Old 04-22-2003, 10:40 AM   #1
DoriftoSlut
DoriftoSlut's Avatar
DoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to beholdDoriftoSlut is a splendid one to behold
Send a message via AIM to DoriftoSlut
Originally posted by dousan36
yeah i'll get more inf. when i crawled under there and turned everything i was lke "AH i see how that spacer works!!"
i am horrible at described. i'll try and get some vid/pcitures...
You are also horrible at engrish you FOB! i thought that was my job!
Death Before Dishonor.
www.pinkgodzira.com
www.driftalliance.com
DoriftoSlut is offline
Old 04-22-2003, 10:50 AM   #2
Dousan_PG
Dousan_PG's Avatar
haha..yeah mi english sooks. i nede to go dun get edduducat'd.
Aaron
Pink GodziRa
Dousan_PG is offline
Old 04-22-2003, 11:00 AM   #3
sykikchimp
WOW addicted
sykikchimp's Avatar
sykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura aboutsykikchimp has a spectacular aura about
Send a message via AIM to sykikchimp
ROFL.. anyways.. so is the threaded part of the inner tie rod long? I guess the spacer goes into the rack while turning? Seems if the spacer stopped the inner tierod from going in as far then it would reduce the angle of the wheels..
So is the inner rod longer, and the outer rod shorter??
I'm so confused.. I guess I'm just going to have to buy a set to see for myself.. hehe
sykikchimp is offline
Old 04-22-2003, 11:10 AM   #4
Dousan_PG
Dousan_PG's Avatar
wait im typing as i think so its going to be goofy and confusing
right side
steering rack (rods move in and out left and right)
................[tie rod inner here...threads...endlink here
[tie rod inner
---- is steering rack
on this pic is the far right, the part just left of the threads. this hits the steering rack to stop it from turning.
now with spacer
................SPACER[tie rod inner here...threads...endlink here
so now the spacer goes in (past) the steering rack, and then the tie rod inner hits it. so you get another 1/4 inch or so more turning
now with the spacer you cant thread it in as much so youll have toe out, but you fix that (w/ endlinks)
you wont be back at 0 because the inner rods can turn into the rack deeper then before, so that makes the steering longer (more turning/counter/wider..whatever)
does that make sense????????
Aaron
Pink GodziRa
Old 04-22-2003, 11:32 AM   #5
DoriftoSlut
Umm.. Aaron's response does not make sense... Hahaha!
OK, the spacer does go into the rack. therefore, the rack moves MORE until the tie rod joint (stopper) hits the rack. to compensate for the added length, you back off the endlinks an appropriate amount of threads. There is plenty of fore-aft movement so that you do not decreas the steering angle or its capabilities, and there may even be more than stock (we need to get aaron to check this out).
Does this clarify anything? I know exactly what i am trying to say, so if you don't get it, i will try and explain it differently...
www.pinkgodzira.com
Old 04-22-2003, 11:40 AM   #6
Dousan_PG
Dousan_PG's Avatar
u summed up what i tried to explain up there in a few paragraphs!!!
DAMN YOU!!!
yeah spacer goes in so turns more...damn..i'll let doritos explain
(yes i spelled it doritos on purpose)
Aaron
Pink GodziRa
Old 04-22-2003, 11:42 AM   #7
240Dori
240Dori is an unknown quantity at this point
Send a message via AIM to 240Dori
Congrats to all....now only if there were more informative threads like this than all of the garbage that has to be sifted through...not only is a step by step install with pics included but an informative discussion about the improvements it makes over stock..
240Dori is offline
Old 04-22-2003, 11:42 AM   #8
charlie@justdrift
charlie@justdrift's Avatar
charlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond reputecharlie@justdrift has a reputation beyond repute
Send a message via AIM to charlie@justdrift Send a message via Yahoo to charlie@justdrift
good job installing it... i almost lost mine to danny last friday. now
aaron, all u need to do is go top 3rd with high angle so u can use that extra 20% steering on full counter lock.
my friends in japan thinks that the TEIN hard tie rod/end are OEM replacement from another nissan car. thicker than stock S13 but
not as thick as the drift spec spl ones.
charlie@justdrift is offline
Old 04-22-2003, 11:51 AM   #9
Dousan_PG
Dousan_PG's Avatar
3rd gear? I get an alignment tomorrow 9 am. i'll be doing more 3rd gear now that i get rid of that NASTY toe in boo hoo. i hate you bad alignment (changed suspension stuff w/ no time for alignment)
yeah i just read that by VRT. drift spec ones like JIC and another brand that got forwarded to me. check your email.
