02-27-2012, 10:45 PM | #301 | |
I know this is a dumbass question but im gonna ask it anyway: can ANY wheel be widened? Like if its a cheap ass rim, will/would it work without shattering? Im not too big on wheel terminology so excuse me if i said something dumb haha
02-28-2012, 06:54 PM | #302 |
Quite a lot of people struggling with the math on the past few pages. We made a calculator on our site specifically from playing around with widening wheels in mind. Have a look and see what you think:
Split Rim Offset Calculator | Garage LSD Also im currently in the process of building and even bigger set of panasports at the moment, just need to decide on the colour.
02-29-2012, 09:26 AM | #303 | |
And the calculator wasn't any different than the answers I got. With the exception of the one the was corrected by another member. :s |
03-01-2012, 10:51 AM | #304 |
Sorry, I'll re-phrase. We've made a calculator to help people out as much as possible when it comes to widening wheels. If there's any other features people think might be usefull to them then let us know and we will try to include them if its feasible.
03-01-2012, 12:09 PM | #305 |
Trader Rating: (55)
Feedback Score: 55 reviews
the calculator is nice but your missing one factor since some faces are sandwiched between the lips. the faces make the wheel .5 inches wider. I know i can just add the width of the face to the barrel to get the correct siz, but just letting you know.
03-01-2012, 12:13 PM | #307 |
ok so im about to re-lip my rims
are these the correct steps Disassemble : 1- take off tire 2- take off nuts and bolts 3- cut away sealant from seam 4- heat up and separate 5- clean assembly: 1- put together all three pieces 2- reseal bead 2- make sure all surface is clean and good fit 3- bolt down face in criss-cross pattern torque to proper specs (20-24ft/lbs iirc) is that it or am i forgetting something??
s14 kouki ka-t |
03-01-2012, 01:38 PM | #310 | |
how long did it take to do all 4 wheels?? also whats a good solvent to use to clean the inner barrels mines has built up brake dust..
s14 kouki ka-t |
03-01-2012, 02:32 PM | #314 |
ok so i want to widen my wheels and here is the dilema
Wheels are Blitz type 03. currently the fronts are 17x9 and rears are 17x10. Everyone swears up and down that these wheels cannot be widened yet all four wheels are stamped 17x9+22 and the rears are 100% 10" wide and have slightly larger lips 4.5" vs 4" in front. I would like to run the 17x10 up front and widen the 17x9 im not looking to make it have a huge lip i literally just want it wider. Does anyone have any info on who/how it can be done? And please do not tell me they cannot be widened since i have a set that already has been. Also the previous owner purchased them in this size, so he doesnt know either. Pics:
NO HANDS IN PANTS!! |
03-01-2012, 02:56 PM | #315 | |
Here are my Fronts, Work 18x8s Bead to Bead = 8 inches wide Overall width is aprox 9 inches
WTF IS JUICE?? I WANT THAT PURPLE DRANK!!! |
03-01-2012, 03:14 PM | #317 |
Step 1: Get a big fucking lathe
Step 2: Chuck up the wheel in the lathe Step 3: Cut wheel Step4: make new section Step 5: Tack to wheel Step 6: Check runout Step 7: Tack remaining lip piece to extension Step 8: Check runout Step 9: Weld I don't really understand what you're asking. There's really only 4 ways to widen a wheel 1. Re-barrel 2. Re-lip 3. Cut and weld 4. Machine your own piece from billet 5. Call CCW...... A lathe can only work on a rim that's as big as the lathe's swing. IE Distance from bed to center of the spindle. (American lathe don't measure it that way. They just refer to it as the biggest piece you can machine. English lathe go by the spindle center) An 18'' rim will require a lathe with an 18'' swing (American) or a 9'' swing (English)... So you won't be using a lather that fits in the average Joe's garage... For example, but not limited to< my lathes at me last job, could swing a 24'' (American) piece of material... And the lathes were 20' long.. |
03-01-2012, 03:31 PM | #318 |
Just to be thorough
here ar my Rears which are stamped 18x9
Bead to Bead = 9 inches wide Overall Width = approx 10 inches wide
03-02-2012, 05:43 PM | #320 | |
Changed the assembly order and added some notes, lol.
Instagram - SJKnoop |
03-02-2012, 09:38 PM | #321 |
daniel just did his blitz 03s, super wide spec. info is icedsole on this forum
did 03s come in different disks? I remember reading that all of them had ~the same amount of lip between offsets it was just the backing of the rim being different
street dancer. GLEAM |
03-03-2012, 07:08 AM | #322 |
thanks Knoop that helps alot,
when you heat it up to seprate do you have to put it in a oven?? or can i just use a head gun?? thanks
s14 kouki ka-t |
03-03-2012, 09:44 AM | #323 |
I've always used an oven...even with an oven I've had to either stomp them apart or use a 2X4 battering ram (which is hilarious). You can also put the wheel face down and stand inside of it and pull up with welding gloves on the rear barrel...but it is way easier to bash them apart with wood.
03-03-2012, 10:02 AM | #324 |
^thanks seems like i have alot of fun times ahead of me -__- lol
im going for the 2x4 techinque, i take it i pound away at the lip side ?? edit:: whats good to clean the rims after they are apart, wire brush that goes in the drill/3m scotch bright?? thanks
s14 kouki ka-t |
03-03-2012, 02:01 PM | #326 | |
As far as the 2X4 goes...I was using a powder coating oven at my friend's shop because I could fit all the wheels in at once and he had a 8 foot 2X4 so he used it like a battering ram and it worked in one hit, haha. We were trying a rubber mallet and I just couldn't get them apart. If you don't have 2 other people who can help you (one to heave-ho the 2X4, and another to help you hold the wheel still) then you can lean the wheel against a wooden step (like on a porch or something) after removing the front lip (usually comes off super easy) and stomp the back of it while pulling up on the rear barrel until the face separates.
03-03-2012, 02:46 PM | #328 | |
I needed a new sig. Thanks broham.
03-05-2012, 09:38 AM | #329 | |
Trader Rating: (131)
Feedback Score: 131 reviews
One other thing to note- Yuta told me that a lot of 03s are welded together, instead of with sealant. They can still widen them, they just have to cut them apart before they begin, which adds a bit to the cost of having them rebuilt. Did you buy those from a member here/dude in Cali that had them on eBay? I was considering them, but wanted 17/18 and the seller gave me crap for asking for pics. That was enough for me to not respond, lol. |
03-07-2012, 08:50 AM | #330 |
Any one know what size socket to use on the bolt side of VS-MX wheels, ive read it was 8mm 12 point but the 8 mm for some reason doesnt fit on the bolt head.
they look bigger in person
s14 kouki ka-t |
