Old 09-18-2011, 06:14 PM   #31
harrypotter
harrypotter is an unknown quantity at this point
Maybe I suck at this! Here is picture from inside the car. You can see the white coector with a blue stripe on it. If that is the one you are talking about, it goes farther up and behind the dash.
http://imageshack.us/photo/my-images/842/zilviasig.jpg/
harrypotter is offline   Reply With Quote
Old 09-18-2011, 06:28 PM   #32
Mrpopo
Mrpopo's Avatar
Mrpopo is an unknown quantity at this point
It goes over the steering column. Ignition switch and all. Pull the dash it's not that hard.
Mrpopo is offline   Reply With Quote
Old 09-18-2011, 06:44 PM   #33
harrypotter
I know pulling the dash is not that hard, just trying to avoid it if I can. Maybe there is something different about my car. It's a 1990 sohc
Old 09-18-2011, 06:56 PM   #34
Trap Star
Trap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant futureTrap Star has a brilliant future
Send a message via AIM to Trap Star
I would just pull the dash man, it will make your life a hell of a lot easier.
86 300zx/90 240sx/97 240sx/96 LS400/03 350z
-Shake N' Break Racing-
Trap Star is offline   Reply With Quote
Old 09-18-2011, 07:05 PM   #35
harrypotter
I just pulled the harness out this way. Now just need to find a spot to make a hole and a path to route it.
Edit: mow back to the wire tuck thread for examples.
Old 09-18-2011, 08:02 PM   #36
Shift-240
Shift-240 is an unknown quantity at this point
Harrypotter, the front chassis harness only has that main plug, a couple plugs that go to the fuse box, clutch bottun, then extends to the ignition.
It is much easier to pull the dash and take it out but it can be done without removing it.
Shift-240 is offline   Reply With Quote
Old 09-18-2011, 08:20 PM   #37
AdrenalineS14
AdrenalineS14's Avatar
AdrenalineS14 is an unknown quantity at this point
Originally Posted by Options13 View Post
i tucked my harness 2 years ago when i had 17's and did a shitty job, so here i am REDOING it..
DON"T do it like that, unless you want to re-pull fender and re-tuck in the future, when you get big ass wheels in the front.
TODAY I GOT DOWN TO IT...
STEP 1 - REMOVE FENDER
STEP 2- look at the saggy ass harness rubbing on your 18" wheelzzzzzz, actually had to repair some damage, tire started rubbing through half the harness, my car actually shorted out pulling out of autozone in the middle of main st, fuck that never again..
STEP 3- remove plastic tube shielding around harness.
STEP 4- THIS is what i wish i would of knew back when i did it the first time, but if you cut out a slot, the harness tucks perfectly.
STEP 5- ZIP TIE THE FUCKER to random holes, like this
then bend the lip up to act as a barrier between wheel and harness..
STEP 6- repeat to other side of baller lambo aka s13
STEP 7- PUT THAT ISH back together and drive it how its supposed to be driven...
by parking
what wheels are these???
AdrenalineS14 is offline   Reply With Quote
Old 09-18-2011, 08:23 PM   #38
Newtypex
Newtypex is an unknown quantity at this point
No fusebox!
Newtypex is offline   Reply With Quote
Old 09-18-2011, 08:24 PM   #39
Newtypex
Tuck everything!
Old 09-18-2011, 08:31 PM   #40
Irresistible
Irresistible's Avatar
Irresistible is an unknown quantity at this point
I like how everyone always argues over the "best" way to do it... Just do whatever works. I drilled and cut the little triangle piece on my S14 (if you have one you'll know what I'm talking about if you've ever had your fender off). Fixed some wires, threw it through the hole, and rewelded the cut. Then proceeded to make a skid plate bolted in with self driling screws. Works? Yes. Requires a lot of time cutting and extending wires? No.
GLEAM//★☆Street Dancer☆★
IG: streetdncr // tumblr: steve-strtdncr
Irresistible is offline   Reply With Quote
Old 09-18-2011, 09:00 PM   #41
fallen soul
fallen soul's Avatar
fallen soul has made poor choicesfallen soul has made poor choicesfallen soul has made poor choicesfallen soul has made poor choicesfallen soul has made poor choicesfallen soul has made poor choices
Pic of this?????
fallen soul is offline   Reply With Quote
Old 09-18-2011, 09:13 PM   #42
Luvs2slide
Luvs2slide's Avatar
Trader Rating: (81)
Luvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of lightLuvs2slide is a glorious beacon of light
Feedback Score: 81 reviews
Relocating it through the engine bay is easy. The inside wiring and box that needs to come out will NOT fit through the stock triangle opening. All you gotta do is slot that triangle hole and make it into a square. Done this on like 4 S13s and a couple of 14s.
However, once its routed by the strut tower, its a good idea to unravel the electric tape and insulation to try and flatten the wires out, then re-tape everything so the hood can clear it better. Not necessary, but will help greatly since the bundle of wires is like over an inch big.
