#332 |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
![]() ![]() New chassis harness on the way ![]() BC valve springs, Titanium retainers, and valve seals being done while the engine is out. Also going to powdercoat turbo and manifolds to freshen things up a bit.
#333 |
![]() Join Date: Feb 2007
I didn't know faction was doing wiring services!
I'm gonna have to check out the S13 chassis harness.
Determined to be famous, destined to be infamous.
#335 | |
Hopefully it works - the day I placed my order they removed the JZ option from their site
#336 |
BiG MiKE's Little Build!
How it currently sits...
![]() OEM valve seals, BC springs and Ti retainers installed ![]() Figured while it was out it might as well get some ARP studs and a new OEM head gasket ![]() ![]() Should be dropping it back in this weekend
#340 |
Faction Motorsports harness showed up
![]() ![]() All stock wiring gutted (right) and new harness on the left ![]() Relay panel installed and switch panel just mounted temporarily until the dash is back in ![]() Have a JDM cluster for sale if anyone is interested. Works great and all bulbs are LED Dropping the engine and trans this weekend hopefully to get her running again ![]()
#344 |
Build is looking good, man.
Let me know how you like that Faction Chassis harness. The harness in my car is kinda fucked, and I'm weighing the different options for re-wiring. Does it have any provisions for a radio? My car will never not have a radio in it.
#346 |
It's a factory plug and play, it can also be wired to have stereo provisions.
#347 | |
Looks like it has provisions for just the front speakers. After that it's just powering the head unit so it's pretty much there.
#348 | |
Factory cluster is a no go - this harness is the bare essentials.
#355 | |
![]() Quote:
#356 | |
Thanks man. I believe it was Nocturnal Motorworks if I'm not mistaken. I shipped to to a Mike for something like $85 for the service almost 3 years ago now and yes it worked fine with stock ECU ![]() Sent from my iPhone using Tapatalk
#357 |
Thanks for the info Big Mike, gonna get to it right now. I'll be starting my own build thread just to share some, but my build is way more humble day to day kind of car, you guys are on a hole other level, thanks again
#359 | |
Eh.. Lol strong is an overstatement. What ever happened to your build?
#360 |
Little by little I'm tightening things up and getting her roadworthy again. Ran into a gas leak that's probably going to need another tank.
![]() Bought a new 3-1/2" treadstone intercooler to have the whole system redone and finally throw on a blow off valve and AEM AIT sensor. This setup (Greddy VSPL core) with pipes will be for sale soon. ![]() ![]() Last weekend stuck on the side of the freeway when an ignition breaker popped. Didn't find out I could have easily reset it until after I paid for a tow and sat in the scorching Florida heat for about an hour. ![]() ![]() Sent from my iPhone using Tapatalk
