09-06-2006, 06:40 AM | #91 |
Learned this the hard way.
For those of you that didn't know already, SR fan shroud and clutch fan are different from KA fan shroud and clutch fan. SR shroud is offset different. SR clutch / fan is longer than KA setup. KA fan won't work on SR as it will hit crank pulley |
09-06-2006, 03:46 PM | #92 |
This applies to all S cars; however, SR cars are more prone to wiring problems since most people do not know how to run wires.
How to diagnose faulty fuel pump wiring: http://www.zilvia.net/f/showthread.php?t=108545 What a relay is: http://www.zilvia.net/f/showpost.php...9&postcount=20 Last edited by g6civcx; 09-09-2006 at 06:42 AM.. |
12-22-2006, 10:31 AM | #93 |
The Part number for K&N oil filters for a S14 blacktop is Hp-1008
if you need any cross refrencing with Nissan part numbers to ones that auto parts places are familir with just let me know, i can do all that stuff at work thanks Darius |
01-08-2007, 02:05 AM | #94 |
Telling SR20DETs apart visually:
S15 vs S14 Engines: S15's have higher CC injectors, they are red. S15's have a cast divider in the turbo elbow S14 Kouki vs S14 Zenki Kouki S14's have fins on the head. -thank you sblack13 S14 vs S13 Engines: Look for the bulge on the front of the engine and the slant at the back of the valve cover. Look at the intake manifolds, the S14's intake manifold has the throttle body higher - thank you sblack13 S13 Redtop vs S13 Blacktop Color of the valve cover (obviously) All blacktops have fins on the head Blacktops have a fat O2 sensor S13 Blacktop vs S13 Type-X Blacktop Look for the J4 ECU on the Type-X, I don't know of any visual way between the engines though. |
01-08-2007, 02:30 AM | #95 |
^kouki s14's do have fins
the zenki s14 sr20's have the older style maf plug with the metal clip, and some very few later model zenki s14 sr20's thru the s15's have the newer snap plug for the maf. Also its easy to get the s13 sr20det and s14 sr20det maf messed up they are the same plug type the s13 maf should have the following number on the maf NOTE: You cannot use a s14 maf on a s13 or vise versa they read different. 52F00 S13 69FO1 ZENKI 69FOO KOUKI and same goes for turbos they all will have that number engraved on the turbo indentifcation plate the S15 i believe is "54F00" Zenki SR20DET S14: Code "WC" ecu Kouki SR20DET S14: Code "NA" ecu and there is another way to tell the s15 and s14 motors apart. The coilpacks are different between the two. The most obvious difference between the s13 and s14 sr20det would be the intake manifold. Also.. if your running a 300zx maf this is what safc setting you run S13 W/ Z32 = 2in 6out S14 W/ Z32 = 2in 5out Are you swapping a S14 SR20DET into your s13? what you need to know Pretty much everything bolts up as it should in a s13 sr20det swap. Crossmember, Driveshaft, Motor mounts bolt up, of course duh. But!! you need to use your old s13 speed sensor from your manual tranny. You need to use your old s13 coolant temp sensor if you want to see your water temp. Thats pretty much it!! and for the s14 w/ s13 sr20det it should be the direct opposite. |
02-03-2007, 03:25 PM | #97 |
I'd like to add something I came across a while ago and haven't seen in the FAQ, the 96-97 1.8L Suzuki Sidekick AWD Sport ignitors plug straight in to the harness and work. Part number is 33370-77E20. No ricer markup on them, as far as I've seen (I got one for $10 at a local junkyard)
1989 S13 | 1996 S14 | 2001 E46 | 2009 ZX6R |
06-20-2007, 01:09 AM | #101 |
just had a strange problem. my stock t25 sr20det turbo blew. my guess is the seal went bad. the simptoms staeted when it whined a little bit, then progressed to start burning oil at idle once in a while. only idle. then just burnt oil at idle all the time. so i replased it and all better now. just thought this should be here if someone had the same problem as me.
Parking lot pimping |
07-23-2007, 10:37 PM | #102 |
S14 SR20DET / S13 SR20DET power steering pulley's are different sizes.
So is the crank pulley where the power steering belt is mounted, be careful when ordering underdrive pulleys/belts etc etc. For instance you cannot use S13 SR Power steering pump w/ s13 pulley with S14 Crank Pulley S14 SR Power Steering pump w/ s14 pulley with s13 crank pulley |
09-02-2007, 11:30 AM | #103 |
wow, going through this thread looking for some info and saw this completely incorrect piece of info^ TT and NA z32 mafs are the same...
