Old 02-07-2010, 10:08 AM   #1381
SuicidnS13
SuicidnS13's Avatar
SuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruinSuicidnS13 is on the path to ruin
Not much in the front and unknown in the rear as Im still on stock RUCAs as I mentioned above. Next weekend I will install toe links and Rucas in the rear and adjust accordingly.
SuicidnS13 is offline   Reply With Quote
Old 02-07-2010, 10:09 AM   #1382
Dazzla
Dazzla is an unknown quantity at this point
Black zenki on kf's is amazing man...very nice
Dazzla is offline   Reply With Quote
Old 02-07-2010, 10:09 AM   #1383
SuicidnS13
SuicidnS13's Avatar
Here is a good front shot with it lowered another 1/2 inch or so.
And in the front I have Stance Coilovers, Tien Tie Rods so far installed. I have a ton of more parts to still install but I am waiting till I am dropping my motor in to do it as the car will be on jack stands at that point.
Old 02-12-2010, 05:40 PM   #1384
S@nt0s
S@nt0s's Avatar
S@nt0s is an unknown quantity at this point
Originally Posted by Slo_240sx View Post
glad to see another dragger.... that makes the 2nd chassis 240 i knwo of out here and both are in socal
S@nt0s is offline   Reply With Quote
Old 03-14-2010, 04:45 PM   #1385
[email protected]
twotones13@yahoo.com is an unknown quantity at this point
because pan
twotones13@yahoo.com is offline   Reply With Quote
Old 03-14-2010, 05:07 PM   #1386
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
^^^ What the....how does that belong in here again? Why is there a pull when its not needed at all?
CLICK HERE!!!
Old 03-14-2010, 05:16 PM   #1387
SuicidnS13
SuicidnS13's Avatar
Nuff said here!!!!
Old 03-15-2010, 06:19 AM   #1388
GripTerror
GripTerror is an unknown quantity at this point
This thread needs new life, where are all the fat tire people
GripTerror is offline   Reply With Quote
Old 03-15-2010, 06:35 AM   #1389
SicBastard
SicBastard's Avatar
SicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the roughSicBastard is a jewel in the rough
The title of "FIRST TO ROCK 345's" is still open...
Zilvinites are maturing and getting better jobs everyday, it's just a matter of time.
BURN OUT IN YOUR FACE!
1998 S14 LS7/T56 swap in progress, build thread:
http://zilvia.net/f/tech-talk/147301...d-gto-pan.html
SicBastard is offline   Reply With Quote
Old 03-15-2010, 07:12 AM   #1390
GripTerror
i hope to do with my v8 swap but not anytime soon, i bet by the time i do the v8 swap someone woulda already done it. In fact I think that purple wheel S13 already has that with 18x13 rears... i think they were 335s though not 345
Old 03-15-2010, 08:04 AM   #1391
SicBastard
SicBastard's Avatar
345/30/18 on 18/10.5 cobra rims
Proof you don't have to go nuts on wheels to get the rubber. But 18x14 CCWs would be nice!
18x13 wheels with 345/30s. Wheels started off as 9.5" width, and had em widened by 3.5" by weldcraftwheels
You are actually pretty limited in rubber for 345s. These are all drag radials on mustangs, but Michelin makes the pilots for the vipers, and there's always Hoosier!
Old 03-15-2010, 08:31 AM   #1392
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
Give me a few days...255/275 stagger on the S14 OEM metal fenders.
Quote of the year?
Originally Posted by projectRDM View Post
Zoom in a little more, it's not blurry enough.
bshotts is offline   Reply With Quote
Old 03-15-2010, 09:07 AM   #1393
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
i like those 18x13
TRUE thing: True ////OFFSET\\\\ is acheived without spacers
Running on E85 570whp Precision 5862....laggy as fuck. hate it
ROIDMONKEY is offline   Reply With Quote
Old 03-15-2010, 09:56 AM   #1394
longfellow
longfellow's Avatar
longfellow is an unknown quantity at this point
I'm already there.
longfellow is offline   Reply With Quote
Old 03-15-2010, 10:28 AM   #1395
bshotts
bshotts's Avatar
Originally Posted by longfellow View Post
I'm already there.
Must be nice! Still using your 17x9 et+15 and 17x10 et+12 FN01 setup? You just switched to 275 from 255 on the rears then?
