Old 09-29-2020, 05:37 AM   #571
PoorMans180SX
PoorMans180SX's Avatar
Mazworx paperwork says 65ft/lbs. Seems light to me, but they should know what they're doing? IDK.
I I bought the 20mm extended shanks for the gktech arms for kicks and gigs and experimentation purposes. They don't fit with my 17in wheels unfortunately, but it does look like I can nearly fit a 265 up front for roadcourse work. I'm not sure how much of that this car will actually see, but it's fun to mess around with.
Definitely seems like the roll center would be on point with the car down another 1.5in.
But alas, I don't think I'll run the 20mm shanks for drifting.
Got my vibrant black muffler in, should make for a mellow tone. Gotta keep the street cars classy, ya know?
And finally got this in! EFR 6258 if you haven't been reading.
Old 10-03-2020, 12:17 PM   #572
S13project
S13project's Avatar
S13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of lightS13project is a glorious beacon of light
Get ready for instant spool with the 6258. So quick!
S13project is offline   Reply With Quote
Old 10-05-2020, 05:29 AM   #573
PoorMans180SX
I'm pumped for it!
Doing a little mock assembly I've figured out a few things. One is that the rear inner stud on the T25 is going to need to be shorted a little bit. I bought flying miata inconel studs, so that should be interesting.
Secondly is that the water fittings need to be re-arranged so that the in is on bottom and the out is on top. This helps with cooling.
Here's a little mockup.
One of the last few pieces, a Taarks oil filter relocation block.
And I bought S14 lower control arms, which are a tad bit longer in the tension rod section, so I think I'm just going to redrill my tension rod brackets and run them.
Old 10-05-2020, 11:42 AM   #574
S13project
S13project's Avatar
Originally Posted by PoorMans180SX View Post
I'm pumped for it!
I went with the Stage8 locking hardware for the turbo, was a bit tricky on one stud but no interference.
Good info about the cooling lines. Never though it out before. Possible FullRace clocked it for SR setup since I purchased the full kit from them.
Old 10-05-2020, 11:52 AM   #575
PoorMans180SX
Yeah I have the Stage 8 as well.
Here's a good article with some data on why thermal siphoning is important.
https://www.garrettmotion.com/racing...or-your-turbo/
Old 10-05-2020, 01:40 PM   #576
TheRealSy90
TheRealSy90's Avatar
Hey you got the good hardware me too.
Such a good signature.
Old 10-05-2020, 01:45 PM   #577
IIIXziuR
IIIXziuR's Avatar
Trader Rating: (22)
IIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfectionIIIXziuR is close to perfection
Feedback Score: 22 reviews
Very nice updates. For a Poor Man's S13, this is coming together very fancy hehe.
You always provide with high quality content and very informative posts, my man.
IIIXziuR is offline   Reply With Quote
Old 10-05-2020, 04:56 PM   #578
e30gangsta
e30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to alle30gangsta is a name known to all
" Secondly is that the water fittings need to be re-arranged so that the in is on bottom and the out is on top. This helps with cooling. "
Could you please elaborate on this? As long as the cartridge is being cooled, what difference does it matter on which side it comes through? Just trying to learn/understand more. I mean this in the most non dickhead way I'm just honestly curious.
Need aftermarket parts? PM or DM me competitive pricing! IG@S13Guille
e30gangsta is offline   Reply With Quote
Old 10-05-2020, 05:33 PM   #579
silviaks2nr
silviaks2nr's Avatar
that turbo/mani combo is sweeeet
'98 240sx 5spd
kouki 2jz t56 swap build
Old 10-06-2020, 05:56 AM   #580
PoorMans180SX
Only found it because you posted about it, thanks!
Haha yeah, it's only taken me 15 years to get to this point haha. Thanks man, I try to contribute where I can, I've learned so much from this site.
Absolutely. It's not about which side it comes through, its about the inlet (cool water) being on the bottom, and the outlet (hot water) coming out from the top. This contributes to the thermal siphoning effect and naturally pulls cool water in as the hot water moves out the top, even after the engine is shut off. The Garrett article I posted above explains in more detail. On the EFR, there are four ports, two on each side. Because the wastegate bracket is kind of in the way on one side, it makes sense to move the inlet to the bottom on that side, and have the outlet be the top port on the other side. Hopefully looking at the pictures this makes sense.
Thanks man, I'm definitely geeked on it and feel very fortunate to own such functional, beautiful hardware.
On another note, this came in:
Construction looks high quality. I've gotta pull the front apart again and get all the new parts in there, hopefully this is the last time for a while haha. I also signed up for a drift event on the 17th, so I've really got to get moving here!