09-22-2007, 05:36 PM | #104 | |
To add to this, i found a page on 240sx motoring that has the ECU part numbers that can tell you what engine/car combo your ecu is derived from.... http://www.240sxmotoring.com/partnumbers.html Good luck to those who need the info, and are doing the swap ^_^
Juicy slayin aint easy, but dammit somebody has to do it!!! |
10-18-2007, 02:41 PM | #105 |
FYI: For you s13 blacktop owners
U.S nissan part number for the "fat" o2 is 22690-48P01 (95 300zx TT) i havent actually started the car with it installed, but it threads in fine and plugs right up in the harness. |
10-29-2007, 10:49 PM | #106 | |
On the onther hand, for trouble shooting: -If sr runs like crap after 5lbs of boost, more than likely you have serious boost leakage. Timing being too retarded, misfires but not as frequent as leaking boost. too advanced and you will expirience detonation and top end feels like crap. -if you have a problem with sensors acting up, try using a one thats not fcuked up. if problwm still presist, then obviously its not the sensor. -throttle body off of any sr will work, some harness are different on newer sr, so take the pig tail from engine harnes and color match/pin match. -all o2 off srs (g20/sentra se-r/nx2000) are the same(I've used 300zx,se-r,and g20).(lost of stuff can be used off fwd sr) Working on finding starter that works possibly 01 frontier... -maf from g20 and sentra se-r work on sr20det -89 nissam maxima clutch works but suck -turbo does not need a#* load of oil pressure.(Fcuk up seals if you do) -no expirience=spending lost of money fixing fcuk -up(leave it to people who know thier xiet) -And last but not least Nissan are NOT hondas! beware the mayham.... oh and if valves tap, check oil squirters above cams and make sure they are not clogged. have a nice day! if your a do your hwk! |
11-02-2007, 12:33 PM | #107 | |
livin on the east cost is harder then you think... ECM for life lll |
11-07-2007, 01:45 AM | #108 |
Specifications for the Red Top SR20DET
(Found on the 91-93 180SX & Silvia)
Specifications for the Black Top SR20DET (Found on the 94-98 180SX)
Specifications for the S14 Black Top SR20DET with VTC (Found on the 95-98 Silvia)
Specifications for the S15 Black Top SR20DET (Found on the 99+ Silvia)
--------------------------------------------------------------------------------------------- Parts that fit the SR20DET here in the U.S STOCK Nissan clutch - 89 - Nissan Maxima 240mm 9-7/16" spline 24x1 Ignitor Chip - 92+ - Infiniti Q-45 Throttle Body - 91-98 - Nissan 240SX DOHC Oil Filter - 92-99 - Sentra/200SX SE-R Spark Plugs - 91-99 - Sentra/200SX SE-R MAFS(will need plug) - 89-90 - Nissan 240sx 12 valve Exhaust Manifold Gasket - 91- Sentra SE-R O2 Sensor - 87 - Nissan 300zx Turbo Fuel Injectors - 95 - Nissan 300zx TT Belts (PS, AC, ALT) - Gates K050370 Alt. K040345 PS & AC S14 Oil Filter - 95 - Nissan Sentra SE-R S13 Oil Filter - 91 - Nissan Sentra SE-R T25 Turbo Gasket - 95 - Nissan 300zx TT T25 gaskets SR Turbo Studs - VG30DE Studs part # 14064 7B000 ---------------------- -------------------------------------------------------------- SR20DET wiring ECU pins and description of wire colors 1 - Coil Pack 1 Output (Via power transistor Unit) - Red White 2 - Coil Pack 2 Output (Via power transistor Unit) - Red Yellow 3 - Tachometer signal output - Yellow Red 4 - ECCS Relay - Red Black 5 - Ignition Pulse Monitor (For Trip Comp ?) 6 - Ignition Signal Ground - Black 7 - RX data (Signal from Nissan Consult hand terminal) -Green Black 8 - Coil Pack 3 Output (Via power transistor Unit) - Red White 9 - Coil Pack 4 Output (Via power transistor Unit) - Red White 10 - 11 - 12 - A/T signal DT3 (autotrans gear select ?) 13 - Ignition Signal Ground - Black 14 - CLK clock (timing signal) - Green White 15 - TX data (signal to Nissan Consult hand terminal) - Green 16 - MAFS signal input ( Mass Air Flow Sensor ) - White 17 - MAFS ground - Black 18 - Water Temp Sensor input - Blue Brown 19 - Oxyen Sensor input (O2) - White 20 - TPS input (throttle postion sensor) - White 21 - Sensor ground - Black 22 - CAS 180deg signal (Crank angle sensor) - White 23 - CHK check (check start) ? - Green Red 24 - Monitor check Lamp (red) (fault code lamp output) 25 - Exhaust over temp warning lamp output - Orange 26 - Exhaust temp sensor inout (Behind the Cat) - Blue Yellow 27 - Detonation sensorinput (knock sensor) - White 28 - TPS for A/T (kick down switch) 29 - Sensor ground - Black 30 - CAS 180deg signal (crank angle sensor) - White 31 - CAS 1deg signal (crank angle sensor) - Black 32 - Speed sensor input - Yellow Green 33 - 34 - Start signal (from ignition switch) - Orange 35 - A/T neutral switch input - Green Orange 36 - IGN (ignition ON, from ignition switch) - Black Red 37 - TPS power output (power to throttle position sensor) - Light Green Red 38 - ECCS power - Black White 39 - ECCS ground - Black 40 - CAS 1 deg signal (crank angle sensor) - Red Black 41 - A/C on input (Air Con ON from A/C panel) - Blue Green 42 - A/T signal DT1 (auto trans gear select ?) 43 - Power steering switch (speed proportional control output) - Purple White 44 - A/T signal DT1 (auto trans gear select ?) 