Old 07-04-2009, 04:58 PM   #1
Forge_55b
Forge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enoughForge_55b will become famous soon enough
yes, exactly.
based on filters that aren't garbage
tinier filter, poor assembly & parts, and cardboard
what the fuck are you smoking you have no argument so just shut up
awww you want me to shut up and have to use profanity to prove your point.....i love the interwebz
so other then the fact that yes its cheaper stuff in it, you can't prove that it filters soooo badly that it would cause harm to your car, or are you just going to keep saying this stuff costs more and has better materials so the other stuff is instantly labeled garbage? I'm not trying to say that there is no difference between the filters, just that oem and fram filters will work fine regardless of the materials being not as good as more expensive ones.
Forge_55b is offline   Reply With Quote
Old 07-04-2009, 05:12 PM   #2
lflkajfj12123
They are made with inferior components, and many many people have reported more valve train noise on start up with these filters. They use cardboard end caps which can easily leak and cheap bypass valves which are known to stick open. You could get lucky and run them without a problem, but knowing that there are better choices for the same money, why take a chance?
I'm sorry if you don't understand the importance on how the filtration works in an oil filter.
Old 07-04-2009, 05:35 PM   #3
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
There is a defense in defending ebay exhausts, but IMO not for a fram filter, it only takes about 6 feet of movement to get out of the fram section. Why play "bang the hooker raw" when you can play it safe with a 12yr old by using a mobil1 or maybe a wix that wont leak.
Didnt they have a picture of a fram grenaded?
Bigsyke is offline   Reply With Quote
Old 07-04-2009, 04:45 PM   #4
Def
I've never had a problem with OEM Nissan filters. I've never see one tear up with track usage, and their drainback valves work.
I think it's just like oil, you can nitpick to the Nth degree, but as long as the oil you are using has a relatively good additive package you're just splitting hairs. I say this as someone who has at least some background in tribology.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 07-04-2009, 05:10 PM   #5
MrChow
MrChow's Avatar
MrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant futureMrChow has a brilliant future
Send a message via AIM to MrChow
Okay the thing with OEM filter that the newer ones are made in China switch are using paper filters. If your going to go with OEM filter make sure it's a blue filter and made in Japan. If not it's our true OEM filter.
wurd on the wix. That's interesting to hear. I haven't used wix filter yet. I've been on moble1 and k&n mostly. I don't see the different really between the two. I've used boschs filter a few times when they didn't have anything else. There not bad for a cheaper fitler. Like I said for the OEM filter has long has there blue and made in Japan there good.
Originally Posted by TheSquidd View Post
Are you the guys that buy your KSports and just turn the dampening knob to 32?
"It's stiff and hurts my livers! I'M A HANDLING GOD!"
WTT: 2 way for 1.5 way LSD
MrChow is offline   Reply With Quote
Old 07-04-2009, 05:13 PM   #6
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
protection wise.... just change your filter everytime you do a oil change.
i say. get the cheapest you can get. cause your just going to change your oil every 3000 miles. some ppl like us do even sooner.
as long as your changing oil its good enuff.
and most of you s13 guys your prolly leaking half a qrt a week. in one month you pour in 4 qrts maybe.
you guys prolly dont even need a oil change haha just keep pouring oil and changing your filter.
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 07-04-2009, 05:21 PM   #7
lflkajfj12123
i leak ZERO
Old 07-04-2009, 05:52 PM   #8
lflkajfj12123
yep
fram was banned from most automotive racing during the 90's because of the filters exploding and causing crashes
Old 07-05-2009, 02:13 AM   #9
MrChow
MrChow's Avatar
yep
Out of subject... Uh? You learn something new everything. =D
Old 07-04-2009, 06:36 PM   #10
Matej
Trader Rating: (39)
Feedback Score: 39 reviews
Nothing. K&N is supposed to be one of the best.
Old 07-04-2009, 06:47 PM   #11
HyperTek
filters only need to last 3k miles.. quality wise, your not gonna drive a year on 1 filter.. should be ok.
Keep it Classy
Old 07-05-2009, 05:11 AM   #12
lflkajfj12123
can't understand your engrish homie..
Old 07-05-2009, 12:22 PM   #13
Bigsyke
Bigsyke's Avatar
Are our filters supposed to have a bypass valve?? every nissan 240sx filter I cross reference has NO bypass relief valve?!
