Old 03-30-2014, 10:24 AM   #781
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
Pretty stoked to finally be able to post up, and actually have something to contribute today! Got everything installed yesterday, and so far has gone really well. Working out some boost control issues with my EBC, but I'll be sorting that out today hopefully!
Turbo is installed!!
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 03-30-2014, 12:54 PM   #782
Def
Got some pretty big PS leaks there!
I'd also be careful with the bend you have in that teflon oil feed line. Once that teflon liner kinks, you'll get almost zero oil flow through there. The outer braid will straighten out and you probably won't be able to tell.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 03-30-2014, 08:06 PM   #783
BlackZenkiS14
Also, at this power level, say 350whp, can the regular walbro 255lph fuel pump handle it? Or should I be upgrading now?
-Kyle
Old 03-30-2014, 08:11 PM   #784
Def
Walbro 255 can easily handle 350 rwhp on stock fuel lines and gas. It can even do it on E85 with enough injector, but you're starting to push the limits of stock lines a little past there.
DEFSPORT
Old 04-01-2014, 12:08 PM   #785
sftmb
sftmb's Avatar
sftmb is an unknown quantity at this point
I've got the DeatschWerks 255lph w/ 840cc injectors at around 370hp and no issues so far.
Also, to answer your question about the internal WG flap, I actually just got a locker bar for mine.
sftmb is offline   Reply With Quote
Old 04-01-2014, 03:43 PM   #786
BlackZenkiS14
What does your AFR look like in 2nd and 3rd?
In my car, if I do a full pull in 4th, it is dead solid 11.6-11.7 all the way til 8k pretty much.
However, in 2nd it hangs around 12.3, and 12.0 in 3rd. I just figured that the fuel pump wasnt able to keep up since it rips through those gears so fast?
-Kyle
Old 04-01-2014, 05:45 PM   #787
spooled240
spooled240's Avatar
spooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfectionspooled240 is close to perfection
where did you get all that cool hardware from?
spooled240 is offline   Reply With Quote
Old 04-01-2014, 08:50 PM   #788
BlackZenkiS14
Copper nuts from FRSport, and locking tab hardware from Stage8
-Kyle
Old 04-02-2014, 10:08 AM   #789
sftmb
sftmb's Avatar
hmm, not sure off the top of my head. I'll double check later today after work.
Old 04-02-2014, 01:01 PM   #790
Def
The leaner AFR in lower gears is the hysteresis of the MAF affecting the measurement vs. actual more and more. You also have hysteresis in your wideband O2 that is probably affecting results somewhat as well.
DEFSPORT
Old 04-02-2014, 11:33 PM   #791
ryan15
ryan15 is an unknown quantity at this point
Nice, I removed my engine to do the clutch, replace the rear main seal and to get the manifold welded up by codyace for an EWG. I just ordered the stage 8 bolts, some of the new studs I used to install the turbo seemed looser than when I installed them a month ago.
ryan15 is offline   Reply With Quote
Old 04-13-2014, 12:28 PM   #792
801nismo104
801nismo104 is an unknown quantity at this point
what heat range plug are you guys using and gap?
801nismo104 is offline   Reply With Quote
Old 04-13-2014, 02:15 PM   #793
Def
BKR7EIX's - stock 0.028" gap should be fine for this turbo. I'd maybe think about 8's if you're doing a lot of track time. Mine would range from looking fine to maybe a hair on the hot side with lots of track usage.
DEFSPORT
Old 04-13-2014, 02:24 PM   #794
801nismo104
Thats what im currently using. i was just wondering if i should switch to 8's. im going to just stick with 7's. Thank you for your response
Old 04-13-2014, 03:08 PM   #795
BlackZenkiS14
I also run the iridium 7's a .025 gap
-Kyle
Old 04-13-2014, 11:52 PM   #796
Seraphim38
Seraphim38's Avatar
Seraphim38 is an unknown quantity at this point
Send a message via ICQ to Seraphim38
Ngk bkr7s as well. I ran 30 gap until I went to a bigger turbo. Had to go down to 24 gap when I got past 430rwhp.
