Old 12-13-2013, 09:44 PM   #481
silviaks2nr
silviaks2nr's Avatar
Just get the h4/9003 harness TRS sells and it will do exactly that, and completely plug and play. Even has 9006 inputs for the mini bixenon solenoids.
Old 12-13-2013, 10:46 PM   #482
mad-ass
mad-ass's Avatar
So far..I have this.
Well, I seem to do this all the time, post up a question with 1/3 of it answered on my own, read and research again and kind of find my own answers...So from what I've been reading so far I've gotten these two items just now.
Capacitor for the [Low to High] or [High to Low] transitions so the HID doesn't loose power, and Diode to keep the HID on.
now I just gotta figure out where exactly they would need to get soldered onto.
oh, and I am broke ATM and I always enjoy figuring stuff out and doing it on my own(If I can do it, I might as well do it kind of thing, the nerdy stuff), so I didn't want to buy the TRS harness. I've called them twice just today asking the same questions to them and I didn't get a clear answer on what exactly I needed to order from them, and twice in same day is enough for me.
edit: after some thinking and what not...i think this will work.
My HID system already has relays in it, so I'll leave that alone.(1 relay powering both ballasts. don't want to change it because it's been working perfectly fine for last 5 years)
So instead, I'll change things around the stock low-beam harness.
I'll tap into the high-beam wire and solder in the bi-xenon solenoid wire than the diode to the low-beam wire. On the low-beam wire after the diode, i'll solder in the capacitor than finally into the H4 socket.
I'll try to draw this out, but hopefully that makes sense and will work with what I'm trying to do here.
edit #2: Here's my super fine Power Point drawing! lol
This is all before it gets hook up to the bulb or the ballast.
Old 12-13-2013, 11:56 PM   #483
shephurd
shephurd's Avatar
shephurd is an unknown quantity at this point
just got hella h4 conversion for s13, will update with pictures
shephurd is offline   Reply With Quote
Old 12-14-2013, 12:33 AM   #484
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Are you just doing Halogen bulbs or are you just going to toss H4 HIDs in there without doing the proper retrofit of the housings?
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 12-14-2013, 10:00 AM   #485
silviaks2nr
you shouldn't need the capacitor actually then. But what you have there will work. Put a 15a fuse inline in the power wire to each ballast
Old 12-14-2013, 01:43 PM   #486
mad-ass
mad-ass's Avatar
^there is a 25A fuse for the main power relay(again, been fine for 5 years now, i think it's a good system) already that feeds power to the ballasts. I know the capacitor is completely optional, but I put that there so there is no brake period on the ballast for the power transition from low-to-high.
unless you are saying i really don't need it for what I want it to do.
Old 12-14-2013, 01:49 PM   #487
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Why dont you just run 2 relays? Thats what I'm doing to keep my lows on, when I flip the highs.
CLICK HERE!!!
Old 12-14-2013, 05:26 PM   #488
coreyh
coreyh is an unknown quantity at this point
why run ground between 85 and 86? why no just keep the wiring parallel?
coreyh is offline   Reply With Quote
Old 12-14-2013, 07:28 PM   #489
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
My retrofit is done with Audi TT headlights and they're aimed WAY too low.
Does anyone know what I can do to correct this?
Old 12-14-2013, 07:31 PM   #490
silviaks2nr
when the retrofit was performed were the audi projectors mounted so that the hid low beam lined up with the original kouki halogen low beam? If you didn't do the retrofit yourself you might not be able to answer this I guess... First make sure the bulb connector isn't interfering with the back housing and then just turn either the top or bottom 8mm hex adjuster which is located between the low and high beam until the aim is more suitable.
Old 12-14-2013, 07:32 PM   #491
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
I've turned the adjuster, but it only adjusts the high beams.
I didn't do the retrofit. I just bought them. They're aimed pretty low. It really sucks.
Old 12-14-2013, 07:33 PM   #492
silviaks2nr
do you have jdm lights? the adjusters are in a different location if so
Old 12-14-2013, 07:34 PM   #493
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
They're USDM housings. I'm sorry I didn't include that info -__-
Old 12-14-2013, 07:40 PM   #494
silviaks2nr
hrmm something really odd must be going on then. The projector is mounted to the same metal bracket inside the headlight as the high beam reflector in USDM lights. My guess is the bulb connector is hitting the housing causing the projector to get stuck or one of the threaded clips inside the headlight, on the mounting bracket, is stripped.
This is for aiming either for future reference though
Old 12-14-2013, 07:43 PM   #495
silviaks2nr
Do you have a picture of the output? I wonder if the projectors were not mounted to the bracket properly and are pointed down instead of mounted so the low beam corresponds with the high beam. Is your projector beam pattern way lower than the high beam "hot spot"?
Old 12-15-2013, 12:07 AM   #496
mad-ass
mad-ass's Avatar
well, 85 and 86 can be swapped if there are no diodes are involved, and either one of those two posts need to be grounded to activate the relay, I'll assume it was purely for ease of drawing purposes.
fliprayzin240sx, I hope you are doing well with your deployment, come back home safe.
I don't see the need to run extra relays because my ballasts gets power straight from the battery through it's own relay harness and I only need to mess around with the input signal to the ballasts so it doesn't turn off during the High-Low transitions(i'll be using the capacitor for this reason).
And plus, relays add extra bulk and wiring that I really don't need.
I am probably going to be doing this on the HID harness and not on the OEM harness to keep it simple as possible, and I also always wanted to redo the store bought relay harness since I started reading upon projectors(it was bit much to take in at the time, but I realized how simple things were after I knew what I was doing. haha)
Old 12-15-2013, 04:05 AM   #497
fliprayzin240sx
I ran dual relays just to be safe. I never found a definitive answer on how much amp HID ballasts pulls on the initial ignition of the bulbs.
Yah, the drawing is just a reference. I used it on my Zenki in Japan when I did my retrofit and used it on my current car when I converted to Kouki. I just think its alot simplier to do with 2 relays and using the original low beam power wire as the switch reference.
CLICK HERE!!!
Old 12-15-2013, 09:14 AM   #498
shephurd
shephurd's Avatar
Cant remove my current headlights to install my hella h4's because the screws are rusted and striped. Does anyone know where i can get new screws?
Old 12-15-2013, 10:02 AM   #499
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Def have USDM lights.
The projector unit(?) from the Audi TT seems to be entirely in the housing. They may have cut out the adjustment plate for the low beam to house the projector unit. I'll bake it and open it up and report back with what I find.
Old 12-15-2013, 10:04 AM   #500
fliprayzin240sx
You'll probably have to shim it inside to push it up higher when you open it.
CLICK HERE!!!
Old 12-15-2013, 01:33 PM   #501
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
What that mean? Like put something under it or something? I am gonna open them this week if that's all I have to do. Tired of this shit. LOL
Old 12-18-2013, 09:37 PM   #502
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Originally Posted by jamg View Post
what's the best h4 halogen money can buy?
If only looking at OEM-wattage 60/55W bulbs, these currently seem to be the best, if the advertised '+percentage over standard' ratings may be trusted:
1. Narva Plus 120 (+120%)
2. Osram Night Breaker Unlimited (+110%, 'white' tint)
3. Philips X-treme Vision (+100%)
3. Narva 48342BL2 (+100%)
4. Osram Night Breaker Plus (+90%, 'white' tint)
4. Narva 48532BL2 (+90%, 'white' tint)
I am considering going back to regular bulbs, since I dislike all the extra junk that comes with HID's.
Though I am not a fan of LED's on old cars, these LED sealed beams do not look as offensive as the other offerings. Too bad about the black bits. I wonder how they would look and perform with some non-clear Sylvania or Hella lenses transplanted onto them.
[yt]JelMzHG
Old 12-19-2013, 11:22 PM   #503
hybrid_eg
hybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the roughhybrid_eg is a jewel in the rough
Silvia dual projectors, retrofitted with RX projectors, color modded, TRS clear lens, black headlight bowls painted black, clear circuit sport housings, note -do not attempt using OEM glass ones, their output is terrible!
I will follow up with new pics, day/night once installed on the car.. they have been sitting around for about a year now but hopefully the old lady will run next month.
Tests were performed with 85122CM bulbs and 35W ballasts, I will be running 55W so expect more output than pictured.
I love my bricks but the output simply blows at night so I thought Id give this a shot.. Enjoy!!!!
hybrid_eg is offline   Reply With Quote
Old 12-20-2013, 12:06 AM   #504
mad-ass
mad-ass's Avatar
dat shroud...what is it?
Old 12-20-2013, 12:21 AM   #505
hybrid_eg
It's not a shroud, the ring around projector is just what came with RX, the black housing around the projector is oem Nissan headlight backing which is originally metallic grey color when you take glass lens off, in my case I painted it black as I wanted it less flashy..
Old 12-21-2013, 06:03 AM   #506
soryu
soryu's Avatar
soryu is an unknown quantity at this point
Originally Posted by advanEST View Post
Hi!
well, i did mine with HELLA FF75 lights!
Output pics? What kind of bulb?
Relay?
soryu is offline   Reply With Quote
Old 12-22-2013, 06:04 AM   #507
kouki-gymkhana
kouki-gymkhana is on a distinguished road
What are you guys using the trigger the HID harness? The original headlight stalk or a separate button? I really couldn't figure out the complicated FSM diagram for the headlight switch. Right now I have it set up completely separate from the headlight stalk but I want to have OEM functionality. Any tips or links?
**The atypical S-chassis enthusiast***
kouki-gymkhana is offline   Reply With Quote
Old 12-22-2013, 09:49 AM   #508
silviaks2nr
use the +12v low or low/high from the factory body harness.
Old 12-22-2013, 10:06 AM   #509
mad-ass
mad-ass's Avatar
Check your FSM...should come across something like this.
and this is pretty much what I'll be doing integrated with my previous drawing.
Old 12-22-2013, 06:42 PM   #510
Gordo714
Gordo714's Avatar
Gordo714 is an unknown quantity at this point
Had these projectors laying around for the longest time
still need to adjust them but they are good for now
Gordo714 is offline   Reply With Quote