Luvs2slide is offline   Reply With Quote
Old 09-18-2011, 09:29 PM   #43
Options13
Options13's Avatar
Trader Rating: (43)
Options13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the roughOptions13 is a jewel in the rough
Feedback Score: 43 reviews
hmmm to the people who think the zipties are gonna break? if anything, the tire will eat through my harness before a ziptie breaks, there is no way unless i seriously wreck that my tire will even come in contact with a ziptie
wheels are xxr 526! baller on a budget!! haha
Drift team page
www.facebook.com/savageimpression
Options13 is offline   Reply With Quote
Old 09-18-2011, 09:34 PM   #44
om3ga
om3ga's Avatar
om3ga is an unknown quantity at this point
I actually don't like cutting those seams, i thought about that initially but ended up putting hoses there instead.
There is a metal plate shaped and welded on mine to protect the vertical section of the harness as well as the rubber plug that keeps water/dirt from getting into the cabin right behind the fuse box.
Here are some pics.
There is a small gap between the plate and fender well large enough for water to drain.
om3ga is offline   Reply With Quote
Old 09-18-2011, 09:34 PM   #45
Phatsilvia
Phatsilvia is an unknown quantity at this point
this is my engine bay, extended and tucked every wire i could see and hose and line.
Phatsilvia is offline   Reply With Quote
Old 09-18-2011, 09:39 PM   #46
yomisiu
yomisiu's Avatar
yomisiu is making a name for him/her selfyomisiu is making a name for him/her selfyomisiu is making a name for him/her self
that looks radical
yomisiu is offline   Reply With Quote
Old 09-18-2011, 09:43 PM   #47
Options13
Options13's Avatar
Trader Rating: (43)
holy fuck!
Drift team page
Old 09-18-2011, 10:20 PM   #48
Mrpopo
Mrpopo's Avatar
Very nice indeed
Old 09-18-2011, 10:47 PM   #49
kalypso123
(ノಠ益ಠ)ノ彡
wtf IS that intercooler
Old 09-18-2011, 10:54 PM   #50
Options13
Options13's Avatar
Trader Rating: (43)
yeah lol, is that even an intercooler or some plasma ice box time traveler that teleports your air to Antarctica real quick to get it ice cold, looks like your gonna have some excellent throttle response.
Drift team page
Old 09-18-2011, 11:07 PM   #51
Irresistible
Originally Posted by fallen soul View Post
Pic of this?????
Didn't take any while the fender was off, but I'll try to snap one tomorrow somehow.
Old 09-18-2011, 11:09 PM   #52
Newtypex
Your engine bay is still lumpy >.<
Old 09-19-2011, 08:48 AM   #53
Phatsilvia
its an air to water intercooler, it has a heat exchanger(kinda like front mount) mounted in the front that coolant goes threw and gets cooled by the air and then the cold coolant goes threw the intercooler and cools the air that is going into the intake and then there is a water tank that stores all the cold coolant waiting to get cycled threw the intercooler. its way more efficient than the conventional front mount, the turbo side gets so hot you can hardly touch it and after it goes threw that tiny intercooler the intake side is cold, and thats after driving the car after several hours.
Old 09-19-2011, 09:07 AM   #54
TheRealSy90
TheRealSy90's Avatar
I routed mine through the engine bay after pulling the white plug and running it out of the firewall, just had to enlarge the triangular hole a bit. No cutting of wires required.
Old 09-19-2011, 09:17 AM   #55
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
i like this idea,... i just would have made it a little more removeable friendly
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 09-19-2011, 09:31 AM   #56
n8RPS13
n8RPS13's Avatar
Trader Rating: (22)
n8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of lightn8RPS13 is a glorious beacon of light
Feedback Score: 22 reviews
Wow the OP did it just like how Martin from PBM showed me how to do it...so I think if it works for them on the S15 it should be ok for any of us...just saying!
WASTED I AM!
n8RPS13 is offline   Reply With Quote
Old 09-29-2011, 08:13 PM   #57
MaRshMaLLow
MaRshMaLLow's Avatar
MaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond reputeMaRshMaLLow has a reputation beyond repute
Send a message via AIM to MaRshMaLLow Send a message via Yahoo to MaRshMaLLow
i tucked by shiiitt along the rails ....
Keeping It Real Since 1985
MaRshMaLLow is offline   Reply With Quote
Old 10-17-2011, 01:45 PM   #58
longbeachstateofmind
longbeachstateofmind is an unknown quantity at this point
sir that is a bad ass set up. where did you get it
longbeachstateofmind is offline   Reply With Quote
Old 10-17-2011, 01:57 PM   #59
whiterps13
whiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to behold
He purchased it at the "Dumb-Ass Questions" store.
whiterps13 is offline   Reply With Quote
Old 10-17-2011, 02:12 PM   #60
1] it wasnt something for you to reply to.
2] was i talking to you?
3] why waste your time to reply?
