Old 12-14-2013, 05:22 PM   #31
mechanicalmoron
mechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nicemechanicalmoron is just really nice
Originally Posted by Jerflem1387 View Post
Once again if you don't know what your talking about don't post. It's not physically impossible if you knew anything about a motor you would know that in order to remove the upper timing chain the car needs to be at TDC (that's top dead center for your information) and in order to do that you need to spin the crank. The lower timing chain I'm assuming was cracked and when I was turning the crank it broke so really not impossible. And also I have owned the car for a year and a half and it was my daily driver the whole time. If you have a question on the car pm me rather then posting your stupidity here.
Sent from my HTC One using Tapatalk
Wether you spin the motor with the crank bolt or the pistons, the timing chain's JOB is to be able to turn the cams without breaking. Turning it by hand would be the most gentile thing possible to it. (unless someone was a retard and turned it from a cam, instead of the crank. Then it might be possible. Or it might rip out the idler or something)
mechanicalmoron is offline   Reply With Quote
Old 12-14-2013, 08:17 PM   #32
P-Funk alot
P-Funk alot's Avatar
P-Funk alot is an unknown quantity at this point
Send a message via Yahoo to P-Funk alot
car looks great did a leak down already and everything checks out this far. thanks for car and sorry I burned so much of your time today
P-Funk alot is offline   Reply With Quote
