Old 08-27-2010, 07:11 PM   #1561
Csomme
Csomme is an unknown quantity at this point
How? like details on how?
I'm sitting here with my girlfriend getting ready to go to a movie and just yelled out, "What the fuck!? How!?"
So, pwease do tell<3
Ordering soon Dan.
Csomme is offline   Reply With Quote
Old 08-29-2010, 03:19 PM   #1562
!Zar!
!Zar!'s Avatar
I'm still interested in how much the average person is cutting off of their knuckles. Everyone says that it depends on the wheel combo, but I'd imagine the average would be something like a x9 or a x9.5 +0 up front?
So would something like 2.5" shorter be a ball park or what?
Aside from that, everyone seems to be up in arms about their front roll center and and trying to achieve great roll center or whatever, but then most are rocking the rear stock/stockish. To me it seems like it would be best to leave both alone, and then try to change all of it at once, because changing only the front will disrupt front to rear balance.
Old 08-29-2010, 03:56 PM   #1563
Def
The front roll center drops much further with lowering than the rear due to the geometry. So the front needs correction more than the rear. Of course, going crazy on the front with zero adjustment in the rear is not smart.
I spaced my front lower balljoints down ~1.625"(probably about 1.25" more than stock), and raised the rear subframe up to the framerails with SPL bushings. Feels great to me, but the front could probably use a bit more correction.
S13 Hatch - Goes around tracks quickly
DEFSPORT
Old 08-29-2010, 06:01 PM   #1564
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
This is exactly what I have done as well - the car rides better than it ever has...all I'm awaiting now are the SPL outer tie rod ends to make some of the bumpsteer go away and we're set.
Old 08-29-2010, 10:16 PM   #1565
zorak
zorak's Avatar
zorak is an unknown quantity at this point
Send a message via AIM to zorak
comparison:
zorak is offline   Reply With Quote
Old 08-30-2010, 01:34 AM   #1566
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
To summarize what's spread out in my posts in this thread, I use the MAX Super Angle Kit installed like this:
MAX SAK Tommy Roberts Spec
That in combo with the prototype long tie rods and long lower control arms produces that angle without letting the knuckles steering arm line up with the tie rod.
A wheel spacer eliminates hitting the wheel on the frame and tie rod. There are no aftermarket steering rack parts and the rack has not been moved.
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline   Reply With Quote
Old 08-30-2010, 06:52 AM   #1567
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
So if that black thing (looks like a massive zip tie?) was in line with the tie rod as well, that would be over centering?
Instagram - SJKnoop
95KA-Turbo is offline   Reply With Quote
Old 08-30-2010, 07:12 AM   #1568
thefro526
thefro526's Avatar
thefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of lightthefro526 is a glorious beacon of light
Originally Posted by DC Dan MAX USA View Post
Angle is 55 degrees (center to lock while on the lift) but the most unique thing is that we are achieving this angle without overcentering.
heres proof
Wow, that's pretty rad.
It's impressive that you did all of that without over centering... Shoot, I was getting ready to move my rack forward and stuff too.
Btw, do you have an ETA for the Tie Rods? I figure the LCA's are probably a few months out still?
thefro526 is offline   Reply With Quote
Old 08-30-2010, 10:27 AM   #1569
PoorMans180SX
PoorMans180SX's Avatar
Yup. I think it's a metal straightedge though? Hahahah.
Old 08-30-2010, 01:09 PM   #1570
DC Dan MAX USA
Trader Rating: (79)
The metal ruler is the effective new knuckle steering arm angle determined by the mounting position of the MAX SAK. Exactly, if that was in line with the tie rod they would be centered, or mechanically locked due to the rack having no leverage angle to turn the knuckle.
Old 08-30-2010, 01:43 PM   #1571
PoorMans180SX
How many degrees of caster are you running on the S15 Dan?
Old 08-30-2010, 01:48 PM   #1572
!Zar!
!Zar!'s Avatar
How much caster is in that pic?
Edit: PoorMan said it before I noticed his post. hahaha
Old 08-30-2010, 02:00 PM   #1573
Tearlessj
Tearlessj's Avatar
Dan,
In the above photo with the new FLCA, are you running the normal SAK or the T.R. SAK's? I have the normal SAK, don't know whether I should wait to get the FLCA or send my knuckles in.