Quote of the year?
Old 03-15-2010, 10:32 AM   #1396
longfellow
longfellow's Avatar
Same wheel set up. Though I will say I'm going to start working on my "OEM" wide front fenders tonight because the current ones are bent to hell from the wheels rubbing on them since the car is lower than it used to be.. I also have a 3/4" pull on the rear fenders. 17x10 +25 FN01RC's with 275's would clear stock fenders all day.
Old 03-15-2010, 04:51 PM   #1397
longfellow
longfellow's Avatar
OEM Metal wide front fenders
Old 03-15-2010, 09:00 PM   #1398
bshotts
bshotts's Avatar
Not a bad idea...can't wait to see the final product. How do you plan on combining the two? Cut and weld I assume? How much clearance are you gaining...15 to 20mm?
Quote of the year?
Old 03-15-2010, 09:06 PM   #1399
longfellow
longfellow's Avatar
Yeah the top layer is getting welded in place then grind down the welds, bondo to smooth everything out then cut out the inside, presto stock looking +20ish front fenders that dont totally suck.
I'll measure once I finish them but I'd guess 15-20mm is about right. I'm getting a d/s fender friday. I would do it this weekend but dont have the time, so I'll have an update on it in 2 weeks.
Probably end up running a 15mil spacer up front untill I get 10" FN's to replace the 9"s with.
Old 03-15-2010, 09:36 PM   #1400
GripTerror
Needs moaaar tire
Old 03-15-2010, 09:47 PM   #1401
longfellow
longfellow's Avatar
haha as is always the case
But honestly 255 NT05's are more than enough for 300hp (which I dont even have yet!). If I ever decided to go to NT01's I'd be in heaven. I like my steering to still be some what responsive. I can hardly move the wheels more than 1/2 turn when the engine is off already. Plus 275-40-17 is a shit tire size. If they ever make a 275-35-17 tire I'd be all over it.
Old 03-15-2010, 11:07 PM   #1402
Homer_Simpson
Homer_Simpson's Avatar
Homer_Simpson is on the path to ruinHomer_Simpson is on the path to ruinHomer_Simpson is on the path to ruin
Clever, I like it.
Homer_Simpson is offline   Reply With Quote
Old 03-16-2010, 12:52 AM   #1403
atutt
atutt's Avatar
atutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond reputeatutt has a reputation beyond repute
Does anyone make anything wider than a 315 in 17's???
I know khumo makes a315 in 17's but that's about it i think
atutt is offline   Reply With Quote
Old 03-16-2010, 07:51 AM   #1404
longfellow
longfellow's Avatar
http://www.discounttiredirect.com/direct/tires/nitto/product/submitProductSize.do?pc=40524&typ=Passenger%2FPerf ormance&tmn=NT05
Old 03-16-2010, 11:35 AM   #1405
s142jzkillav10
s142jzkillav10's Avatar
s142jzkillav10 is an unknown quantity at this point
Send a message via MSN to s142jzkillav10
Exclamation
I wanna see engine bay shots!!!!!!!!!!!! What's the deal with the Cholos???
s142jzkillav10 is offline   Reply With Quote
Old 03-16-2010, 12:02 PM   #1406
s142jzkillav10
What size are your wheels 17/18 ?? And did you have to modify the rear so the tire would clear ??? Thank you.
Old 03-16-2010, 12:06 PM   #1407
iwannaslyde
iwannaslyde's Avatar
iwannaslyde is an unknown quantity at this point
^im actually starting to like these FN01rc's
iwannaslyde is offline   Reply With Quote
Old 03-16-2010, 04:45 PM   #1408
greddy2die
greddy2die's Avatar
greddy2die is an unknown quantity at this point
Send a message via AIM to greddy2die
Who is that question directed towards, Slo_240sx?
if so i hope i hope your kidding because there are pictures above that clearly show that the rear is tubbed.
greddy2die is offline   Reply With Quote
Old 03-16-2010, 05:35 PM   #1409
SuicidnS13
SuicidnS13's Avatar
And also the car in primer with the fn's has 50mm widebody fenders molded on.
Old 03-16-2010, 09:42 PM   #1410
s142jzkillav10
Question if for the Black Primer 240 Not the Green. For the Green I would like to see some Engine Bay shots.