Aaron
Pink GodziRa
Old 04-22-2003, 02:53 PM   #10
charlie@justdrift
where is it? i wanna see...
Old 04-22-2003, 04:30 PM   #11
sykikchimp
WOW addicted
sykikchimp's Avatar
yes.. I understand now.. VRT's diagram confused me b/c it didn't really look like the spacer was going into the rack..
Thanks Dousan!
Old 04-22-2003, 04:35 PM   #12
Dousan_PG
Dousan_PG's Avatar
cool
i got alignment appointment 9 am sharp tomorrow morning. i'll get some vid/whatever this weekend.
replacing water pump and rad hoses and thermostat so busy weekend er...more like still poor
Aaron
Pink GodziRa
Old 04-25-2003, 07:45 AM   #13
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
so wheres the update? hows the alignment?
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline
Old 04-25-2003, 08:43 AM   #14
Dousan_PG
Dousan_PG's Avatar
oh i forgot haha
well, went well
except my rear toe arm is bent..still got WAY TOO MUCH toe in on the left. so im getting Battle Version adjustable rear arm i think. gotta call alex
anyways.
got it all fixedup
the turning radius. WOW. with the spacer its so much tighther
i was at Jspec and when we left, i parked along the sidewalk. everytime i have to make it a 3 pt turn on the street. not anymore! I cleared the curb w/ LOTS of room!
the spacer is a definate plus and im excited to see how it feels at the track drifting
car's got too many problem:
rear toe
waterpump leaks (replacing this weekend)
hairline crack on the z32tt rotor (grr)
rear coilover adjustment.
cars suck.
Aaron
Pink GodziRa
Old 04-25-2003, 09:41 AM   #15
Steeles
Steeles's Avatar
awsome... *adds tein tie rods to list of suspension stuff to get* I see now Im just gonna wait and get all my suspension stuff and wait to install it all at once.. lol heck with the main seals leaking I may just wait till I can put her down for like a week and do a complete overhaul towards the end of may. now I need money...
Steeles is offline
Old 04-25-2003, 10:12 AM   #16
mrmephistopheles
mrmephistopheles's Avatar
Are we ready to send this to the archive?
mrmephistopheles is offline
Old 04-25-2003, 10:14 AM   #17
Dousan_PG
Dousan_PG's Avatar
yeah i think im done
i hope to get some video or something next time on the next car and we'll add it here. some of my friends might buy it as well
Aaron
Pink GodziRa
Old 04-25-2003, 10:16 AM   #18
Foxcolt
Foxcolt's Avatar
Foxcolt is an unknown quantity at this point
Send a message via AIM to Foxcolt
Can some one post the differences between the tiens and the JIC's/ other drift spec. Or two pictures side by side
Thanks!
Driftec
www.midatlantic240sx.com
Foxcolt is offline
Old 04-25-2003, 10:23 AM   #19
Dousan_PG
Dousan_PG's Avatar
JIC/'drift spec' are FAT and SUPER BEEFY
tein is thicker and stronger then OEM but not close to JIC/'drift spec' type
'drift spec' can take some serious abuse and offtracking im sure hehe...its scary to drop a wheel off the track when you clip an apex, i've done it! sounds...very very scary!
i'll go 'drift spec' later this year im sure (as will a few friends who track alot like me). maybe Uras. hmmm
pics? I have none. check JICs site in Japan and US. maybe search tie rod or hard tie rod on yahoo japan search engine?
Aaron
Pink GodziRa
Old 04-25-2003, 10:42 AM   #20
Foxcolt
Foxcolt's Avatar
Here's a pic of the Jic's.
These are designed to be used with stock of aftermarket tie rod ends i.e. Kazama, correct?
Driftec
Foxcolt is offline
Old 04-25-2003, 10:46 AM   #21
Dousan_PG
Dousan_PG's Avatar
depends on the type of endlink it uses..m14 (s14, tien hard rods r32, etc)
i think s13 is m12 size. so if JIC s13 uses m12 then kazama s13 will work
if JIC uses m14 on both s14 and s13 rods the you need kazama s14 size
we tested the kazama s13 endlink on the tein s13 hard rod and didnt fit!
oh btw, people i saw (and examined closely) the KAZAMA endlinks last night WOW i was so lovin' it!!! very very very very nice!! i love the pillowball joint, perfect for lowered cars and response. ill be getting a set myself later!
