12-12-2016, 11:37 AM | #6511 | |
12-12-2016, 12:15 PM | #6512 | |
I have the exact same setup! cept it's going into a sc400
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
12-12-2016, 02:33 PM | #6513 | |
I've heard good things about Wiring Specialties so I might go with their harness. Also you should look into the ECU Masters piggy back. Looks really nice for around $500 |
12-13-2016, 05:36 PM | #6514 | |
12-13-2016, 07:12 PM | #6515 |
What are you even asking? If you replace the DBW TB with a DBC will the motor be in limp mode? Yes Can you run an aftermarket plenum with a DBW TB? Yes... Will you need an aftermarket ECU to do this? Yes
'98 Kouki Build in Progress '10 Subaru Legacy 2.5GT |
12-14-2016, 04:56 AM | #6516 |
The mechanic swapped all the first gen 1jz throttle body , manifold and plenum to my car and he believes that they are interchangeable with no limp mode issue as he did it on many cars before .unfortunately i can't convince him and he want me to buy manual transmission .I wonder why i can not keep stock 2jz throttle body and auto tranny in my car and don't have these issues .
12-19-2016, 09:57 AM | #6517 |
I tried this and they do not fit. I decided on cheap altima twin puller fans. They blow very hard. You have to trim the shroud some and you have to notch the radiator top support some, as has been discussed in this thread.
12-19-2016, 10:24 PM | #6518 | |
You can keep stock 2j throttle body and auto tranny with no limp mode issues... If your mechanic says otherwise, time to find a new mechanic lol
01-04-2017, 09:10 PM | #6520 |
1JZ swap
Hey I'm doing a 1J to S14 kouki swap this thread is incredible!
the biggest question I have is; I'm using a T56 6 speed and I'm getting a clutch/flywheel/bellhousing adapter package from a local JZ tuner, but with this combo and normal mounts will the shifter come up too far forward like normal T56 swaps? and does anyone know an off the shelf shifter that will work? |
01-08-2017, 08:46 AM | #6521 |
Sikky has an adapter that should work. Of course you'll have to measure just to be sure. Post back in here with your findings
01-09-2017, 10:33 AM | #6523 |
Whats up guys. I just started pulling apart my aristo 2jzgte vvti apart that I got from an importer for maintenance before putting it in the car. Is it common to have the spark plug valley filled with oil? I'm guessing the valve cover gasket leaks into the spark plug valley over time? Freaked me out for a second because the rest of the motor is pretty clean.
Also in the rear most sparkplug hole it was filled with a aqua blue watery liquid. Anybody have a clue what that could be? Coolant that came out of the water pump was red so it's not coolant. Thanks |
01-09-2017, 04:42 PM | #6524 | |
Need pics.
01-10-2017, 05:35 PM | #6525 |
Does anyone know what size/ thread pitch the S14 clutch master cylinder is ? I never had a stock master and I need to get an adapter for the wilwood I bought.
The clutch line I purchased a few months ago is from R154 slave to stock S14 CMC
95' SE slick 3.0L 2JZGTE/R154/APU,96' SE sunroof KA24DE , 12' MS3 |
01-10-2017, 10:25 PM | #6526 |
I'm aiming for 550whp from my 1JZ on E85, it's only done about 80,000 kms (50,000miles) should I be going with a new head gasket? thought I could save some money and stay with the OEM one
01-17-2017, 07:54 PM | #6529 |
That's how my 1J came from the importer when it came from the importer too and I was also freaked out. I'm guessing it's just from shipping or something. Maybe it tipped over? Mine has 0 issues now that the car is running
01-24-2017, 06:20 PM | #6531 |
Just a quick question for opinions sake, how many of you guys run R154 transmissions with your swaps? I'm taking my time just buying parts and stacking them. I already have the R154 with the proper bellhousing and all. Like I said just for opinions sake how do you guys feel about these trannys before I go any farther forward. Thanks a bunch
01-26-2017, 10:49 PM | #6535 |
i browse this thread frequently for new ideas and such. heres a few pics of my s14 im working on. Ive done a 1jz swap in a previous s13 i owned, so doing a chassis swap with some upgrades.
1jz vvti, maverick motorsports adapter with cd009 and gktech shifter, cut and welded to a more "stock location". this year im running a greddy oil sandwich thermostat for am oil cooler. I also moved the wiring out of the fender well and to the driver side |
01-31-2017, 01:27 PM | #6536 |
Looks awesome man! How's it run with the j pipe delete?
2jz guys who went single, how is everything on stock fuel and ecu? Looking to do an s360 single on stock ecu and fuel. Anyone running the treadstone cast manifold? |
02-01-2017, 05:56 PM | #6537 |
I have a dumb question guys. I bought the collins cd009 trans kit and I am not sure if I am supposed to buy the cd with the internal or external slave cylinder. Can anyone guide me? Anyone have a pn? Im going to be buying it new.
02-02-2017, 06:06 PM | #6538 | |
Best bet is you will have to contact Collins Adapters or buyer to find out.
93 s13 Vert - 2jz/cd009 -- parted/sold 95 Supra Turbo |
02-02-2017, 06:41 PM | #6539 |
You can buy either, but it's best to go with the external slave cylinder trans because if you go with the internal slave cylinder trans, you will have to buy an upgraded slave cylinder from z speed at the tune of $325+ because the oem slave doesnt last, especially when you start using higher clamping force pressure plates
