Old 05-22-2017, 09:21 PM   #1
RalliartRsX
Trader Rating: (32)
Feedback Score: 32 reviews
Originally Posted by LuckyX2 View Post
Just keep in mind the N1s have a lot of overlap which becomes a problem with large backpressure and a 2.2 is going to generate more backpressure than a 2.0 assuming everything else is the same. I'm actually concerned a bit that the N1s are going to limit me when I shoot for 30psi. I may adjust the cams to reduce the overlap a bit.
WHat did Coheed produce on his 6266 fwd sentra with N1?? From what I saw, they worked very well for high boost/high back pressure situations.
The only other option is...............Kelford @ $1000...............and not a whole lot of sets of 184C come up for sale much less 184Ts. And even they did, they would be $800 lol
Old 05-22-2017, 08:05 PM   #2
RZRSHARP_240SX
RZRSHARP_240SX's Avatar
RZRSHARP_240SX is an unknown quantity at this point
Boost started around 2800 rpm. This is a p11 head. We haven't start the cam timing yet since we just want to wait till I put in the high boost actuator. I don't have the dyno chart yet since we are still not done tuning.
RZRSHARP_240SX is offline   Reply With Quote
Old 05-23-2017, 06:30 AM   #3
LuckyX2
LuckyX2's Avatar
LuckyX2 is an unknown quantity at this point
6266 is a larger turbo than the 7163 with a turbine that has a greater swallowing capacity which means less backpressure. Also his "high boost" was only 19psi. There's gonna be a lot more backpressure at 25-30psi.
His pressure ratio (exhaust:intake) was probably close to 1:1 where the N1s operate well since that is basically the ratio of an NA car with a good flowing exhaust. Meanwhile a 7163 at 25psi/8k+ is probably going to be a ratio of 1.5:1, maybe even 2:1 on a 2.2L.
I guess we'll find out if the N1s hold it back when I eventually get back to the dyno. My guess is the P12 cams will make the most power up top with a 7163 at 25psi+ while the N1s will make the most midrange. At ~20psi I'd guess the N1s are the best all over. I need midrange for autox and probably will only run 20-25psi when I compete anyway, so I went for the N1s.
TLDR; Once you hit the point where the backpressure overcomes the momentum of the exhaust and you see reversion, the P12s should make more power than the N1s due to less overlap.
My S13 SR Street Mod Build
LuckyX2 is offline   Reply With Quote
Old 05-26-2017, 02:58 PM   #4
Will.
Will.'s Avatar
Will. is an unknown quantity at this point
Hey Guys,
I'll be travelling from Australia to the US next week for EDC LV and staying around SF & LA the first two weeks. I'm also about to start my VE build and i was wondering if it was easy to obtain VE parts from Supertech or Mazworx, how long would it take to get parts shipped over to my hotel?
Instagram: willssilvia
Will. is offline   Reply With Quote
Old 05-26-2017, 03:06 PM   #5
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Originally Posted by hanzbrady View Post
Hey guys, I have multiple sets of Kelford VE cams on the shelf ready to ship, call or email and mention Zilvia and I'll knock 5% off your order!
Originally Posted by Will. View Post
Hey Guys,
send a PM to Hanz
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 05-26-2017, 03:52 PM   #6
hanzbrady
hanzbrady's Avatar
hanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura abouthanzbrady has a spectacular aura about
Hey Guys,
It depends heavily on what you're in need of. We have a lot of stuff on the shelf but if it's time sensitive always shoot us an email to confirm availability
[email protected]
hanzbrady is offline   Reply With Quote
Old 05-26-2017, 04:11 PM   #7
bardabe
bardabe's Avatar
Hey Guys,
I regularly stock Supertech & can get you the stuff you need no problem. PM sent!
Review Thread
bardabe is offline   Reply With Quote
Old 05-23-2017, 06:56 AM   #8
RalliartRsX
Trader Rating: (32)
So the one thing was the massive amounts of overlap of the n1 vs p12. Something like double the amount so we will see.
So far VET cams should (on paper) be the hot ticket if this is the case (low overlap) but real world testing has somewhat shown otherwise
However as yourself, I am looking for midrange and his low boost numbers would align more with what I intend to run on the VET/7163 hence why I'm going with the N1. At 20psi or so the back pressure shouldn't be more than 1.1-1.2 or so :1
In all honesty, I expect the VET cams to perform better for my 20-25psi/7163/stock unported/3 angle valve job head to perform the best for my goals.
Old 05-23-2017, 07:11 AM   #9
speedingmofa
speedingmofa's Avatar
speedingmofa is a well-known jackass
Awhile back people have been wondering how the stock sr20ve plenum can be flipped and welded... Well, i finally found someone who's done it:
No, it won't any beauty contests, but it seems to work and is making almost 500hp.
I thought the ports lined up like shit, but it seems to work for him!
About the cams, can someone break down what are the pros/cons (strength low/mid/top range) of each OEM cam (20ve, 16ve, N1, 20V and 20VET)?
I found this info awhile ago by Coheed, not sure if anyone's verified his claims:
"I've had good luck with the SR20VET cams. They have a strong powerband that starts to level out around 6500rpm or so, and holds pretty flat to redline. I made 440whp on 24psi with a log manifold and VET cams.
If you are running a log, don't use the stock cams. VET cams are your friend.