45 - Ambient air tamp sensor input - Blue White 46 - ECCS backup power - Red 47 - ECCS power - Black White 48 - ECCS ground - Black 101 - Injector No. 1 drive output - White Black 102 - EAI control solenoid output (egr valve control ?) - Orange Black 103 - Injector No.3 drive output - Green Black 104 - Fuel pump relay output - Black Purple 105 - Fuel pressure control module - Red White 106 - A/C on output (Air conditioner on relay signal) - Green Black 107 - Injector ground - Black 108 - Injector ground - Black 109 - Reverse electrical flow return circuit (alternator fail input) - Red 110 - Injector No. 2 drive output - Yellow Black 111 - Turbo boost pressure control solenoid (over boost cut ?) - Orange Black 112 - Injector No. 4 drive output - Blue Black 113 - AAC valve control (Auxiliary Air Control, Idle speed control) - Light Blue 114 - 115 - 116 - Injector ground - Black ------------------------------------------------------------ Usefull info ive used threw out the years and got saved in a folder. Thought it would be useful for some if i dropped it in here. Peace, True Speed- Last edited by TSLegendary; 11-07-2007 at 02:08 AM.. |
11-15-2007, 12:35 AM | #109 |
ECU Codes
RED WC is from a 95-96 S14 Silvia Zenki BLACK WC is from a 96-97 S14 Silvia Chuki (transition, different MAF plug) NA is from a 97-98 s14 Silvia Kouki 5 speed 62 is from a 91-93 180sx or S13 Silvia 5 speed 63 is from a 91-93 180sx or S13 Silvia automatic E5 is from a 94-96 180sx black top 5 speed E6 is from a 94-96 180sx blacktop automatic J4 is from a 97-98 180sx Kouki 5 speed J5 is from a 97-98 180sx Kouki Automatic Also: S14 Zenki SR20 with Red WC ECU has a rectangle MAF plug S14 Chuki SR20 with Black WC ECU has an oval MAF plug, S14 Kouki SR20 with Black NA ECU has an oval MAF plug |
11-23-2007, 05:56 PM | #110 |
This website helped me out a lot. its where i found what ECU i needed to match my harness
http://www.nodrft.com/page.php?id=25 |
12-23-2007, 07:34 PM | #111 |
Ran across a couple of things today while researching wastegates.....firstly, dont know if this mod has been posted, but its called a free boost upgrade....
Details here : http://www.nissansilvia.com/forums/F...de-t12212.html Another is vaccum line routing, which i found VERY USEFUL.... Details here:
12-25-2007, 11:22 PM | #112 |
I have some useful ecu pinouts I found on the net.
This is for a Zenki S14 SR20 Blacktop WC and this is the Kouki S14 Blacktop and JDM S15 Pinouts (they are basically the same) |
02-25-2008, 11:12 AM | #113 |
resistance between + and - on the coil packs should be 1 ohm
compression on each cylinder should be 1.087 Kpa minimum of 883 kpa and the most that the cylinders can be off by is 98 Kpa. I was having compression problems so i figured id post that since it was a pain to find. |
03-10-2008, 06:04 PM | #114 |
S13 KA24DE Cam cap bolts/cam tower bolts/call them what you want, are interchangeable with S13 SR20 Cam cap bolts/cam tower bolts.
i snapped my S13 SR20 bolt while torquing it after installing RASs(yes i know i'm retarded for doing it). i honestly couldn't find anything about them on zilvia or the internet. keep in mind the "outer" cam cap bolts are longer than the "inner (closer to spark plugs)" bolts. i only used the inner, and that is all i can vouch for. hope this helps! oh yeah, and i removed the snapped bolt with an ez-out or bolt extractor (lol call it what you want) if you would like more details, feel free to PM me |
04-06-2008, 06:38 PM | #115 |
Trader Rating: (44)
Feedback Score: 44 reviews
S14 Sr20det
13270-65f00 Valve Cover Gasket 13271-65f00 Spark Plug Gasket 13268-31u01 Valve Cover Washers (where Bolts Go Thru) 13224-2j200 Valve Cover Bolts X14 13224-52f00 Bolt (that Goes Between 2nd And 3rd Coil Pack) 21010-65f26 Or 25 Water Pump 21200-0c811 Thermostat 14036-75f00 Exaust Manifold Gasket (7 Layer) 14064-2j200 Exaust Manifold Studs X8 14037-42l02 Exaust Manifold Yolks X8 08912-8401a Exaust Manifold Nuts X8 15208-65f0c Oil Filter 11110-52f10 Oil Pan 13500-69f00 Front Cover (with Oil Pump) 08120-6201e Front Cover Bolts X10 17042-69f00 Fuel Pump 16400-41b0a Fuel Filter S15 Spec R Sr20det 14411-91f00 Turbo 16600-91f00 Injector
Daily Driven |
04-15-2008, 02:23 PM | #117 |
kouki man
Trader Rating: (36)
Feedback Score: 36 reviews
sr redtop and blacktop can use an 89-90 sohc starter. i made a thread
http://www.zilvia.net/f/showthread.p...27#post1910027 |
05-08-2008, 03:47 PM | #118 |
Most SR20DET swaps, even if they're advertised as 'Complete' do not include the SR20DET Motor Mount Brackets as are required to install the engine (duh)
You can use your stock motor mounts, but not your stock motor mount brackets which are bolted to the block. Also, it is much easier to install the engine with the motor mounts attached to the swap and then put it in the engine bay, rather than just try to line the brackets up while the mounts are in the car. Even if your oil pan looks good, take it off and bang it out anyway. Or buy the GReddy oil pan or a replica. Even if it doesn't look too bent in, looks may be deceiving. When wiring your power up to the engine using a battery relocation kit, don't forget about the two power wires in the harness behind the passenger headlight that were hooked up to the stock battery terminal. Obviously you'll need power to the lower harness on the SR swap, but you need power to these two plugs as well.
