alright finally an update..
Ive got some stuff back in the bay. Finalized how the brake lines will run. As per this entire build, my first time dealing with flaring and bending brake lines. I like how it came out, and most important it takes care of the hideous hardlines up on the firewall...(brake booster is another story i havent found a good solution for that) ![]() I also ave those extra large oil filter. took my summit relocation block to vatozone and tried a bunch of filters till i found a larger one that fit. you can also see the connection in rear brake lines, slightly altered but from there back its stock. the fuel hard lines will remain the same as im going to run the oem fuel filter holder. ![]() and the lines running through interior. and the 3 pedals! got a legit ma nual brake pedal too. ![]() i undercoated my brake booster, love me some texture ![]() heres an oil filter comparison. the left is for a sentra w/ sr20. they couldnt tell me what the K&N was for but its much larger. ![]() since i did a 5 speed conversion i had to piece junk together anyways. decide to do something about the clutch line also. got an isis line and changed up the fitting for the slave end. straight line master to clutch no silly damper. ![]() ![]() i also knoecked out the rear bushings one day. knuckles and RLCA. ![]()
@UpshiftEngineering |
#2 | |
I know everybody likes pictures...
Brake master, clutch, and PS res. are all in place, perfect spot top right for PS. That throttle cable isn't going to cut it... Wish I could recall who made that heat shield. few years back some guy on here, its sweet. ![]() Picked up this AN fitting, put it in the lathe, turned down the hex portion. . ![]() Drilled a hole in the waterneck and bam got that sucker welded in. also tapped it for aftermarket water temp. ![]() swapped out the steering column bushing ![]() New rack bushings, also made up some new lines since the others were beat to all hell. We can also note at this point there's no motor....back out for paint! ![]() During mockup I didn't have a clutch or flywheel in there. and only a few bell-housing bolts, so had to take care of that This is an old ACT clutch of mine, its got some life left so just gonna rock it till it dies. HD pressure plate, 6 puck un-sprung. ![]() ![]() I have seen it a couple times before and thought the idea of low mount PS pump was cool so one day I thought I'd fab up something. Took a couple tries but its pretty sturdy. Im not sure how much stress it will be seeing..? ![]() Just for fun ![]() I'll leave you guys with this...makeshift paint booth. 'Merica ![]()
@UpshiftEngineering Last edited by KoukiMonsta; 02-13-2015 at 06:29 PM.. |
#5 |
![]() Join Date: Jun 2010
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 4 reviews
Nice build man! Coming along nicely. I was in the same boat as you, never touched a welder and one day I just picked it up. What I've found best when learning, cut a practice piece and do some welds on it, play with the settings some till you get a nice weld. I've learned to run the welder hotter to get a nice burn in but if you do make sure you move the bead fast
#6 | |
#8 | |
I used the mounting points for the AC compressor. the top one is a pivot point and the lower to tension the belt simply using a turnbuckle. also note sweet XRP fitting from Toby. Re-did the high pressure PS line with xrp stuff. its great quality! ![]() ![]() ![]() please dont hate my horid welding ![]() ![]() Hope that gives some insight to anyone wanting to attempt something like this. thanks for reading!
#9 |
I am gonna leave this here...updates soon, been super busy with not car junk
color is Eastwood- hot rod black. i was going for a bit more flat color as to let the engine itself 'pop' more. first time using a real paint gun id say i did a fair enough job. ![]()
#13 | |
thank you sir
but as i stated in the beginnning this whole build is a massive learning process for me, before this all i did was bolt on mods. but thanks for the kind words brotha! haha, right on
#15 |
Get ready ladies. I got some sweet stuff on the way!
#18 | |
I had 5 of 6 flares done by a shop with hydraulic flaring equipment. I have used the cheap tool from summit before, and used it for the sixth flare. Though it was easier for me to just have them done. That said the flare I did seems to hold fluid. Thanks!
#20 |
So the motor is in! for good....Ideally. Not mant pics of the process since i had previously bolted everything up. was pretty stright forward slapping everything back together. check the photos, there always the best part.
![]() ![]() ![]() ![]() ![]() ![]() stay tuned, suspensions going on and wiring soon after.
#22 |
Not sure yet honestly.
This build isn't going anywhere fast.. I did my best to enlarge the front wheel wells to the 'max' so down the road I can put some serious rubber in that bitch. And stay low.
#23 |
Wow, engine bay looks great! Awesome job on that. Can I ask how you are routing your PS reservoir to the pump with it located in that position? And(Forgive me if I over read this) are you using low pressure hose/clamps or AN fittings?
#27 | |
The car will always be red, vc I imagine will change at some point. Thanks for the words everyone. Helps keep motivation going on this sucker. I got an update coming soon!
#28 |
Well the next step was to get this thing back on four wheels and rolling for the first time in a year. So thats exactly what i did.
can you fucking say MONSTER TRUCK, but so sweet to see it roll outside and catch some rays. finished up a bunch of engine bay stuff ![]() ![]() mocked up some stuff for fun ![]() ![]() brackets for my super corroded rad ![]() stock arms, ES bushings, z32 hubs, stock calipers, drilled/slotted rotors, baller bolts for entire subframe...for now ![]() So now its on the ground...well 5 miles above it but she rolls. as i said before gotta wire her up. now wiring sucks i will tell you so its kinda a procrastination thing. thanks for lookin
#29 |
Ive been doing work. hope you fuckers like it
So i want to put the ecu, fuses, relays etc in a location that allows for easy access. to swap fuses, test shit, check ecu codes ect. so the glovebox seemed like a brilliant spot for this, hidden but easily opened. so i got this setup going on ![]() blue sea 12 fuse, its awesome ![]() ditching all the dummy lights and other bs ![]() So at this point ive spent a couple months looking over the fsm wiring diagrams trying to get a solid grasp and now i really understand them. as always in this build, this is my first time. and i wil be entirely re doing everything. this is only going to have "racecar" wiring no accessories. ![]() decided to go a little overkill on relays, i like the idea of seperati ng things so its easy to determine the circuit at fault in the case of issues down the road...of course inevitable. ![]() i dont really have many pics from the engine harness creation. heres a process pic ![]() ![]() wiring for tail lights and fuel. cut tons of stuff from the rear ![]() made this quick panel to get wires run. those switches are IGN and fuel ![]() stay tuned, this thing will be running soon
#30 |
![]() Join Date: Jan 2010
![]() ![]() ![]() ![]() Feedback Score: 10 reviews
kick ass build!!
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