Old 10-06-2020, 09:23 AM   #581
e30gangsta
I'm blind and completely missed the link on your post above. My apologies and thank you for the response. Guess I have some things to change.
Old 10-06-2020, 02:27 PM   #582
Fuglychuki91
Fuglychuki91 is on a distinguished road
Halloween bash at autocity?
Fuglychuki91 is offline   Reply With Quote
Old 10-12-2020, 06:29 AM   #583
PoorMans180SX
Yup, but car's not going to be done in time. See below. I'll be driving Forrest's car.
So previous damage to the block deck means this block needs to be sleeved. Kinda frustrated as it seems like the machine shop should have caught this before they went ahead and did everything. Oh well. Might have found a solution that I'll be exploring today.
Old 10-12-2020, 07:55 AM   #584
S14rebuild
How did that damage occur?
I had rot on my sleeves from years sitn with shitty coolant..the shop recommended sleeves, but i opted to source a virgin block
Old 10-12-2020, 07:59 AM   #585
PoorMans180SX
Most likely detonation. Might have even blown a headgasket or destroyed itself when it was stock block, or after it was "built". It's impossible to tell.
Old 10-12-2020, 08:35 AM   #586
S14rebuild
Dam dissapointing...suprised the shop didnt catch this...idk how well u know that machine shop but looks a mess between this and the line bore.... id be co cered with the work done
Old 10-12-2020, 08:40 AM   #587
PoorMans180SX
I did figure out that the main bearing clearance is .00244", which is loose but not out of running ability. I would have ran it and experimented with oil pressure with 5w50 and 10w60 oils.
The good news is that I've decided this engine will eventually go in my other car, so it will serve a purpose at some point.
Old 10-12-2020, 08:44 AM   #588
S14rebuild
Ive always ran 20w50 on my sr...acually what saved it from exploding itself lol
What would u recommend for oil weight? Lookn at 10w30 or would 20w50 be fine again.
Bearing specs are within oem specs
Old 10-12-2020, 12:39 PM   #589
PoorMans180SX
I recommend 5w40 for engines that haven't been opened up.
Old 10-13-2020, 05:37 AM   #590
PoorMans180SX
A wild 2.3 stroker appears!
Old 10-13-2020, 07:19 AM   #591
S14rebuild
Welcome to my world!
I went with the tomei stroker kit!
Old 10-13-2020, 11:38 AM   #592
Fuglychuki91
Nice! I saw this block up fs on fb marketplace I think. That?s awesome Forrest is going to let you rip. He was just at my garage this past Thursday to drop off something to me and also said I could rip his car at auto city lol. It?s so funny how he explains he doesn?t care about his car and he can?t blow it up hahaha. I think I may take it for some laps but it?ll be late in the day because I work that Saturday
Old 10-13-2020, 07:47 PM   #593
PoorMans180SX
Got this thing for a crazy deal. Now my turbo is borderline too small, but oh well haha. Should make a very rally-car-esk powerband.
Old 10-14-2020, 12:46 AM   #594
S13project
S13project's Avatar
Running 2.2L with the 6758 and its super linear. Honestly kind of miss the lag kick, but I do love the instant boost at nearly any RPM. Low boost and 110 I was hitting 420tq. Am curious to see your 2.3L scream once its all buttoned up.
Old 10-14-2020, 04:17 AM   #595
S14rebuild
That oil lookn milkshakey
Old 10-14-2020, 05:38 AM   #596
PoorMans180SX
Wow, what's "Low boost" for you? I have the high boost canister that's minimum is 17psi.
Been sitting for 2-3 years, so no surprise there.
Old 10-14-2020, 08:04 AM   #597
S14rebuild
Ahhh gotcha was wordern if it had todo with the tear down...excited for this build even more!
Old 10-20-2020, 12:19 AM   #598
S13project
S13project's Avatar
Am running 18-19psi.....well I was when it made 430whp/420tq, The head was sent out for porting and new valves along with solid lifters. Still finishing up rest of the refresh on the car. Eventually will get around to tossing it on a dyno
Old 10-25-2020, 08:04 PM   #599
PoorMans180SX
Drove my friends S13 last weekend. It was a ton of fun sending the NA KA hard in third.
More updates tomorrow.
Old 10-26-2020, 05:36 AM   #600
PoorMans180SX
So tore the shortblock down this weekend. Luckily I did, once again, as some debris had gone through the engine and scored the main bearings.
You can see all the crap imbedded in the bearing:
Thrust bearings totally destroyed.
Luckily the crank took it like a champ and just needed a good polish.
There's some light scuffing on the cylinder walls and pistons, looks like just not quite enough piston to wall clearance, so I'll have this thing honed and skimmed.
JE 10:1 pistons with upgraded pins are pretty cool.