06 Civic Si 2dr for the daily grind 90 S13 Coupe w/SR20DET for weekend fun |
06-08-2008, 03:48 PM | #119 |
thought id add this hope it helps
Basically the list goes Part/Date/Part Number/Special Note Engine: Bare engine assembly Jan 1991 - Jan 1994 10102-50F50 Bare engine assembly Jan 1994 - Aug 1996 10102-50F52 Bare engine assembly Aug 1991 - Dec 1998 10102-50FM2 Short block engine assembly Jan 1991 - Dec 1998 10103-50FM0 Cylinder Block and Oil Pan: Oil jet assembly Jan 1991 - Aug 1993 11560-79E00 Timing chain oil jet Jan 1991 - Dec 1998 13081-53J00 Timing chain oil jet Aug 1993 - Dec 1998 11560-1E000 Rear oil seal Jan 1991 - Dec 1998 12279-18V00, 12279-30P00, 12279-1E000, 12279-53J10, 12279-85Y00, 12279-1N510 Oil pan lower baffle Jan 1991 - Jan 1994 11113-52F00 Oil pan lower baffle Jan 1994 - Dec 1998 11113-65F00 Main bearing cap bolts Jan 1991 - Dec 1998 12293-53J00 Dipstick Jan 1991 - Dec 1998 11140-52F00 Dipstick tube Jan 1991 - Dec 1998 11150-52F00 Crankcase plate baffle Jan 1991 - Dec 1998 11038-53J00 Rear oil seal retainer Jan 1991 - Dec 1998 12297-53J00 Oil pan Jan 1991 - Dec 1998 11110-52F10 Upper oil pan Jan 1991 - Dec 1998 11110-52F01 Upper oil pan baffle Jan 1991 - Dec 1998 11113-53J02 Rear engine plate Jan 1991 - Dec 1998 30411-52F00 Plate between engine and tranny Rear plate cover Jan 1991 - Dec 1998 30417-52F00 Plate on back of upper oil pan Valve Cover/Cylinder Head: Spark plug cover Jan 1991 - Dec 1998 13287-50F01 Spark plug cover bolt Jan 1991 - Dec 1998 01131-40F01 Valve cover nut Jan 1991 - Nov 1992 01217-00181 Valve cover nut Nov 1992 - Jan 1994 01217-00221 Valve cover nut Jan 1994 - Dec 1998 08918-20610 Valve cover washer Jan 1991 - Dec 1998 13268-97E00 Valve cover stud Jan 1991 - Dec 1998 13508-53J00 Valve cover red Jan 1991 - Jan 1994 13264-50F02 Valve cover black Jan 1994 - Dec 1998 13264-50F03 Valve cover gasket Jan 1991 - Dec 1998 13270-52F00 Valve cover spark gasket Jan 1991 - Dec 1998 13271-52F00 Headgasket Jan 1991 - Dec 1998 11044-50F01 Oil cap assembly Jan 1991 - Dec 1998 15255-40F01, 15255-1P101 Cylinder head assembly Jan 1991 - Dec 1998 11040-52F00 PCV Valve Jan 1991 - Dec 1998 11810-79E01 Intake valve seat Jan 1991 - Aug 1996 11098-53J60 Intake valve seat Aug 1996 - Dec 1998 11098-1E765 Exhaust valve seat Jan 1991 - Aug 1996 11099-53J60 Exhaust valve seat Aug 1996 - Dec 1998 11099-53J65 Timing chain Jan 1991 - Dec 1998 13028-53J03 Chain guide slack side Jan 1991 - Sep 1996 13091-53J01, 13091-2J200 Chain guide slack side Sep 1996 - Sep 1997 13091-2J200, 13091-2J201 Chain guide slack side Sep 1997 - Dec 1998 13091-2J201, 13091-2J202 Chain guide tension side Jan 1991 - Oct 1997 13085-53J00, 13085-1N500 Chain guide tension side Oct 1997 - Dec 1998 13085-1N500 Timing chain tensioner Jan 1991 - Dec 1998 13070-2J200, 13070-2J203 Cam sprocket (intake) Jan 1991 - Dec 1998 13024-53J01 Cam sprocket (exhaust) Jan 1991 - Dec 1998 13095-52F00 Camshaft (intake) Jan 1991 - Dec 1998 13020-1E000 Camshaft (exhaust) Jan 1991 - Dec 1998 13020-50F12 Rocker arm Jan 1991 - Dec 1998 13257-53J03 Hydraulic lash adjuster Jan 1991 - Dec 1998 13234-53J01 Rocker shim (T=2.800) Jan 1991 - Dec 1998 13229-53J00 Rocker shim (T=2.825) Jan 1991 - Dec 1998 13229-53J01 Rocker shim (T=2.850) Jan 1991 - Dec 1998 13229-53J02 Rocker shim (T=2.875) Jan 1991 - Dec 1998 13229-53J03 Rocker shim (T=2.900) Jan 1991 - Dec 1998 13229-53J04 Rocker shim (T=2.925) Jan 1991 - Dec 1998 13229-53J05 Rocker shim (T=2.950) Jan 1991 - Dec 1998 13229-53J06 Rocker shim (T=2.975) Jan 1991 - Dec 1998 13229-53J07 Rocker shim (T=3.000) Jan 1991 - Dec 1998 13229-53J08 Rocker shim (T=3.025) Jan 1991 - Dec 1998 13229-53J09 Rocker shim (T=3.050) Jan 1991 - Dec 1998 13229-53J10 Rocker shim (T=3.075) Jan 