Nagasaki Motors
Tearlessj is offline   Reply With Quote
Old 08-30-2010, 02:17 PM   #1574
PoorMans180SX
He's running the Tommy-spec ones. He says it in the quote. Less ackerman, roll center corrected 25mm.
Old 08-31-2010, 07:15 AM   #1575
cazman
cazman's Avatar
cazman is an unknown quantity at this point
Send a message via MSN to cazman
heres proof
Sure do prevent over centering. I had worked out how to do this over a year ago in Aus. I wonder how long it will take people to actually see whats different though.
The only downers are the ADD bumpsteer, as steering length changes with more lock. The distance between centers of the rack end and tie rod end.
This isnt so bad as stock does this, but this is reversed now.
It adds dead ahead bumpsteer too, Ie when your driving straight ahead.
Your ackeman is now dynamic too, changing with amounts of lock. Can you post up a picture that shows both wheels at full lock ?(underneath, midslide, hard parked etc)
once again not a huge problem, but if its not spot on you will get anti ackerman quickly.
But IMO it still fixes many of the problems that we face when drifting, and the good outways the bad IMO. And reps for just working out the binding knuckle secret.
cazman is offline   Reply With Quote
Old 08-31-2010, 07:36 AM   #1576
PoorMans180SX
Originally Posted by cazman View Post
Sure do prevent over centering...
You, good sir, should read through the last several pages of this thread. The PSM knuckles are very well developed, and correct for bumpsteer and roll center. They also have less ackerman, but nowhere near anti-ackerman.
Old 08-31-2010, 07:42 AM   #1577
95KA-Turbo
95KA-Turbo's Avatar
Not to mention, if there is some super secret you should be talking about it, not talking from a pedestal. This thread isn't to show off what you know, its to share what you know with others so people who know more then you can assist with your ideas and make them better.
Instagram - SJKnoop
Old 08-31-2010, 07:44 AM   #1578
cazman
cazman's Avatar
I am slowly going back through the pages, Im still yet to see rpoof of the removed bumpsteer, and not some "seat of the pants" dyno proof either.
A genuine plot on an aligner.
I can see the ackerman a few pages back now, but as stated in my post, please measure ackerman at all steering wheel positions, not just MAX lock.
Lock to lock ackerman will be identical, and if the car is aligned it will have 0 at center too, but measure the dynamic, I suspect it will grow and shrink on the each side independently.
Old 08-31-2010, 07:57 AM   #1579
95KA-Turbo
95KA-Turbo's Avatar
I am not sure about the total removal of bumpsteer, but they have bumpsteer correction built into their knuckles. You can see it in this picture:
Instagram - SJKnoop
Old 08-31-2010, 07:58 AM   #1580
cazman
cazman's Avatar
Just look at the pictures, and the one camera angle that is missing from every image... I figured it would only be a matter of time till some one jigged or copied the idea anyway.
Im not trying to start a pissing fight, sorry. Just the province of bumpsteer removal without figures doesnt sit well.
I have a suspension tuning business in Aus, been playing with these for a while now. I have never really cared about the cash in it, don't worry about that :P
Here is a WIY FCA kit, most of the components came from the US anyway, hahaha
Old 08-31-2010, 08:15 AM   #1581
PoorMans180SX
Ha, sometimes it's not all about the graph man. If you have both ends of the tie rod parallel with both ends of the FLCA, there will be as little bumpsteer as possible. Obviously bumpsteer changes with steering lock, but there really isn't any way around this.
I'm pretty sure you're confusing ackerman with toe and dynamic toe? There will never be any ackerman at center, on any car, ever. And of course changing ackerman will change dynamic toe, they're basically interchangable. It's a pretty simple curve of the tie rod end, nothing crazy.
So the above is a kit to make FLCA's like the PSM ones I take it? Except with modified stock arms and bearing cups for the ball joint ends, yeah?
Just to let you know, Ikeya Formula was the first to design arms like that.
Old 08-31-2010, 08:49 AM   #1582
SoSideways
SoSideways's Avatar
How about we all take the ego out of this thread and just talk about what matters?
THE GODAMNED SUSPENSION.
Not who the fuck came up with who first.
Nissan obviously came up with this shit first, as they made the fucking car. I just don't think they gave a shit with drifting and how the car's suspension would be in a lowered car, or else their knuckles wouldn't be the way they are.
Old 08-31-2010, 09:03 AM   #1583
cazman
cazman's Avatar
Im not trying to emphasise who came up with it first, just that more research has been done than in this thread, and there are reasons that it is bad practice.
