#4681 | |
![]() Join Date: Mar 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 12 reviews
Yes sir Dexron III ATF - power steering works great for a few days then it dumps it everywhere as I drive
#4683 |
![]() Join Date: Sep 2010
![]() Feedback Score: 11 reviews
It's the same as a supra 2jzgte pump. But I would make sure you have absolutely no leaks. I run just power steering fluid and have only had a problem when I'm hot lapping at a drift event an it starts to boil over, but have since added a external cooler. What high pressure line are you running?
Follow me on Ig- Andydennington |
#4684 | |
I've got the Chase bays I believe. Now that I think about it I believe my rack may have a leak but would that really cause fluid to push out of the reservoir?
#4685 |
It can. When there is a leak it creates air in the system. So when you turn the wheel, that "air pocket" moves thru your ps system and pushes out the reservoir
#4686 | |
Its never not ran, but it definitely makes less power some days. Ive notice the timing will change under WOT and full boost, as well as cruising afr. |
#4688 |
Sounds like either a wiring or mechanical issue. I've ran aem for a year and never had an issue.
#4689 | ||
![]() Join Date: May 2006
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
Sent from my SM-G900V using Tapatalk
#4690 | |
Its parked for the winter now while I work on the 240. In the spring I plan on adapting the extra harness I have (If it doesn't sell) for the 1J in the 240. |
#4692 |
#4696 | |
![]() Join Date: Jan 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 14 reviews
I'm on j30 rear.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
#4697 | |
![]() Join Date: Aug 2012
![]() Feedback Score: 6 reviews
follow my build on instagram: s14project |
#4698 |
Induction performance; 2900
Pro128 Wideband 5 Bar IAT Fuel Pressure iBoost switch Boost solenoid Supra 6Spd Harness Flex fuel kit/harness free base map
#4699 |
Pretty sure I'm going to give the haltech elite a try for this car. Seems like all the people i know that had a haltech switched to it and are in love.
Also I run a Q45 diff in my s13. Should be nice with the R154 gearing. |
#4700 |
Hey guys,
So I've been working on installing my Tomei FPR and decided to upgrade to 6AN Fittings since the regulator came with them.. When I went to upgrade, I purchased a 6AN Banjo from Earls, and my line and line fittings from ebay seller and it looks like Earls Banjo has a different seating design. I've started to grind down the area of fitting that is bottoming out on other fittings, but just wanted to see what you guys think about doing this? It looks like the actual tapered area just in front of the threads is what seals so I'm not too worried about it. I plan on also using Loctite Thread sealant just to be safe. You all think this is ok? edit: Alright, scratch that... The second pic is showing what I have it grinded down to now, but it still stops in the same spot. It appears the thread pitch is actually different. I guess I assumed all AN fitting used the same thread pitch, but I guess not? I see now how the design was suppose to work, but unfortunately the piece is destroyed now.. lol. Last edited by XxS13LifexX; 11-30-2014 at 02:41 PM.. |
#4702 |
I have the factory fuel feed hard line coming up in the oem location but don't like it there - Too close to my downpipe.
Anybody redo their fuel hard lines? I want to do a crossover hard fuel line high in the engine bay, and I guess I'll just heat wrap it or something near the downpipe (which is also wrapped).
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers |
#4703 | |
The q45 final drive is way too lazy with r154. I want to move to a 3.6 or 3.9 when I put my q45 rear end in. I'm currently using the j30 rear end with the r154 and it still kinda sucks - 5th gear will go over 160 easily.
S13 XE coupe: Aristo GTE, R154, GT37, Defsport Wilwood kit, KTS coilovers Last edited by Black R; 01-27-2015 at 06:37 AM.. |
#4704 |
CD009 people- looking at using a collins adapter/drive shaft/clutch etc with their full kit.
What engine mount kit should I go with? or does it not matter. Thinking just using an ebay set up since the price for the other shops is high and the include a trans mount which I don't need. I will be running a J30 rear end for the time being, but worried the gearing will be way to high since this is a drift car. |
#4706 | |
#4707 |
![]() Join Date: Nov 2008
![]() Feedback Score: 16 reviews
Just started my swap.. Looking forward to contributing to the thread and also I'd love to put up a little FAQ website that people can contribute to.. that way things are a bit more organized.
I'll be putting in a 2JZ-VVTi into my S13. Pretty pumped, just investigating cost/benefit of Collins adapter/Z trans vs R154... |
#4708 |
![]() Join Date: Jun 2009
Trader Rating: (24)
![]() Feedback Score: 24 reviews
I don't know much about pricing. How much did you guys pay for your jdm 2jz long block? no tranny or ecu.
I'm looking to pick up a jdm 2jzgte non vvti auto, but I'm not getting the tranny or ecu. It comes with harness and everything else. I have no idea how much it's worth.?
REVIEW |
#4709 | |
1800 with trans, igniter, ecu Make sure you check the compression, don't know how to do that without the starter though |
#4710 | |
![]() Join Date: Jul 2007
Trader Rating: (18)
![]() Feedback Score: 18 reviews
'92 HB HX35 rb25 - sold '89 Coupe GTX35 VVT-I 2JZ - yeah buddy |