1991 - Dec 1998 13229-53J11 Rocker shim (T=3.100) Jan 1991 - Dec 1998 13229-53J12 Rocker shim (T=3.125) Jan 1991 - Dec 1998 13229-53J13 Rocker shim (T=3.150) Jan 1991 - Dec 1998 13229-53J14 Rocker shim (T=3.175) Jan 1991 - Dec 1998 13229-53J15 Rocker shim (T=3.200) Jan 1991 - Dec 1998 13229-53J16 Rocker arm guide Jan 1991 - Dec 1998 13218-53J00 Valve spring collet Jan 1991 - Dec 1998 13210-D4200 Valve spring retainer Jan 1991 - Dec 1998 13209-53J00 Valve spring Jan 1991 - Dec 1998 13203-53J00 Valve spring seat Jan 1991 - Dec 1998 13205-53J00 Intake valve oil seal Jan 1991 - Dec 1998 13207-84A00 NDK Intake valve oil seal Jan 1991 - Dec 1998 13207-D4201 NOK Intake valve Jan 1991 - Jan 1994 13201-53J00 Intake valve Jan 1994 - Dec 1998 13201-1E700, 13201-1E710 Exhaust valve oil seal Aug 1996 - Dec 1998 13207-53F00 NOK Exhaust valve oil seal Jan 1991 - Dec 1998 13207-D0111 NDK Exhaust valve Jan 1991 - Feb 1996 13202-53J01 Exhaust valve Feb 1991 - Dec 1998 13202-53J02 Front Cover: Oil pump assembly Jan 1991 - Dec 1998 13500-50F00 Front main seal Jan 1991 - Jan 1994 13510-40F00, 13510-53J10 NDK Front main seal Jan 1994 - Aug 1996 13510-53J00 NDK Front main seal Aug 1996 - Dec 1998 13510-53J01 NOK Front main seal Jan 1991 - Aug 1996 13510-53J10, 13510-53J11 NOK Front main seal Aug 1996 - Dec 1998 13510-53J11 NDK Oil pump gear set Jan 1991 - Dec 1998 15020-50F00, 15020-79E00 Oil pump regulator valve set Jan 1991 - Dec 1998 15132-50F00 Engine and Tranny Mount: Engine mount right Jan 1991 - Apr 1991 11210-40F00 Engine mount right Apr 1991 - Dec 1998 11210-52F00, 11210-65F11 Engine mount left Jan 1991 - Apr 1991 11220-40F00 Engine mount left Apr 1991 - Dec 1998 11220-52F00, 11220-65F06, 11220-85F00 Tranny mount Jan 1991 - Dec 1998 11320-35F01 Tranny crossmember Jan 1991 - Dec 1998 11340-35F00 Engine - Bottom End: Piston ring set (standard) Jan 1991 - Dec 1998 12033-53J00, 12033-53J01 Piston ring set (0.20 oversize) Jan 1991 - Dec 1998 12035-53J00 Crank Sprocket Jan 1991 - Dec 1998 13021-53J00 Crankshaft assembly Jan 1991 - Dec 1998 12200-60J10 Piston with pin (standard-1) Jan 1991 - Jul 1993 A2010-79E60 Piston with pin (standard-2) Jan 1991 - Jul 1993 A2010-79E61 Piston with pin (standard-3) Jan 1991 - Jul 1993 A2010-79E62 Piston with pin (0.20 oversize) Jan 1991 - Jul 1993 A2010-79E71 Piston with pin (standard-1) Jul 1993 - Dec 1998 A2010-54C00, A2010-75F60 Piston with pin (standard-2) Jul 1993 - Dec 1998 A2010-54C01, A2010-75F61 Piston with pin (standard-3) Jul 1993 - Dec 1998 A2010-54C02, A2010-75F62 Piston with pin (0.20 oversize) Jul 1993 - Dec 1998 A2010-54C10, A2010-75F76 Connecting rod assembly Jan 1991 - Dec 1998 12100-79E00 Con rod bearing (standard-0) Aug 1996 - Dec 1998 12111-1N500 Con rod bearing (standard-1) Aug 1996 - Dec 1998 12111-1N501 Con rod bearing (standard-2) Aug 1996 - Dec 1998 12111-1N502 Con rod bearing (standard-0) Jan 1991 - Aug 1996 12111-60J00, 12111-1N500 Con rod bearing (standard-1) Jan 1991 - Aug 1996 12111-60J01, 12111-1N501 Con rod bearing (standard-2) Jan 1991 - Aug 1996 12111-60J02, 12111-1N502 Con rod bearing (US 0.12) Aug 1996 - Dec 1998 12117-1N500 Con rod bearing (US 0.12) Jan 1991 - Aug 1996 12117-60J00 Con rod bearing (US 0.25) Aug 1996 - Dec 1998 12118-1N500 Con rod bearing (US 0.25) Jan 1991 - Aug 1996 12118-60J00, 12118-1N500 Con rod bearing (US 0.8) Aug 1996 - Dec 1998 12122-1N500 Con rod bearing (US 0.8) Jan 1991 - Aug 1996 12122-60J00 Crank bearing (standard-0) Jan 1991 - Dec 1998 12207-60J00 Crank bearing (standard-1) Jan 1991 - Dec 1998 12207-60J01 Crank bearing (standard-2) Jan 1991 - Dec 1998 12207-60J02 Crank bearing (standard-3) Jan 1991 - Dec 1998 12207-60J03 Crank bearing (standard-4) Jan 1991 - Dec 1998 12207-60J04 Crank