Old 03-07-2010, 10:14 PM   #14
jspeedm
jspeedm's Avatar
Trader Rating: (26)
jspeedm is on the path to ruinjspeedm is on the path to ruin
Feedback Score: 26 reviews
If I'm not mistaken, the KA has a built in valve.
most all filter manufacturers design their filters with valves when they are called for in the filter. otherwise they are probably built into the block or filter adapter.
http://i404.photobucket.com/albums/pp128/jspeedm/Picture097.jpg
jspeedm is offline   Reply With Quote
Old 07-05-2009, 04:45 PM   #15
GSXRJJordan
GSXRJJordan's Avatar
I was told that wix had the same oil press bypass as oem, so that would imply that wix Nd oem do? I don't know, haven't verified.
Old 07-05-2009, 05:02 PM   #16
dtc 360RT
dtc 360RT's Avatar
Location: You can tell how I walk, I ain't from around herr..Five6Duece, Kings Only
dtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfectiondtc 360RT is close to perfection
Send a message via AIM to dtc 360RT
Engine Oil Filter Study
DTCPerformance.com, Socal-Drift.com, Myspace.com/Dtcperformance
DTC 360RT Review
dtc 360RT is offline   Reply With Quote
Old 03-07-2010, 06:49 PM   #17
!!chuy!!
!!chuy!!'s Avatar
!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore!!chuy!! is not welcome here anymore
this should do the job.
Royal Purple Indaependent Videos
(i dont think they make it for our cars just yet but i cant wait untill they do)
!!chuy!! is offline   Reply With Quote
Old 03-07-2010, 07:04 PM   #18
PoorMans180SX
PoorMans180SX's Avatar
This is what I will be adapting to my car:
Pure Power Oil Filters High Performance Motor Oil
http://www.gopurepower.com/store/ite...em&itemKey=713
Old 03-07-2010, 07:07 PM   #19
!!chuy!!
!!chuy!!'s Avatar
http://www.royalpurple.com/index.php#
Old 03-07-2010, 07:11 PM   #20
!!chuy!!
!!chuy!!'s Avatar
damb Poor Man, there products are quiet spendy, but if u got the buck , why not get bucked off your seat. hah intresting website.
has anyone tried any of there products?
Old 03-07-2010, 07:10 PM   #21
ranger240
ranger240's Avatar
ranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the roughranger240 is a jewel in the rough
we need a new section for threads.. it should be called the
"dont buy (insert product with a high quality repuation) i heard on the internet that they suck"
last week it was garett turbos are trash.. this week its wix filters...
next week?? i'll uncover the TRUTH that volk wheels are worse than rotas
Originally Posted by surreybc
...common sense is for uneducated people who operate on animal instinct.
ranger240 is offline   Reply With Quote
Old 03-07-2010, 08:04 PM   #22
Bigsyke
Bigsyke's Avatar
actually read the thread. This was about the ADBV of the Wix vs PureOnes, which Wix filters were extremely hit or miss, but the Pureones were/still are spot on.
They Pure Ones cost the same as the wix, but out perform them.
Old 03-07-2010, 08:17 PM   #23
PoorMans180SX
Originally Posted by dtc 360RT View Post
Good link btw!
HAhahahaha, awesome post.
Old 03-07-2010, 07:31 PM   #24
Mitsubayati
Trader Rating: (18)
Mitsubayati is an unknown quantity at this point
Feedback Score: 18 reviews
Send a message via AIM to Mitsubayati
I just use Bosch filters. how do they rank?
http://www.fittedlife.com/images/nickbanner.jpg
Mitsubayati is offline   Reply With Quote
Old 03-07-2010, 09:05 PM   #25
D.Adams
D.Adams's Avatar
D.Adams is an unknown quantity at this point
Send a message via AIM to D.Adams Send a message via MSN to D.Adams
i ,l,ml,nbdnfnhdhg
“About the time we think we can make ends meet, somebody moves the ends.” ―Herbert Hoover
The build
http://zilvia.net/f/builds-builds-on...u-city-az.html
Owner of NVS Fabrications
D.Adams is offline   Reply With Quote
Old 03-07-2010, 11:45 PM   #26
Spring Break '92
Spring Break '92's Avatar
Spring Break '92 can only hope to improve
I was online earlier looking at the Delvac oils and saw that Mobil offers 10w-30. Seems like its alot easier to find the 15w-40 variety than any of them. As far as filters I just use whatever I can find with an anti drain back valve and buy in bulk. It doesn't seem like there are really any that truly hold pressure available for our motors.
BOOYAH!
Spring Break '92 is offline   Reply With Quote
Old 03-08-2010, 03:32 AM   #27
TurboSE
TurboSE's Avatar
TurboSE is an unknown quantity at this point
K&N...white, easy to see...have the nut on the end, easy to put on/take off...sold at the Autozone up the street, easy to find....I'll stick with them...
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please.
TurboSE is offline   Reply With Quote
