Old 12-22-2007, 01:34 PM   #31
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
34dt-dlg
1000cca
8 year warranty
not very big
side and top posts
80 bucks
jskateborders is offline   Reply With Quote
Old 12-22-2007, 01:37 PM   #32
rocksteady_racer
rocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her selfrocksteady_racer is making a name for him/her self
Send a message via AIM to rocksteady_racer Send a message via Yahoo to rocksteady_racer
s13 I like the Red Tops
I have had Red Tops in all my cars. Never had a problem with starting. Plus I left my headlights on in my 96 maxima for 6 hours and came out and the car still started right up. What other battery can do that?
rocksteady_racer is offline   Reply With Quote
Old 12-22-2007, 01:59 PM   #33
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
this is what im using , so far no problems. i dont have big sound system only a radio and speakers no amps, a clifford alarms and thats it . i think i paid 120 or something , dont remenber
ROIDMONKEY is offline   Reply With Quote
Old 12-22-2007, 02:01 PM   #34
thedecapitator
thedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choicesthedecapitator has made poor choices
wow thanks even for the pics! :] i am going today and buying a redtop at costco thanks zilvians!
thedecapitator is offline   Reply With Quote
Old 12-22-2007, 03:58 PM   #35
g6civcx
g6civcx's Avatar
My Optima yellow top
Old 12-22-2007, 04:49 PM   #36
ixfxi
Guest
Posts: n/a
Originally Posted by JoeC1982 View Post
Optima quality has went downhill over the last few years.. Oddysey, Exide Orbital(heavy), or Kinetik FTW
what is this bullshit? did optima all of a sudden start cutting corners? did you investigate their build quality and have some kind of undercover information that we're not aware of?
if you have something meaningful to add, say it.. just quit spreading propaganda.
Originally Posted by MegasquirtCA View Post
Odyssey is military grade, weighs 14 pounds. Rated to be in working condition for 12years, 3year warranty I believe and takes 2 years to discharge when left.
3 year WARRANTY, but definitely no 12 year GAURANTEE.
Point being, a battery will last as long as its properly maintained. Now, considering most S13 owners are idiots who dont maintain their cars... theres no reason to assume ANY battery, including a super strong optima/odyssey will last if the person neglects their electrical system.
The red top batteries are considered "starting" batteries, designed to give the most cold-cranking-amps for automotive use. Generally speaking, this is the choice battery for MOST people. Its a good balance of performance and cost.
The yellow and blue are both deep cycle, but the blue top seems to be more durable and dependable. I have had my blue to for near 10 years now, it STILL fucking works. The redtop in the Miata is also several years old and works like a charm.
If you maintain your electrical system by making sure your alternator is in good condition and properly charges the battery, then your electrical system will last for a very long time.
The biggest problem I see is that most people run these under-sized motorbike batteries and end up putting too much of a strain on their alternators (charging system). All for what? To save weight? I have an idea, get a girlfriend that isnt as fat...
that would be better....
Old 12-22-2007, 04:55 PM   #37
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
i have a optima redtop have only had 2 in so many years... die hards are good but better spend the few more on a optima... but i would recomend the yellow top its way better than the red one... ive heard good things about odyssey and svr you should check it out...
bejota180sx is offline   Reply With Quote
Old 12-22-2007, 04:59 PM   #38
burnsauto
burnsauto's Avatar
i'd say a redtop.
pros:
-good cranking power
-2 year replacement warranty
-gel cell, so you can mount it any way you'd like
-it wont blow up/leak acid
cons:
-price, but they're getting cheaper.
personally, i picked a yellow top, decent cca's and deep cycle, so i can run all the electronic gadgets without having to worry about it putting a strain on the system.
but thats just my .02 cents.
Old 12-22-2007, 05:02 PM   #39
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
agreed not to mention that optima's are used by the military, thus the reason they were on backorder two years ago when the Govt. purchased a ton of them.
bigOdom1 is offline   Reply With Quote
Old 12-22-2007, 05:17 PM   #40
Irukandji
Costco special
Irukandji is offline   Reply With Quote
Old 12-22-2007, 06:14 PM   #41
driftage240
driftage240's Avatar
driftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfection
Send a message via AIM to driftage240
buy a lil cage wit a wheel get a squirel and let it run around and power your car!!!! jdm battery ftw lol!!!!!!!!!!!!!!!
Misty blu is coming 4 you!
driftage240 is offline   Reply With Quote
Old 12-22-2007, 07:08 PM   #42
thedecapitator
wow i am extremely upset and angry! i purchased the redtop optima like a few of you guys suggested so i hook it up to the car and it doesnt fucken start my car! next thing i use jumper cables and still ATLEAST this time it gives a little faint bs that it wants to start but nothing!
ugh! i am angry
by the way i bought it at costco for what i believe a good price of 145$
i am just going to go to SEARS like another zilvian mentions and buy the DIEHARD battery for 100$ and with a 5yr instead of 3yr like the optimas
extremely dissapointed.
Old 12-22-2007, 07:56 PM   #43
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
you sure it's the battery?
