Old 06-26-2013, 11:06 PM   #61
AXV
AXV is an unknown quantity at this point
Yea I'm reviving and old thread but better than making another thread. I am getting new plugs tomorrow. I have iridiums in there right now in my KA24DE but planning to get copper ones. The only "mod" I have on my s13 is a catback exhaust. Will I be ok with using stock FSM recommended gap? Or do I need to change it?
Thanks guys
AXV is offline   Reply With Quote
Old 06-27-2013, 02:00 AM   #62
!Zar!
!Zar!'s Avatar
Stock is fine.
Old 06-27-2013, 02:02 AM   #63
AXV
Thanks! NGK V Power should be good right?
Old 06-27-2013, 09:38 AM   #64
!Zar!
!Zar!'s Avatar
The V powers are ngk bkr7e. Those are fine.
That's all I run.
Old 06-29-2013, 09:19 PM   #65
S T Y L E S
S T Y L E S's Avatar
S T Y L E S is an unknown quantity at this point
What's would u guys recommend for a stock KA? Brand, heat and gap??
S T Y L E S is offline   Reply With Quote
Old 06-29-2013, 11:00 PM   #66
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
btw if you guys are interested i have some NGK schwag for sale
fender protectors, coffee mug, water tumbler.
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 06-30-2013, 12:15 AM   #67
EsChassisLove
EsChassisLove's Avatar
Trader Rating: (26)
EsChassisLove is an unknown quantity at this point
Feedback Score: 26 reviews
Originally Posted by turbociv910 View Post
Engines get better gas mileage and less emissions the hotter they are, that is why most cars have an operating temp of 200-220. Some iron blocks are 230!. Iridium increases heat increasing fuel mileage. Hotter everything is, the air the engine is consuming is less dense(= less fuel). Just like when its cold you expect more power right?
Copper runs cooler, has colder spark(naturally) to reduce detonation for higher horsepower and aftermarket applications. Many, countless times have i taken out iridium plugs in exchange for copper and gained power, or got rid of a miss fire.
never buy "iridium racing" plugs for your car, you will waste the $$ and i will say i told you so.
downside is that a copper plug wears out twice as fast, but who cares when they cost $3 a piece.
Had misfire with my .30 Iridiums. Swapped to cheap copper and .25 gap and misfire disappeared.
Going to dyno with Iridiums and then switch to copper to see a difference.
IG/TikTok-ThatS14_Z06guy
EsChassisLove is offline   Reply With Quote
Old 06-30-2013, 10:10 AM   #68
EnemyS15
EnemyS15 is an unknown quantity at this point
Awesome info ! Here, I have been reading up on heat ranges and what not. Definitely going with Ngk iridiums. Thought about going with a heat range of 8 for my 460-530 hp rb25. I have the general hp range due to my over all tune. Do you guys think 8 is a suitable heat range. It's still pretty new fresh material I am learning.
I have always just went with copper. Never had any probs, cheap, replace 1x a month with my monthly oil change on my previous cars. Iridium comes around and now takes the stage when it comes to spark plugs.
EnemyS15 is offline   Reply With Quote
Old 06-30-2013, 11:58 AM   #69
ILoveJDM
ILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to beholdILoveJDM is a splendid one to behold
Ive used a few types of DENSO iridiums
IK20
IK22
IK24 (currently using)
HEAT RANGE INFO COMPARABLE
DENSO 16 20 22 24 27 29 31 32 34 35
NGK 5 6 7 8 9 9.5 10 10.5 11 11.5
CHAMPION 12,11 10,9 8,7 6,63,61 4,59 57 55 53
BOSCH 8 7,6 5 4 3 2
I used the IK22 last year, the white stuff ended up actually cracking and going through my motor. Currently on the IK24 with 20psi 400whp sr22det and theyre great.
only downside is that theyre $10 a plug. Not bad since I just came back from owning a rotary....$40 set of plugs ..which i changed all the time
DODOlogic.ca
ILoveJDM is offline   Reply With Quote
Old 07-01-2013, 08:08 PM   #70
S T Y L E S
Anybody? Looking to replace it out this week
Old 07-01-2013, 08:22 PM   #71
EsChassisLove
Trader Rating: (26)
Replace them with stock.
Old 03-22-2021, 01:04 AM   #72
rightcoastimports
rightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond reputerightcoastimports has a reputation beyond repute
edit:: running BKR7E .28 gap on s13 sr 12-13psi
95 SR Zenki | @ e_form
daily - A34 Maxima | A36 Maxima
rightcoastimports is offline   Reply With Quote
Old 07-20-2022, 03:04 AM   #73
tunermt
tunermt's Avatar
tunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to beholdtunermt is a splendid one to behold
While searching for SR20det Iridium plugs I found this old thread and thought i'd share a little guide for other SR20det, KA24, RB owners in need of upgraded plugs/coils or anyone dealing with spark blow out. SR20det Iridium spark plugs
I know there is a lot of miss information about spark plugs, plug gap and heat range, hope this helps.
GTR PartsBuy JDM Cars
tunermt is offline   Reply With Quote
Old 07-20-2022, 11:04 AM   #74
Kingtal0n
Kingtal0n's Avatar
I tune the engine on BKR7, then install a fresh clean set and drive the vehicle 5k miles or so to review the plug condition in it's final tuned state. Then always switch to Iridium, usually heat range 7 , BKR7EIX for example. This for 2jz, sr20, or even LS application, pump gas, up to around 125hp/cyl, try to keep the gap open .021" to .025", doing this for around 20 years hundreds of cars
In LS application I use the TR6 or TR7 NGK plug for tuning as above (part# 4177 = TR6)
Then switch to iridium version of that plug with stock coils for up to 1200rwhp using stock engine 05-07 L33 5.3L for example, gap .019" to .023" , D585 coils , Heat range 7 or 8
Old 07-20-2022, 07:26 PM   #75
shaggyjake
shaggyjake's Avatar
shaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choicesshaggyjake has made poor choices
TR6 is a great heat range for the LS for like 400-550hp. This is what i run at 430whp gapped at .040 for NA application
TR7 is the next step for higher power or for long track sessions like 30+ minutes.
I think factory LS6 spark plug is like an NGK 5.5 equivalent gapped at .044
shaggyjake is offline   Reply With Quote
Old 07-25-2022, 06:00 AM   #76
tunermt
tunermt's Avatar
I run bkr7eix-11 factory 1.1mm gap in my s14 Sr20det on e85 and 19psi. (R35 coils)
I?ve run copper core ngk as well but they last less than half as long and I have to gap them way down compared to the iridium ngk spark plugs.
Old 07-25-2022, 12:04 PM   #77
jr_ss
Why are you running 11 heat range on a lower performing motor? Especially on E?
Old 07-27-2022, 07:05 PM   #78
Kingtal0n
Kingtal0n's Avatar
7 is the heat range , i forget why theres an 11 in there. but look its 7 not 11
pull up the ngk parts catalogue and lets get a breakdown of what ever letter number means
Old 07-28-2022, 09:33 PM   #79
tunermt
tunermt's Avatar
7 is the heat range the -11 at the end means the plugs are pre gapped to 1.1mm
Old 07-28-2022, 11:18 PM   #80
jr_ss
Well google failed me. I thought the heat range was in the PN not at the end. Thanks.
Old 07-29-2022, 01:17 AM   #81
tunermt
tunermt's Avatar
For the BKR7eix-11
The 7 represents the heat range, the 11 represents the gap (1.1mm)
