 and have a bigger footprint? A 235 on a 10 will stretch maybe an inch max, or about the same as a 225 on a 9, or in other words, perfect fitment!
My work in progress...