bearing (standard-5) Jan 1991 - Dec 1998 12207-60J05 Crank bearing (standard-6) Jan 1991 - Dec 1998 12207-60J06 Crank bearing set (US 0.25) Jan 1991 - Dec 1998 12208-60J00 Thrust washer Jan 1991 - Dec 1998 12280-60J00 Crankshaft pulley Jan 1991 - Dec 1998 12303-52F00 Crankshaft pulley bolt Jan 1991 - Dec 1998 12309-29S00 Clutch: Flywheel assembly Jan 1991 - Dec 1998 12310-79E11, 12310-79E12 Flywheel bolt Jan 1991 - Dec 1998 12315-52F00 Pilot bushing Jan 1991 - Dec 1998 32202-B9500 Intake/Exhaust Manifold: Upper intake manifold Jan 1991 - Dec 1998 14001-52F00 Connects to head Lower intake manifold collector Jan 1991 - Dec 1998 14010-52F00 Connects to throttle body Throttle body gasket Jan 1991 - Mar 1993 16175-53J00 Throttle body gasket Mar 1993 - Dec 1998 16175-79S70, 16175-79S71 Intake manifold gasket to head Jan 1991 - Dec 1998 14035-53J10 Intake manifold middle gasket Jan 1991 - Dec 1998 14032-52F00 Throttle cable bracket Jan 1991 - Dec 1998 16165-52F00 Throttle cable insulator Jan 1991 - Dec 1998 18316-52F00 Throttle body Jan 1991 - Dec 1998 16118-52F00, 16118-52F05 Throttle position sensor Jan 1991 - Jun 1997 22620-53J00, 22620-53J01 Throttle position sensor Jun 1997 - Dec 1998 22620-31U01 Throttle cable pulley Jan 1991 - Dec 1998 16134-52F00 Idle air control valve Jan 1991 - Dec 1998 23781-50F05 Tousoku Idle air control valve Jan 1991 - Dec 1998 23781-50F15 Atsugi Idle air control valve gasket Jan 1991 - Dec 1998 23785-50F00 Exhaust manifold gasket Jan 1991 - Dec 1998 14036-53J00 Exhaust manifold Jan 1991 - Dec 1998 14004-50F00 Exhaust manifold stud Jan 1991 - Aug 1996 08267-03010 Exhaust manifold stud Aug 1996 - Jun 1997 14065-75F00 Exhaust manifold stud Jun 1997 - Dec 1998 14064-2J200 Exhaust manifold washer Jan 1991 - Dec 1998 14037-42L02 Exhaust manifold nut Jan 1991 - Dec 1998 08912-8401A Turbocharger: Turbocharger Jan 1991 - Dec 1998 14411-50F00 Manifold to turbo gasket Jan 1991 - Dec 1998 14415-17M00 Turbo to O2 pipe gasket Jan 1991 - Dec 1998 14445-26E00 O2 extension Jan 1991 - Dec 1998 14440-50F01 Locking washer plate Jan 1991 - Dec 1998 14495-17F00 Oil return tube Jan 1991 - Dec 1998 15197-50F00 Oil return gasket Jan 1991 - Dec 1998 15196-79E00 Lubricating System: Oil filter bracket assembly Jan 1991 - Dec 1998 15238-52F01 Oil pickup tube/strainer Jan 1991 - Sep 1993 15050-52F00, 15050-52F01 Oil pickup tube/strainer Sep 1993 - Dec 1998 15050-65F01 Oil pickup O-ring seal Jan 1991 - Jan 1994 15059-V5001 Oil pickup O-ring seal Jan 1994 - Dec 1998 15053-1E400 Cooling: Waterpump Jan 1991 - Dec 1998 21010-52F01 Waterpump pulley Jan 1991 - Dec 1998 21051-65F00 Clutch fan clutch Jan 1991 - Dec 1998 21082-52F00 Clutch fan fan Jan 1991 - Dec 1998 21060-52F00 Upper waterneck Jan 1991 - Aug 1996 11060-52F00, 11060-52F01 Upper waterneck Aug 1996 - Dec 1998 11060-65F00, 11060-65F01 Lower water inlet Jan 1991 - Dec 1998 13049-52F00 Thermostat Jan 1991 - Dec 1998 21200-53J00, 21200-53J10, 21200-0C810 Thermostat housing Jan 1991 - Dec 1998 11061-52F05 Engine coolant temp sensor Jan 1991 - Jan 1994 22630-V5010, 22630-51E00 Engine coolant temp sensor Jan 1994 - Aug 1996 22630-51E00, 22630-51E02 Engine coolant temp sensor Aug 1996 - Dec 1998 22630-43Y00, 22630-44B10 Engine coolant temp sensor Aug 1996 - Oct 1997 22630-44B10, 22630-44B20 Engine coolant temp sensor Oct 1997 - Dec 1998 22630-44B20 Radiator Jan 1991 - Dec 1998 21410-52F11 Resevoir tank Jan 1991 - Dec 1998 21721-35F01 Upper radiator shroud Jan 1991 - Dec 1998 21476-52F00 Lower radiator shroud Jan 1991 - Dec 1998 21477-35F00 Fuel system: Fuel injector Jan 1991 - Dec 1998 16600-50F00, 16600-50F02, 16600-50F10, 16600-50F12 Small injector O-ring Jan 1991 - Dec 1998 16618-53J00 Large injector O-ring Jan 1991 - Dec 1998 16618-10V05 Injector insulator Jan 1991 - Dec 1998 16635-53J00 Injector rubber back cap Jan 1991 - Dec 1998 16619-53J00 Fuel rail Jan 1991 - Dec 1998 17520-52F00 Fuel pressure regulator Jan 1991 - Dec 1998 22670-52F00 Fuel pump Jan 1991 - May 1991 17042-35F00 Fuel pump May 1991 - Dec 1998 17042-73L02 Intake: Mass air flow sensor Jan 1991 - Dec 1998 22680-52F00 Compressor inlet tube Jan 1991 - Dec 1998 16577-50F00 bolts to turbo Compressor inlet tube gasket Jan 1991 - Dec 1998 14465-54C00 Intake rubber tube Jan 1991 - Dec 1998 16578-50F01 Ignition System: Coilpack Jan 1991 - Dec 1998 22448-50F01 Coilpack harness Jan 1991 - Dec 1998 24079-50F00 Igniter chip (PTU) Jan 1991 - Dec 1998 22020-50F00, 22020-50F01, 22020-50F10 Knock sensor Jan 1991 - Dec 1998 22060-30P00 Camshaft position sensor (CAS) Jan 1991 - Dec 1998 23731-50F02 Electronics: Wastegate control solenoid Jan 1991 - Dec 1998 14956-50F00 Oxygen sensor Jan 1991 - Jan 1994 22690-50F00 Oxygen sensor Jan 1994 - Dec 1998 22690-50F02 Oxygen sensor holding nut Jan 1991 - Jan 1994 20607-V5000 Oxygen sensor holding nut Jan 1994 - Dec 1998 20607-P6500 ECU Jan 1991 - Jan 1994 23710-50F00 MT ECU Jan 1994 - Aug 1996 23710-50F05 MT ECU Jan 1991 - Jan 1994 23710-50F10 AT ECU Jan 1994 - Aug 1996 23710-50F15 AT ECU Aug 1996 - May 1997 23710-60F06 MT ECU May 1997 - Dec 1998 23710-60F07 MT ECU Aug 1996 - May 1997 23710-60F16 AT ECU May 1997 - Dec 1998 23710-60F17 AT Alternator Jan 1991 - Aug 1996 23100-52F10, 23100-52F11 Alternator Aug 1996 - Dec 1998 23100-65F17 Starter Jan 1991 - Dec 1998 23300-52F01, 23300-80F00 Tachometer gauge Jan 1991 - Jan 1994 24825-52F00 Tachometer gauge Jan 1994 - Aug 1996 24825-52F20 Temperature sensor Jan 1991 - Aug 1996 25080-89903 Temperature sensor Aug 1996 - Dec 1998 25080-89907 Power Steering: Power steering pump Jan 1991 - Dec 1998 49110-52F00 2WS Power steering pump Jan 1991 - Dec 1998 49110-52F60 4WS Hicas Transmission: Clutch slave cylinder Jan 1991 - Mar 1997 30620-18V01, 30620-69F01, 30620-69F02, 30620-69F03 Clutch slave cylinder Mar 1997 - Dec 1998 30620-0H620 SR20DET transmission Jan 1991 - Aug 1996 32010-50F00, 32010-50F20, 32010-50F21, 32010-50F22 SR20DET transmission Aug 1996 - Dec 1998 32010-69F10 SR20DET front belhousing shell Jan 1991 - Apr 1995 32101-50F00 SR20DET front belhousing shell Apr 1995 - Dec 1998 32101-50F01 Speed sensor assembly Jan 1991 - Aug 1996 25010-35F00 Same as US S13 Speed sensor assembly Aug 1996 - Dec 1998 25010-71T00 Speed sensor pinion gear Jan 1991 - Aug 1996 32743-35F20 Speed sensor pinion gear Aug 1996 - Dec 1998 32743-71T20 Driveline/Suspension: Output flange (right 5 star) Jan 1991 - Oct 1995 38220-53F00, 38220-93L00 Output flange (right 6 bolt) Oct 1995 - Dec 1998 38220-92L00 Output flange (left 5 star) Jan 1991 - Oct 1995 38220-53F01 Output flange (left 6 bolt) Oct 1995 - Dec 1998 38220-52F01 Half shaft (right 5 star) Jan 1991 - Oct 1995 39600-73L00 Half shaft (right 6 bolt) Oct 1995 - Dec 1998 39600-35F00 Half shaft (left 5 star) Jan 1991 - Oct 1995 39601-73L00 Half shaft (left 6 bolt) Oct 1995 - Dec 1998 39601-35F10 Front strut tower bar Dec 1995 - Aug 1996 E4390-50F00 Front strut tower bar Aug 1996 - Dec 1998 E4390-60F00 Nismo front strut tower bar Jan 1996 - Aug 1998 E4420-RN521 Rear swaybar Jan 1991 - Dec 1998 56230-39F03 Other Desired JDM 180SX Parts: Digital climate control Jan 1991 - Aug 1996 27510-52F00 Digital climate control Aug 1996 - Dec 1998 27510-60F01 Digital control subharness Jan 1991 - Aug 1996 24042-52F00 Resister for climate control Jan 1991 - Jan 1994 27150-51E01 Resister for climate control Jan 1994 - Aug 1996 27150-51E05 Cabin temp sensor Jan 1991 - Dec 1998 27720-35F03 Sunload sensor Jan 1991 - Dec 1998 27721-35F00 