Old 07-01-2012, 08:02 AM   #31
omgRWDgoodness!
omgRWDgoodness!'s Avatar
Trader Rating: (48)
omgRWDgoodness! is an unknown quantity at this point
Feedback Score: 48 reviews
Sounds like the whole A/C Vert thing depends on whether the base model coupe being used for the conversion originally came with it or not.
omgRWDgoodness! is offline   Reply With Quote
Old 07-01-2012, 08:18 PM   #32
Fred Allen Burge
Fred Allen Burge's Avatar
Fred Allen Burge is an unknown quantity at this point
If you are going for a tucked bay, that lowest hole you welded is where I run all my engine wiring and clutch line through. It makes the bay look cleaner, since the motor hides it from view.
Thanks, I may redo that part. I wonder if the LS1 wiring harness will play nice with the lower hole?
Silvia, built 5.3 turbo, 4l80e, 9.8@142
Fred Allen Burge is offline   Reply With Quote
Old 07-01-2012, 09:03 PM   #33
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
Yes, it works. But the ecu plugs wont fit through it. You either cut the hole bigger or feed the harness through from the inside.
C. Anderson is offline   Reply With Quote
Old 07-02-2012, 08:07 AM   #34
Fred Allen Burge
Great, thanks!
