06-03-2010, 12:33 AM | #61 |
Re-read the front page. It says "shipped" after the posted prices.
1995 s14 Zenki - R.I.P 1992 s13 Zenki Coupe - KA-T |
06-03-2010, 12:43 AM | #63 | |
Trader Rating: (163)
Feedback Score: 163 reviews
It never hurts to ask though! Thanks, Toby |
06-03-2010, 02:00 AM | #65 | |
5901 and all the sensors + the back up battery shipped to 91754
http://silaudrey.blogspot.com/ |
06-03-2010, 08:39 AM | #66 | |
I do Paypal or money order/cashiers check. Thanks, Toby |
07-07-2010, 01:59 PM | #68 |
hmmm,,, can i get some help with a decent alarm, tilt sensor (cause we all know chicago guys are towing cars now), probably a back up battery and how hard would it be to install in an s13 if its my first time taking out the dash and all that? would i be better off having a pro do it and just paying up?
are the audio glass ones sensitive? my exhaust is loud as shit and i know it sets off alarms all the time, but would it be set off my some ricer driving past my car parked? |
07-07-2010, 05:37 PM | #69 | |
I always recommend doing it yourself. You can learn along the way. Just take your time and give me a shout if you have any questions. Toby |
07-16-2010, 12:12 AM | #70 | |
07-16-2010, 12:41 AM | #71 | |
Also, you do not need to take the dashboard out..... basically just the drivers under dash piece which is just a few screws. Toby |
07-19-2010, 02:38 AM | #72 |
hey broadfield i'm interested in purchasing a pair of the viper responder one remote starts but have a couple questions;
-does it have the feature that won't let the starter to grind when you turn the key on? -does it have the oil/temperature sensor so the car can't overheat? -does it piggy back of the stock actuators or do i need anything special to hook them up (lexus/volvo) thanks in advance! |
07-19-2010, 11:46 AM | #76 | |
edit: read it, yeah i never have my phone with me so ill skip out on the smart start lol. but you had said smartstart gives me unlimited range??? so i could be in like chicago and leave my car at home (north suburbs) and if someone starts messing with it i'll still get notified?? |
07-19-2010, 12:58 PM | #78 | |
07-19-2010, 07:09 PM | #79 | |
The Lexus has a goofy locking system where you have to run two wires into the door and wire a relay along with some diodes. If you buy stuff from me, I always send all documents and any little extra parts at no charge. So the stuff for the door locks would be included. You would want to remind me when you make payment. Keep in mind that the Viper Responder One will only unlock the doors, not lock...... it does not have keyless entry built into it. As far as oil sensor no. I have never even seen a system of any brand that has that. Although I'm pretty sure there is a brand out there that does. For anti-grind, all Vipers have a programmable output that you would wire a relay just like a starter-kill circuit. So during remote start, the starter wire is interrupted and therefore cannot grind if you turn the key too far. Any Viper remote start that also has an alarm will obviously have this "built-in" since it has an actual starter-kill relay built into it for the alarm portion. Thanks, Toby |
07-21-2010, 02:00 AM | #80 |
last question toby i swear lol...you mentioned that the viper one only unlocks doors...not locks. both cars already have keyless entry/locking. will this installation take that away or interfere with their oem keyless entry/alarms?
07-21-2010, 08:18 AM | #81 | |
lol.... ask away man, it keeps bumping my thread! The installation of any system will not interfere with the OEM keyless. However, your OEM keyless may not work while the vehicle is running. Which means it also won't work while the vehicle is remote started. This is why they add the unlock feature on the systems that are only remote start. Otherwise you would have to use the key in the door to unlock it while remote started or shut the remote start down then unlock it with the OEM remote. You can simply test this by starting your vehicle and seeing if the OEM remote will still unlock the door. If not, then you would want to hook up the unlock feature on the Viper Responder One, or simply buy the 5301 which has keyless built-in. |
07-24-2010, 05:45 AM | #82 |
I have a 1989 240sx with power windows and locks and I want to get the viper 5902. does that include everything I need to make the door locks work for keyless entry.. and do you have any in stock? thanks
07-24-2010, 07:40 AM | #83 |
Yes and yes! I include an extra relay and wiring just in case you have type-F(one wire) door locks. If you have plain negative trigger door locks then the Viper can control those without any extra parts. I also include vehicle specific wiring info with every purchase. I have them in stock and ready to go.
Thanks, Toby |
07-29-2010, 10:24 AM | #85 |
You can Paypal me at: [email protected]
Please enter in the comments box what the payment is for. Thanks, Toby |
08-28-2010, 05:55 AM | #89 |
Hi, do you still happen to have the 3303 in stock? I need it for a 95 240SX, base model. Let me know via PM or this thread I suppose.
I also have an alarm already set in place (came with my car) that I then want to remove and replace with this one. How difficult of a task is this going to be? |
08-28-2010, 07:48 AM | #90 | |
Alarm systems are fairly easy installs. It may make it a little easier since you already have the wires tapped for the one you currently have in there. Toby |