If you are tubular and want power under 8500rpm, look at SR20VE cams.
If you are tubular and want power up to 9500rpm or so, pick SR16VE cams.
Use N1 cams for crazy builds utilizing GT4294R+ turbos and 10,000rpm+ powerbands.
The 20V cams I would expect to fall in somewhere in the SR16VE area, and be good for top end power. But I would expect them to make a lot more mid-range than the SR16VE cams."
Need UKDM/EUDM/JDM/RHD Nissan parts? Hit me up
Insta: skids14
speedingmofa is offline   Reply With Quote
Old 05-23-2017, 12:37 PM   #10
600supersport
600supersport's Avatar
600supersport is an unknown quantity at this point
The Sr20/Sr22vet thread
Anyone actually shared EBP logs on these relatively similar setups before or are we just guessing off someone's log manifold and god knows what else?
Most now have a free flowing, 3" or bigger exhaust (probably catless), .73ar or bigger turbine housing and tubular manifold. Would this still be THAT much EBP on roughly a 35R sized turbine wheel or am I just wrong too?
600supersport is offline   Reply With Quote
Old 05-23-2017, 01:00 PM   #11
RalliartRsX
Trader Rating: (32)
Go ask BW (seriously). They have a the matchbot which has a majority of this already recorded
Old 05-23-2017, 03:08 PM   #12
LuckyX2
LuckyX2's Avatar
Matchbot calculates about 40psi of backpressure at ~8k for my SR20VE with a 7163 FYI.
Old 05-26-2017, 06:06 AM   #13
hanzbrady
hanzbrady's Avatar
[email protected]
Old 05-26-2017, 04:13 PM   #14
Will.
Will.'s Avatar
Thanks mate, i will send a PM.
I'm looking to build my P11 Head for my S15,
aimming for 370kw/500HP, responsive~ planning to run a EFR turbo. It will be a dd car and also occasional track days/time attack circuit.
Just seeing what parts would suit the build. I will also plan on building the bottom end aswell.
Old 05-26-2017, 04:24 PM   #15
livelovesole
livelovesole is an unknown quantity at this point
If you run an ATI Damper, do you still have to machine off 5mm?
livelovesole is offline   Reply With Quote
Old 05-26-2017, 04:28 PM   #16
bardabe
bardabe's Avatar
sounds good looking forward to doing business with you mate!
yes you do.
Review Thread
Old 06-01-2017, 08:42 AM   #17
Will.
Will.'s Avatar
My P11 head I just picked up, the previous owner ended up going RB26 on their S15, I got the head for cheap, its been acid washed and all the standard parts including cams were given to me in a separate box, Also got given a cool SR16VE rocker cover.
Going to be flying into San Fran from Sydney tomorrow morning for my holiday so it'll be delaying my build but I get to explore the USA
Old 06-01-2017, 09:00 AM   #18
RalliartRsX
Trader Rating: (32)
Luckily the head is very easy to put back together
However, I sure hope the prior owner properly labeled all the shims and locations......
Old 06-01-2017, 10:42 AM   #19
jr_ss
If it's taken down that far, he'd have to go back through and redo all the shims anyway.
Old 06-01-2017, 10:47 AM   #20
RalliartRsX
Trader Rating: (32)
True. I should be more specific
I sure hope he labeled the entire valve train and corresponding location.
When I bagged and tagged the head items, a diagram was drawn up for engine location and every item was bagged and tagged and will be returning to exactly where it was removed from
Old 06-02-2017, 02:08 AM   #21
bardabe
bardabe's Avatar
Hey guys am I the only one that thinks this thread belongs in the tech section by now?
Review Thread
Old 06-02-2017, 10:04 AM   #22
jr_ss
It's a discussion thread, not really a tech thread. I do think it needs to be stickied though.
Old 06-06-2017, 12:46 AM   #23
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
I second this. This thread is getting more and more legit.
Old 06-04-2017, 09:01 AM   #24
Will.
Will.'s Avatar
Everything's been tagged but I rather replace all them all with brand new components
Old 06-06-2017, 12:48 PM   #25
hanzbrady
hanzbrady's Avatar
Hey guys we need someone with a VVL swap in an schassis preferably an S14 to come by and help with some product development. We have a new product that we need to test firewall clearance for.
[email protected]
Old 06-07-2017, 10:39 AM   #26
jr_ss
I have one, I'm 2+hrs southwest of yous. I wouldn't be able to get the car up there during the week days, but possibly on a Sat. Pm me and maybe we can work something out.
Old 06-07-2017, 09:58 PM   #27
Hyaboosta
Hyaboosta is an unknown quantity at this point
Is anyone running aem series 2? I was curious if the units that are designed for the sr20 have any issues controlling the vvl engagement.
Hyaboosta is offline   Reply With Quote
Old 06-08-2017, 06:01 AM   #28
hanzbrady
hanzbrady's Avatar
It can control VVL.
[email protected]
Old 06-12-2017, 02:00 PM   #29
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
someone spilled the beans well not really, anyways, anyone used Porsche Cayenne coils. i head they pack a punch when used on KA-ts.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 06-13-2017, 09:45 AM   #30
RalliartRsX
Trader Rating: (32)
Why not just use Gixxer 750/1000 coils? They are less than 50 shipped for a set off ebay and are similar to the AEM pencil coils.