Im not confusing the 2 don't worry.
Due to the new tie rod end angle, when your wheel is centered your tie rod ends now angle inwards (the angle is level to the ground stock)
As you turn wheels your tie rod/ rack length alters.
You can see here, the tie rod end no longer points to the ground at straight ahead.
Now you can imagine/see what happens at full lock either way. Instead of being equal angle both sides, it is now different lock to lock.
It makes the car feel a bit odd, and WONT remove bumpsteer. Nissan spent alot of time getting this stuff dead perfect, to alter a few points and angles really upsets things.
As far as the FLCA, it was the dentsport items that I based them off, I never said they were new. Just easily rebuilt once made.
No use of the stock arm, and they use a 3/4 bolt not a small taper bolt. Ive seen too many fail when the taper was incorrect, or the finish on the material was too coarse.
Def hasn't had issues with the 3/4s so far, and its a similar kit, but witha 7/8 bearing, and youll see the Roll center cones sit in the bearing, removing (reducing significantly) lateral load on the bolt.
Old 08-31-2010, 09:34 AM   #1584
PoorMans180SX
The whole point of the Parts Shop MAX knuckle is to make the tie rods level to the ground when the car is on the ground.
Then you can use the other parts to bring the FLCA pivot points parallel with the tie rod pivot points.
Thus, eliminating bumpsteer.
Old 08-31-2010, 09:58 AM   #1585
Csomme
That wheel is turned brah.
Why don't you ask questions and THEN give your input instead of assuming?
I also think you have a misconstrued way of how bumpsteer works? or maybe you're not explaining yourself properly?
Old 08-31-2010, 10:16 AM   #1586
Def
Are you talking about the actual vertical orientation of the tie rod stud?
That doesn't matter one bit as long as you aren't binding the tie rod stud while steering.
Bumpsteer occurs due to different arcs of the FLCA and tie rod(for a strut car like ours) during suspension travel. Once both pivots are in line with each other, they follow the same arc, and you don't have toe changes with suspension travel.
What do you think bumpsteer is, because that doesn't sound like what you're referencing.
DEFSPORT
Old 08-31-2010, 10:32 AM   #1587
SoSideways
SoSideways's Avatar
Well, so far, you haven't given a single input, other than sit there criticizing other people's work, and showing a picture of one of your kits in a non-assembled state.
I can go out and take a bunch of pictures of random bearings and bolts and shit and call it my kit too.
Honestly, you come in here on your high horse, calling everyone out, but your high horse is just a little donkey.
Get real or get out.
Old 08-31-2010, 10:45 AM   #1588
GripTerror
GripTerror is an unknown quantity at this point
Guys shut up and stop fighting, don't ruin this beautiful thread.
GripTerror is offline   Reply With Quote
Old 08-31-2010, 03:07 PM   #1589
conrad_s13.5
conrad_s13.5's Avatar
conrad_s13.5 is making a name for him/her selfconrad_s13.5 is making a name for him/her self
^ aint fighting,..just hittin people with knowledge.
some idea's and inventions are created off debates!
im nothin' special but i for one cant wait for these to go public........the science and rigorous testing and Q&A that seems to go into these and all other PBM parts sold me long ago
cONtRol FReAkS
conrad_s13.5 is offline   Reply With Quote
Old 08-31-2010, 04:35 PM   #1590
DC Dan MAX USA
Trader Rating: (79)
Originally Posted by Tearlessj View Post
Dan,
The way you say that may lead people to think there is more than one SAK.
Just to clarify, there is only one SAK and the difference is how much towards the outside you rotate it before its welded in. The more you rotate it out the less ackerman you get. So when I say Tommy Roberts Spec, I say that because its the first one we rotated to that extreme (still not zero, it still has 10 degrees of difference between innner and outer tire angles) And the front roll center is a separate mod, no kit for that just custom labor $150+return shipping.
Tommy does not have the new LCA, and I do so thats an independant mod too, compromise being you will loose negative camber ability without a longer LCA while having the roll center adjusted knuckle.
Sure do prevent over centering. The only downers are the ADD bumpsteer
Not sure if we are on the same page but the toe change under suspension compression is less than one degree with the current setup.
There was some pictures clearly showing both wheels on previous pages.
Next event is at the end of next month so maybe we'll get some cool action shots.
Thanks!
anti-squat, best thread ever, kpi, roll center, steering angle, suspension