Kouki front bumper cover Aug 1996 - Dec 1998 F2022-60F** **varies by color Kouki optional lip spoiler Aug 1996 - Dec 1998 K6010-60F50 Kouki fender side piece (left) Aug 1996 - Dec 1998 62025-60F** Kouki fender side piece (right) Aug 1996 - Dec 1998 62024-60F** Chuki side skirt (left) Dec 1995 - Aug 1996 76851-51F81, 76851-51F25 Chuki side skirt (right) Dec 1995 - Aug 1996 76850-51F81, 76850-51F25 Side skirt #2 (kit) Jan 1991 - Aug 1996 G6850-40F** Side skirt #2 (left) Jan 1991 - Aug 1996 G6852-40F10 Side skirt #2 (right) Jan 1991 - Aug 1996 G6851-40F10 Kouki side skirt kit #2 Aug 1996 - Dec 1998 G6850-60F** Kouki side skirt (front-left) Aug 1996 - Dec 1998 76853-60F** Kouki side skirt (front-right) Aug 1996 - Dec 1998 76852-60F** Kouki side skrit (rear-left) Aug 1996 - Dec 1998 76857-60F** Kouki side skirt (rear-right) Aug 1996 - Dec 1998 76856-60F** Kouki rear spoiler Aug 1996 - Dec 1998 K6030-60F25, K6030-60F26 Kouki rear valence kit Aug 1996 - Dec 1998 H5910-60F** Rear valence kit Jan 1991 - Aug 1996 H5910-51F** Rear valence (left) Jan 1991 - Aug 1996 H5913-51F10 Rear valence (middle) Jan 1991 - Aug 1996 H5911-51F10 Rear valence (right) Jan 1991 - Aug 1996 H5912-51F10 180SX side glass (right) Jan 1991 - Jan 1995 83300-47F00 180SX side glass (right) Jan 1995 - Dec 1998 83300-47F01 180SX side glass (right) Sep 1997 - Dec 1998 83300-47F02 180SX side glass (left) Jan 1991 - Jan 1995 83301-47F00 180SX side glass (left) Jan 1995 - Dec 1998 83301-47F01 180SX side glass (left) Sep 1997 - Dec 1998 83301-47F02 180SX Rain guards Jan 1991 - Dec 1998 G3810-40F00 Kouki front seat (back assy) Aug 1996 - Dec 1998 87600-60F00 Both sides Kouki front seat (cushion assy) Aug 1996 - Dec 1998 87300-60F00 Right side Kouki front seat (headrest) Aug 1996 - Dec 1998 86400-80F10 Both sides Kouki front seat (cushion assy) Aug 1996 - Dec 1998 87350-60F00 Left side Kouki rear seat (back assy) Aug 1996 - Dec 1998 88600-60F00 Kouki rear seat (cushion assy) Aug 1996 - Dec 1998 88300-60F00 180SX Key (with 180SX logo) Jan 1991 - Dec 1998 KEY00-00135 Zenki front turn signal (right) Mar 1989 - Jan 1991 B6120-44F00 Zenki front turn signal (left) Mar 1989 - Jan 1991 B6125-44F00 Chuki front turn signal (right) Jan 1991 - Aug 1996 B6120-50F00 Chuki front turn signal (left) Jan 1991 - Aug 1996 B6125-50F00 Kouki front turn signal (right) Aug 1996 - Dec 1998 B6130-60F00 Kouki front turn signal (left) Aug 1996 - Dec 1998 B6135-60F00 Front amber sidemarker (right) Mar 1989 - Dec 1998 26160-47F00 Front amber sidemarker (left) Mat 1989 - Dec 1998 26165-47F00 Kouki parking light (right) Aug 1996 - Dec 1998 B6170-60F00 Kouki parking light (left) Aug 1996 - Dec 1998 B6175-60F00 180SX rear center light Mar 1989 - Aug 1996 26540-47F00 Kouki tail light (right) Aug 1996 - Dec 1998 B6550-60F00 Kouki tail light (left) Aug 1996 - Dec 1998 B6555-60F00 Kouki tail light (center) Aug 1996 - Dec 1998 26540-60F** Kouki tail center (carbon?) Aug 1996 - Dec 1998 K0810-60F00 Kouki rear trim panal Aug 1996 - Dec 1998 85230-60F00 Navan steering wheel Jan 1991 - May 1995 D840V-11100 Navan steering wheel (Hicas) Jan 1991 - May 1995 D840V-11130 Momo steering wheel Aug 1996 - Dec 1998 D8400-C9901 |
02-25-2009, 08:03 PM | #120 |
DIDNT SEE NO FAQ's ABOUT THE N/A SR's, So here my share of a couple things:
Distributor rotor : nissan 200NX Distributor cap: DOHC KA(must be mitsubishi equip) SE-R AND G20 caps wont work. AND due to the direction of the port's you'll need the DOHC KA sparkplug wires RWD-SR20DET/DE clutch are identical DOHC KA PS can fit to SR20DE/DET , but you have to swap the tension bracket and pulleys thats all i came across so far with my N/A SR. Last edited by DDDsquad_s13panda; 03-05-2009 at 10:55 AM.. Reason: more info |
