this looks like its gonna be a blast to drive! even though it wont have an astounding power/weight ratio its still gonna be smooth and predictable, assuming the f/r weight balance turns out alright. also with a heavier overall car their will be allot more suspension response wich is good for learning, wich is what this car is being built for if i remember correctly... Hell i couldnt drive for shit on twisties untill i sold my civic with coils and started driving my parents q7 on backroads, thats the car that taught me how to manipulate suspension, now i get to apply it to the s13 im slowly but surely building, wich is a stripped and has a lightweight ca tucked as low and far back as i could get it, very nice balance!
![]() Join Date: Apr 2005
snow are AWESOME...but salt's are not.
I only have the subframe powdercoated but everything else are either painted or came like that from SPL. and OH GOD..I HATE WAITING FOR THE RIGHT PARTS!!!! I NEED OVERNIGHT PARTS FROM JAPAN!! ![]() I NEED MY WHEEL FXXKING BEARINGS!!!!! |
#13 |
Update time!
Tomei 2way Diff ![]() Putting the ring gear on ![]() Clean the pumpkin with solvent ![]() Unfortunately, the pinion spacer is messed up and it seized the bearings when I tighten the pinion. So I went home and finish off my front suspension assembly. SPL tie rod ends Tein Z33 tie rods New sway bar linkage New steering rack boot ![]() Finally have the new wheel bearings pressed in and painted my drift knuckle. ![]() I have everything installl ![]() Oh wait...the studs from the SPL tie rods doesn't fit my knuckle!!! Great..I thought they are the same as z32 but I guess not, so SPL told me they will send me a pair of S13 one. ![]() Rear is the same..I have the sway bar bolted on with new linkage ![]() Car is still on jack stand..alignment is super out of wack that I can't even install my front sway bar. ![]() Test fit my wheels.. ![]() ![]() Unfortunately I haven't received my spacers from PBM yet to clear my brakes..so I can't put them on yet. I am still waiting for my tires for the TE as well.. Last edited by C-unit; 10-24-2010 at 01:15 AM.. |
#17 |
![]() You the cone shape thing that suppose to sit in the knuckle and then you put the nuts on top to tighten it. Well, that part doesn't fit the knuckle as it was too wide. |
#24 |
More update!
Took the car back to the shop! I have the tires mounted 245/35R18 18x10+20 plus 20mm spacer 265/35R18 18x11 -1 plus 18mm spacer I also have the rear fenders pulled yesterday. I am so tired from moving everything to the shop so here are some teaser. I will have full update after halloween! ![]() ![]() |
#25 |
Truly nice work man. Top 5 fav builds yet. Individuality is what this sport is all about. Not having the same boring motor and same boring dildo shift knob everyone seems so desperate to have. This is an awesome car with quality parts and a solid commitment to the build. This will be epic when its finished. Keep up the good work!!!
As long as u stay away from the sit and spin shifter so many people seem to use..Were all good! lol ![]() |
#26 |
![]() Join Date: Jul 2009
![]() Feedback Score: 17 reviews
Your avatar offends me.
http://thatistupid.tumblr.com/ |
