#31 | |
![]() Join Date: Jan 2003
#32 | |
Like Me on FaceBook ![]() |
#33 |
![]() Join Date: Jan 2004
The only way it would give more power through not holding boost would be when the wastegate is open. The exhaust flow from the turbo would not be interupted since the wastegates exhaust flow wouldnt even be going near it. Problem is, 18psi on a GT28r and your wastegate is closed damn near the entire time. That dyno graph just seems iffy to me. That is a shitload of power to make on any 2.0 liter turbo car at 6 thousand rpms
I'm from Florida so I'm probably a bit more strange than you |
#34 | |
![]() Join Date: Oct 2003
#35 |
best thing to do in your case (which works pretty damn well imo) is to get a better actuator with an adjustable arm and a fresh diaphram, like the HKS adjustable one.
Then Tighten it down as much as you can, and pull it back over the WG arm. You should be able to get a steady 12-14 psi on it depending on the wg hole size and turbo specs. Then your Boost controller doesnt have to work as hard (actuating the solendoid bleed valve) to control the boost and youll get a more steady control of the surge and spiking that happens with efficent compressors and internal gates. hope that helps.
#36 | |
Thats what came with the turbo when I got it, I suppose I could get a new one but its not even a year old with very little mileage on it. I have it adjusted fully down, it holds 14-15psi normally like this, and still does in lower gears, problem is up high now in 3rd,4th,5th with these cams, it just starts creeping |
#37 | |
![]() Join Date: Dec 2004
Trader Rating: (58)
Here's a graph of mine @ 20...search my name, as my specs and stuff are found everywhere....Due to an odd injector/fuel problem in cyl one, it killed the piston, so I can't wait to see what the car will make at 20 with water injection + cam gears, as well as @ 23 psi ![]() ![]()
#38 | |
Trader Rating: (58)