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 12-22-2007, 07:59 PM   #44
thedecapitator
Red face
YES POSITIVE i mean it did turn on with a lil mazda battery but thats my dads
so what do you think should i just get the diehard
i think ima go that way now
after this bad experience
Old 12-22-2007, 08:00 PM   #45
Irukandji
Are you serious? The battery has probably been sitting for a while, so just jump your car, and drive around. Sounds like it just needs to be charged
Old 12-22-2007, 08:01 PM   #46
johngriff
johngriff's Avatar
Optima is trash.
Just standard miata case battery, its small works well, and is cheap. Pick your preference in manufacture, but those gelcell batteries are no fun.
[email protected]
Old 12-22-2007, 08:04 PM   #47
thedecapitator
no joke man that bitch got jump started still wouldnt start was left on like that for a good 4-5 min. and barely wanted to turn over but not even screw that optima bs after this it has scarred me for life!!
ima have to go with diehard and hope that one doesnt dissapoint me
and for the other post .. uhm a miata battery did turn on my car but the thing is i dont want to use that one since its my dads and im also gona be running a sound system ( no amps, though ) but still dnot wanna risk it
Old 12-22-2007, 08:05 PM   #48
thedecapitator
Originally Posted by johngriff View Post
Optima is trash.
i agree
Old 12-22-2007, 09:05 PM   #49
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
Yes base your decision on one experience instead of returning to costco and trying a different one
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 12-22-2007, 09:14 PM   #50
S14DB
AFC #1
S14DB's Avatar
ugh! i am angry
Did they check the charge on the battery before giving it to you? Heaven forbid you exchange it.
Good Luck with a DieHard I sued Sears for Acid burns I received from a brand new one as I was leaving the store. The top wasn't sealed on from the factory. Lucky they have a safety shower and the got my new cloths from the mens dept as it melted my shirt and pants.
Old 12-22-2007, 09:41 PM   #51
JoeC1982
JoeC1982 is just really niceJoeC1982 is just really niceJoeC1982 is just really niceJoeC1982 is just really niceJoeC1982 is just really niceJoeC1982 is just really niceJoeC1982 is just really niceJoeC1982 is just really niceJoeC1982 is just really niceJoeC1982 is just really nice
I wasn't saying optima is trash but i've had a few come in that were defective from the factory and i've seen many people having trouble with theirs on the car audio forums. Optima makes a good battery but there are others i'd spend my money on first.
96 240SX daily driver resto//mod
Nismo//JBL//Hawk
My feedback: http://www.zilvia.net/f/showthread.php?t=169481
JoeC1982 is offline   Reply With Quote
Old 12-22-2007, 10:55 PM   #52
driftage240
dont jump start the optimas... they need to be trickle charged like bike battery,cause it wit burn the battery..the red tops cant sit to long...kills them..atleast get the yellow tops.go back return it!,fuck die hard...Duralast
gold 24 800ccca 950crank amp,3 year free replacement and 8 year prorated,and my discount too pendejo!!! just make a trip....u never listen!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!
Old 12-22-2007, 11:12 PM   #53
thedecapitator
LOL why cause u get commission after u sell me a battery? haha!! thats 2 much gas money lol
^^^^ also wow i cant believe the diehard battery threw acid on ur clothes :-0 ima have to be careful
fuck this is the reason i made this thread
any other input on what kind of battery to buy??
ima check out the duralast gold also
thanks everybody
i bet that optimas arent bad and i just got a defective one but 1 bad experience is enough to leave as an unhappy customer
Old 12-22-2007, 11:32 PM   #54
kingyogi
kingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nicekingyogi is just really nice
i had a bad ground on my gold s14 somewherea nd it kept killing my optima redtops, literally killing 4 of the cells from some odd ass reason. i think i had a bad ground, BUT, i swapped batterys with my sister from her Scion TC and with even a bad ground the scion TC factory batter hasnt fucked me over in almost a month. still is like a champ.
kingyogi is offline   Reply With Quote
Old 12-22-2007, 11:41 PM   #55
thedecapitator
wow .. but in my case i dont have any ground problems its just that the positive post popped like half of it fell off .. good thing though ur cars still running cause mine isnt!!!
Old 12-22-2007, 11:45 PM   #56
drifting.8
drifting.8's Avatar
Location: What's heavier a pound of iron or a pound of feathers??
drifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud ofdrifting.8 has much to be proud of
Send a message via AIM to drifting.8
i actually like the carbon fiber batteries that bride has... they say there just as good as the optima batteries with half the weight..
RB 25DET NiZTECH BUILT
drifting.8 is offline   Reply With Quote
Old 12-22-2007, 11:48 PM   #57
nissan240sxkid
nissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enoughnissan240sxkid will become famous soon enough
I want in on this ......I didnt read any one using the wesco its nice and fits in tray awsome and its under 100 bucks, just an idea no burn please
nissan240sxkid is offline   Reply With Quote
Old 12-22-2007, 11:50 PM   #58
thedecapitator
^^ whats the cranking power
Old 12-22-2007, 11:54 PM   #59
nissan240sxkid
its 475 and its westco....I spelled it wrong sorry just noticed
Old 12-22-2007, 11:59 PM   #60
nissan240sxkid
its a mazda miata battery and it fits in like thedecapitator's battery....I have used 2 off them on diff projects and it snows where I live never had a problem...