Sent from my SGH-T999 using Tapatalk
Mazworks | HKS | Greddy | T4 GTX3076r | Full Race | Tial | SPL | Feal
Seraphim38 is offline   Reply With Quote
Old 04-14-2014, 03:40 PM   #797
BlackZenkiS14
Ok, so I lost compression in #4 this weekend at the track (only 80psi), so looks like Im going to do a full rebuild. What kind of build specs are you guys running on built engines? how long have you had it together and running (miles/years)? And how has it affected reliability and driveability?
-Kyle
Old 04-14-2014, 05:34 PM   #798
spooled240
spooled240's Avatar
damn do you know what happened? Sounds like #4 leaned out and cracked some ring lands..
Old 04-26-2014, 07:39 PM   #799
gotta240
Couple dumb questions....
1.Why not use the stock locking plates(where the tabs fold up) instead of where you have those nordlocks?
2. Can Nordlocks be used instead of those copper locking nuts? Or is it well known that new copper locking nuts will hold?
3. Does anyone ever have issue with the bolts that hold the center section to the inlet/exhaust housings coming loose?
I'd like to just spend money on the hardware now and not have to worry about stuff coming loose. Open to suggestions.
Old 04-27-2014, 10:14 AM   #800
inopsey
what did you use for a tune?
Old 04-27-2014, 02:13 PM   #801
BlackZenkiS14
JWT ECU. Very happy with it.
New build coming, .020 over, CP pistons, Manley rods, refreshed head, apexi head gasket, OEM bearings, Splitfire ignition, full complete -AN power steering setup, etc...should be back in the car in about a month.
-Kyle
Old 05-12-2014, 07:06 AM   #802
Theyoung1.
Theyoung1. is an unknown quantity at this point
Hey guys had a few questions as to where my set up might stack up..
Vtc s14 sr
9.1 wiseco 87mm
1.2 tomei gasket
1mm over sized valves 3 angle intake 5 angle exhaust
Jwt s4 cams
Stock turbo mani ported and coated
T25+ t31 turbine housing moded for external gate
Gtx2867r
Should be getting on a dyno in a few months
My question is with the t31 t2 housing it flows like a full t3 at .63ar will this flow more like a .86 t2 or more like the .64? I want a really quick response
Also what do y'all believe my limit on boost with pump gas will be I'm running a custom cell -6 fuel line areomotive a750 pump feeding Nismo 740cc injectors will be doing an ls2 coil upgrade soon but first dyno will prolly by on the stock ignition system... Any input would be great!
Theyoung1. is offline   Reply With Quote
Old 05-12-2014, 11:56 AM   #803
Theyoung1.
ImageUploadedByTapatalk1399917339.537778.jpgImageUploadedByTapatalk1399917339.537778.jpgImageUploadedByTapatalk1399917368.564770.jpgImageUploadedByTapatalk1399917390.744621.jpgImageUploadedByTapatalk1399917405.174753.jpg
Old 05-12-2014, 09:42 PM   #804
Dont Panic
Dont Panic is an unknown quantity at this point
What fuel will you be using & what's your power goal?
Dont Panic is offline   Reply With Quote
Old 05-12-2014, 09:49 PM   #805
Theyoung1.
Well my 740's will limit me to petrol but I've been thinking of running a race gas pump mix, I'd like to see 400 whp with crazy fast spool... And maybe full race gas and 20+ psi to see what the set up is really capable of.
Old 05-12-2014, 10:39 PM   #806
Tom N
Tom N is an unknown quantity at this point
Just get a alcohol injection set up.
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 05-12-2014, 11:31 PM   #807
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
I would of sold you my housing!
http://zilvia.net/f/showthread.php?t=564456
huffandpuff00 is offline   Reply With Quote
Old 05-13-2014, 01:46 AM   #808
Dont Panic
No need to run race gas
With your setup you should yield 380-390 hp on pump
420 on E85 easy
Old 05-13-2014, 03:55 AM   #809
Theyoung1.
New Garrett GTX2867r
huffandpuff00 if only I would have known this over the weekend I would have bought yours.... What's your reason for selling? How's was response on this housing
Old 05-13-2014, 06:30 AM   #810
Theyoung1.
Y'all are making me feel confident with the set up I chose s4 cams due to my engine having vtc hoping that will make some tq down low and the s4's really shining up top I'm a total noob when it comes to this stuff so really not knowing what to expect it's been about 3 years of collecting parts and doing research...
gt2871, gtx, gtx2867r