Aaron
Pink GodziRa
Old 04-25-2003, 11:14 AM   #22
Steeles
Steeles's Avatar
bish you were supposed to be in on the group buy! got me all excited about them then backed out... lol. all good I need more people in on the rear arms sets get that price down some. mmm more stuff to buy.
Steeles is offline
Old 04-25-2003, 11:17 AM   #23
Dousan_PG
Dousan_PG's Avatar
i would still get them if i ahd the money. my car is going to hell w/ stuff and tire fund is seriously hurting.
i'll get them eventually. after seeing them last night i was very impressed.
got some other suspension goodies going on this weekend and more in 2 weeks and more stuff in a month hehehe...
track fees are hurting a lot. already spent 500 on track fees this year (5 events)
Aaron
Pink GodziRa
Old 04-25-2003, 11:25 AM   #24
Steeles
Steeles's Avatar
hahaha man I wish I had a track I could hit up every weekend! I really would be broke! Think I'll quit going to strip clubs or somethin.. save for a massive overhaul of the car.
Steeles is offline
Old 04-25-2003, 07:12 PM   #25
Halz
Halz's Avatar
Halz is an unknown quantity at this point
What similarities in wheel/tire size, alignment, and other suspension 'stuffs' are there between these cars that have been known to break tie rods?
Halz is offline
Old 04-25-2003, 07:37 PM   #26
Dousan_PG
Dousan_PG's Avatar
they push the car to the limit
drifting or grip
Aaron
Pink GodziRa
Old 04-25-2003, 11:19 PM   #27
Halz
Halz's Avatar
drifting or grip
I don't doubt that.. but I am pretty sure a car with a stock suspension wont be breaking tie rods when fit with grippy tires, and put on the limit
Halz is offline
Old 04-25-2003, 11:38 PM   #28
adey
adey's Avatar
adey is an unknown quantity at this point
Halz - I think it's pretty obvious then -- you allude to it in your last post, almost.
Since coilover springs and valving are stiffer, more stress is placed on other elements of suspension and indeed the whole car, such as tie rods and tension rods.
With soft/stock suspension, it's soft and bouncy, and the shocks absorbs the force... turning it into heat.
You know, it's that equasion that includes Force, Time and Power or something like that. Same amount of power over longer time = less force or some crap. I never was a physicist.
Instagram: @SX180HKG
adey is offline
Old 04-30-2003, 04:07 PM   #29
driftingpanda
driftingpanda's Avatar
Trader Rating: (24)
driftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond reputedriftingpanda has a reputation beyond repute
Feedback Score: 24 reviews
Send a message via AIM to driftingpanda
good stuff aaron! them shiny sticks sure look beefy. i am waiting for my spaghetti in the microwave, so i guess i'll share my humble (and quite possibly very, very wrong) opinions...
first, i seriously doubt the claim for partial elimination of bump steer. bump steer is caused by suspension geometry, and since a strait bar is being replaced by a strait bar, the geometry stays the same and therefore bump steer probability stays the same. i think they may have been refering to the decrease in toe change due to flex in the end link (and/or knuckle joint), rather than the decrease in toe change due to bump steer.
as for the reasons for tie rod failure, i agree that the main causes would include harsh driving stress and also added strain due to the lack of suspension movement caused by other aftermarket suspension pieces, however, since steel has a rather high stress endurance limit, i would also venture to guess that failure could be caused by material damage due to impact loading (i.e. letting the natural countersteer "slam" while attempting drifts, or a muscular leprechaun tangentially kicking a fully steered steering wheel repeatedly). all this, of course, does not include obvious reasons such as damage from rocks/curbs/etc.
to Dousan and Adey: by the way, i think i may have figured out the mysterious proper drift toe set up, it goes against a lot of conventional theories, and it is highly relative to the other setup specs of the car... i'll email you guys about it i guess.
oops. the spaghetti is ready. or should i say... speghetto... no meat.
danny
PM me about limited edition Pink GodziRa Sticker packages!
driftingpanda is offline
Old 04-30-2003, 06:09 PM   #30
Halz
Halz's Avatar
I was thinking of tie rod failure more along the lines of 1) the car being 'too low', placing the arms at a stupid angle when they're operating 2) spacers on the front wheels increasing the car's track, leveraging heavier loads on the bearing and therefore steering system 3) camber, caster, SAI being too far out of wack could also further increase loads on the system
Halz is offline
