#31 | |
If you live in the middle of nowhere (Trinity), the only time you have to smog is transfer of ownership. So it matters which county you live in. Lol, you said that Bakersfield is "number two."
#34 | ||||||
![]() Join Date: Feb 2006
Trader Rating: (22)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 22 reviews
Also, you can't swap any motor into any car... The engine has to come out of a car that is the same year or newer. Get your facts straight before spreading false information, please. Quote:
Q45 diffs are great if you want rear end with taller gears. http://forums2.freshalloy.com/showthread.php?t=172393 You can ditch the VLSD in the Q45 diff in favor of something better. If you're fine with the stock gearing, I've heard good things about the ATS/Carbonetics 1.5 way LSD. They are pricey, though, unless you find one used. If you're going to run very sticky tires and/or drag race the car, I'd suggest swapping to either a Q45 rear since it is good and strong, or swapping out the stock 6-bolt axles for the JDM 5-bolt axles, which are stonger than the 6-bolt axles. lol, you're wrong as well. It varies from county to county. |
#35 |
![]() Join Date: Oct 2007
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
The car is going to be used for daily driving pretty often, my intention is to optimize it for the track though, 1.5 way with a 3.08 ratio would be ideal. I don't really need it any higher than 3.08 since I'll be having so many traction issues as it is. I'll look into the ones you recommended. ^^
#37 | |
Philosopher King
G O L D E N B E A R R E P U B L I C |
#38 | |
![]() Join Date: Jul 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
newer engine than chassis .. check smog legal engine ... check
#39 |
Yes, assuming all the OEM smog stuff is there. You are allowed to fabricate different piping to make it work in your engine bay, but you have to use stock injectors/ecu/maf in addition to EGR, charcol cannister, and the # & placement of cats...
#40 |
With the exception of the headers I believe, not sure if your counting that with "piping" or not. The headers need to be factory, or CARB certified aftermarket.
#41 |
They don't have to be factory if you can document that they wouldn't fit in their original configuration. But you will have to make sure the catalytic converters are in the same location(s) as the OEM manifolds (by location I mean same distance from engine so they warm up as quickly as stock). It is definitely more work (and some referees will discourage you), but it is possible.
#42 | |
You learn something new every day.
#43 | |
#46 | |
![]() Join Date: May 2005
Maybe you should read what I wrote a little more closely. If a 92 civic DX came with a D16 in it, and a 92 civic EX came with a B16 in it, you can legally put said B16 into your 92 civic DX. |
#47 |
![]() Join Date: May 2006
This was mentioned above, but I want to clear it up - with regard to the headers, the OEM ones do not have to be used, as they don't fit anything except F-bodys or Vettes.
But the configuration of all the emissions equipment has to be identical. When I say emissions equipment, what that really means is the cats. That means no long-tube headers, no headers that make you re-route emissions plumbing, nothing. As long as you keep that in mind, you'll be A-OK with CARB.
#48 | |
Trader Rating: (22)
Read this carefully: ANYTIME YOU SWAP A MOTOR INTO YOUR CAR THAT ISN'T THE OEM MOTOR FOR THAT EXACT YEAR AND TRIM LEVEL, THE SWAP NEEDS TO BE REF-APPROVED TO BE SMOG-LEGAL. Now, I'm reading what you wrote a little more closely... And what you wrote is indeed, retarded. Firstly, the 92 Civic EX never came with a B16. In fact, no US model Civic had a B16 in it until the EM Si coupe came along. Secondly, even if that Civic DID come with said B16, yes, you COULD swap that motor into the DX of which you speak, but it wouldn't be LEGAL without that BAR sticker. Now, I'm going to give you the benefit of the doubt here, and assume that this little arguement is the simple result of your shitty reading comprehension skills, and thus, is a mere misunderstanding. With that said, I'm done here. Have a nice day. |
#49 | |
Philosopher King
#50 | |||
#51 | |
Any updates?
I never followed through because another project drained my budget. I'm saving up so that I can do this swap as well, so I'm definitely interested in following your project. |
