#1419 |
Clearance is good on the inside as far as tire to inner well goes but the LCA is getting close to the wheel/tire ~1/2 of clearance id say. Id like to say a bigger tire would be a breeze to fit with some fine tuning.
Alignment specs are unknow at this point until I finish my frontend but ill be sure to edit my original post with the numbers. |
#1421 | |
![]() Join Date: Mar 2009
http://i72.photobucket.com/albums/i1...x/100_2183.jpg IMG_1047.JPG |
#1423 | |
![]() Join Date: Jan 2003
![]() ![]() Feedback Score: 13 reviews
Here's my 255/275 stagger, think I'm going to go a little lower in front and balance out rear side to side: ![]() |
#1424 |
245/40/18s on all 4 corners with 7 or 8mm spacers, decent tire width for only an 8 inch wheel
Tires are Nitto Neogens, fenders are only rolled ![]() how do most of you pull your rear fenders? I tried with a fender roller but I didn't want to break it because it's not mine.. but i kinda wana see how rear over fenders look with factory aero.. I'll be getting much more aggressive wheels of course to compensate. |
#1425 |
Offset is F18x9 +40 R18x10 +45
Tires are 255/35/r18 Rear's 295/35/r18 ![]() ![]() ![]() Work Mister S2 18x9 18x10 ------------------------------------------------------ WHEELS ARE!!! ![]() ![]() Offset is F18x9 +40 R18x10 +45 Work Meister S2's I had them on the car for a week and have had them in the garauge for about 4months!!!!! ![]() ![]() ![]() Last edited by s142jzkillav10; 03-30-2010 at 10:12 PM.. |
#1426 |
Did you need a spacer in the rear with the 18x10 +45s? Are the control arms stock length?
BURN OUT IN YOUR FACE! 1998 S14 LS7/T56 swap in progress, build thread: http://zilvia.net/f/tech-talk/147301...d-gto-pan.html |
#1427 |
Impossible without using spacers as you would most def hit the rear lower control arm. I hit mine at exactly 188mm backspace....10 +45 is 193mm backspace. I'd guess he used a 10mm at least. As for the fronts...9 +40 is 168mm backspace which would also be impossible with coilovers which leads me to believe he's on lowering springs. Largest backspace I've seen with coilovers on S14 front is 158mm (Ray's 18x10 +18.)
#1428 |
5mm Spacer needed for Stock struts but and so it wouldn't be so close to the lower control arm. due to the stocks being so wide it would rub when it squated or hit a big bump.
#1429 |
The front did require about a 1" or 3/4 spacer due to the stock struts. But I never got a chance to try these with coilovers.
I had to make a desition power or looks and choose a gt4294 Jurbo. ![]() |
#1430 | |
![]() Join Date: Apr 2009
Trader Rating: (38)
![]() Feedback Score: 38 reviews
I have 30mm rear overs on stock jdm s14 aero, i think it looks really good, i will post some pics either later tonight or this weekend. its got tiny tires on it now tho, eventually will get a 255/275 tires. |
#1431 | |
![]() Join Date: Apr 2007
#1433 | |
![]() Join Date: Feb 2002
Trader Rating: (68)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 68 reviews
Cameron |
#1438 | |
![]() Join Date: Sep 2007
Trader Rating: (25)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 25 reviews
Exceeded bandwidth, BRO. Try hosting them on Imageshack.us
#1440 | |
![]() 17x9+18 235/40-17 17x10+20 255/40-17 One of my all time favorite coupes (belonged to YucA http://zilvia.net/f/member.php?action=getinfo&u=27650 before it was stolen awhile back)
![]() Quote:
