#31 | |
AFC #1
![]() Join Date: Oct 2003
#32 |
timing was righ and the flames are gone thanks, but i just need to do the intake cleaning thing, how long until i see a dif are will ir be like a mirical and just be gona once i put it in there
1990 Acura Integra- Deer (mother fucker) 1993 240sx- still tickin |
#33 | |
![]() Join Date: Dec 2002
GL
Don't mess with my monkey...he's loaded. |
#34 |
you can always just loosen the idle adjuster too. sure cleaning it is good but if you want to get to the parts store to get intake cleaner without youre car dieing at stop lights just loosen the screw.
#36 |
no, dont use for superchared or turbocharged engines, i just did it asnd used half a can and didnt do anything. would the timing have anythign to do wiht it, i never got it timed i just put my new exhause on there thinking it might be no back pressure?
#37 | ||
You could try using the WHOLE can, maybe yours is just really dirty. Did you put the cleaner in the right hose? The second one from the left, the bigger of the two. And Drifter.....could you please take the extra 30 seconds and make your posts more gramatically correct? I'm having a hard time understanding you. Thanks. ![]()
#38 |
I would like to post that I tried this, and it hasn't realy fixed my stumbling idle. I honestly am at a loss here.
I have new spark plugs, cleaned intake & manifold (didn't take it apart, just with the intake cleaner), adjusted timing so its perfect. I followed directions here and cleaned that tube through, but I dont know. Anyone have any ideas? It's a 96 btw, and it doesn't die at idle, it just stumbles around causing the car to shake lightly, its just annoying really. It accelerates beautifully, its just when its sitting still. |
#39 |
I found another problem about a week ago, there's a vaccumm line that plugs into the underside of the throttle body. It's only about 5 inches long but it goes to the idle control system. Replace that hose with a new piece from autozone. I found mine to be plugged up at the elbow portion. I replaced it and voila!! no more stumbling idle. Worth a try.
Also when you pull it out, just blow into it. How much air is going through? Mine was completely clogged. I'm currently in the process of changing out ALL the old vaccumm line from my engine bay, there's alot... ![]()
#40 | |
#41 |
no...
Just go to the throttle body and feel the underside of it near the butterfly. You can feel and see the hose. Just work that little shit off and go get some new hose. Best to do it while the engine is cold.
#42 | |
I really should just take apart the manifold so I can access all the EGR stuff behind it to make sure that's all ok, as well as other vacuum lines. But I'm to busy lately ![]() |
#43 |
This would work on a SOHC also. Just make sure your A/C is off and the car is warmed up first. I imagine that would apply to the DOHC as well. You have 3 idle control valves connected to that hose you're spraying cleaner in. They are:
Air Regulator: Just for cold start idle. When the Fuel Pump comes on so does this valve. When it heats itself up the whole way it closes the valve. FICD: When your A/C compressor kicks on this valve opens. AAC: This is the valve you're most likely trying to clean. This is the PWM valve your ECU controls to maintain idle RPM. There's a spring in this part of the assembly that you need to keep fairly clean. Hope this helped someone! |
#45 |
Oh, and the hoses that connect to the Throttle body on the SOHC are coolant hoses. I can't speak for the DOHC, but I would think they are the same thing. I've been told it's so the throttle body doesn't freeze up during cold weather.
#46 |
I find it to clean the AICV better if I just take mine off, and clean it with carb cleaner, re-gasket and re-install. THat way I can really get in there and spray carb cleaner up close and get rid of everything. sometimes I let it soak in there for 10 -15 minutes.
#47 | |
Wish i had a pic......
#48 |
Baaaahhhh.
Well after a day or two of fooling around and tweaking everything, it turned out to be my cylinder 4 spark plug. My friend I put this car together, and he was responsbile for the spark plugs at the time. I was cleaning the throttle body while he installed the plugs. Apparently the 4th one got bent (so the gap was screwed up) and he didnt notice and installed it anyways, hahaha. Thus causing my shaking and stumbling at idle. Note: he also installed the wrong brand, but that's another story. So, I have NGK V-Power coppers in there now and it's haulin ass and idling perfect! ![]() |
#49 | |
Drunk posting FTW! ![]() |
#50 | |
But first be sure you have your timing set at 20 degrees BTDC (KADE), THEN proceed to set idle. If your timing is off, it will affect your idle.
#51 |
I have a problem with my IACV but its the opposite of everyone. The car idles ok (rough b/c of cams) but my problem is that the car stays at wide open throttle when I put the clutch in to shift gears. If I rev to 5K rpm or more air is still rushing in the engine through the IACV because it is still open and the car bounces of the rev limiter. I just got the car back from the mechanic and he says it must be the IACV because its HUGE in the SR compared to other engines and thats the only place besides the throttle where air can get in. No vacuum leaks.
So is it possible that the IACV is so dirty that it is actually sticking open instead of shut? I searched and it no one else seems to have this problem.
#52 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
wait, cant all this hassel of pulling tubes and holding up the throttle be taken away by taking off the filter on the intake, have a friend hold the revs at like 2k and just spray the into the now wide open intake?
#53 |
yeah sure if you like wasting 3 cans of cleaner to do the job that should take only one.
You're getting a more concentrated dose of cleaner if you pull the IACV intake tube and spray in there. It's not that hard really, should take LESS time than pulling the intake filter off, plus you're not getting cleaner on your MAF and possibly damaging it. Those things are touchy.
#54 | |
#55 |
![]() Join Date: Sep 2004
![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 1 reviews
The small line to the left of it, what does it go to? The nipple from my intake broke off and I can't hook that line up. Should I plug the line, leave it free, do I need to get a new intake now?
#59 |
![]() Join Date: Sep 2005
The house that you put stuff in to clean the IACV? Its one of the like 2 big hoses that goes into the stock intake. One goes to your VC, the other goes to your IACV
#60 |
sorry to bring up this tread again, but can some1 verify which hose it is? theres 2 hose on the intake, is it the small one or big one?
a picture if possible thanks
Tooo Sloooow 4 youuuu! |
