10-04-2016, 07:24 PM | #151 | |
On the setup i just did . I was aiming for .200in but it the end the machinist that did my spacer wasnt 100% on my specs ... we ended up with .300 air gap and its perfect on our set-up We Installed everything and he drove away . I Was happy i didnt had to fuck around to make it work like the first setup i did ... do it once , do it right
AV FABRICATION Built thread sr20vet s14 http://zilvia.net/f/showthread.php?t=535574 |
10-04-2016, 08:12 PM | #152 |
Yeah so I guess I'll have to wait and see if the maz housing uses the same parts and requires the same mods as the sr20 housing for the giken twin disc.
Sent from my iPhone using Tapatalk |
10-06-2016, 09:14 AM | #153 | |
I could help you out
10-20-2016, 12:29 AM | #155 |
my Gktech swaybar just got in last week and WOW !!! Quality of there parts is way over my expectation everytime
my car is schedual to go at AvFab for the cage and chassis prep in the next month ... things will go fast once its over there
11-06-2016, 07:18 PM | #156 |
Why do you need to use a solenoid relocation if you have Custom made VVl lock pin vvl killer? isnt the solenoid used to lock the pin at your desired RPM? Why wouldn't you just block off the holes? Still trying to learn about this head swap before I get it.
11-07-2016, 09:22 AM | #157 |
rbs14kouki - Will you please post how the sway bar endlinks attach to the lower control arm? I am very interesting in this setup. I have the GKTech FLCA's so I assume this will work with them.
IG: @scotheocelot |
11-07-2016, 06:48 PM | #158 |
ill keep the mazworx plate in the back of the head but all the holes are gona be blocked ... im not gona run the vvl relocation kit .
11-07-2016, 06:50 PM | #159 | |
on the right of the tie rod stopper ... you have 3 holes ! the endlinks bolts in there ... i guees they make 3 position for different size swaybar !?!? that im not sure
11-07-2016, 07:21 PM | #160 | |
I figured that might be where it mounts. Can you post the endlinks that come with the bar at some point?
IG: @scotheocelot |
11-10-2016, 02:52 AM | #162 |
they dont give a end link with the swaybar ... ill just by a set of sikky or something like that (pillowball) to finish the set-up
04-08-2017, 04:50 PM | #164 |
here is an update in the car . slow process sorry guy's
The cage is in process at #avfabrication . We made good progress in the last 2 weeks even tho we only work 4hours a week on the car . With the shop almost at full capacity and with big project cars, its just normal that we only work on my car on the sunday's ... clients come first and leave pleased from the shop , that's our number one goal . Next step is to had some more bracing and then drop the cage to weld the top . After that we attack the transmission tunnel and seat position before finishing the rest of the cage .
04-17-2017, 08:52 PM | #167 |
People are getting $430 for P12 cams? Jeeze, I sold mine for $300
Nice build, similar to mine (VE head, 350 trans, lots of GKTech parts)
My S13 SR Street Mod Build |
04-28-2017, 10:47 PM | #168 |
Yeah since nissan doesnt make them anymore they go for more then that now ... i got lucky with my set a 400$ if i ever change its for some 184st but i make my engin start and run before upgrading again hahahajhaha
11-23-2018, 01:54 AM | #169 |
I just updated my first post to what the list of parts that are on the car as of today ... i will update with pictures soon
I know my built is taking way to long but a separation with my ex. Selling my house loosing shit tone of money just to get a new start . It got me good but im back on my feet now and ready to finish this once and for all
12-05-2018, 08:17 AM | #170 | |
12-05-2018, 08:51 AM | #171 | |
02-07-2019, 05:00 AM | #173 |
I Parted out my sr20vet to built a 2.2 bottom end and i had a spaire head laying around that i wanted to built with kelford stuff and aftermarket shimless valves (after a saw JP r&d on the supertech vs Kelford springs) ... i couldnt convince my self to take appart a perfectly built bottom end to sleeve it and change my head completly after all those hours in it .... it sold it self for my asking price localy in 2weeks
Now building the spaire block to 2.2 and we should be good to go . Ordered all my electronic for the car too ! Biggess financial error hahahaha but ffff-it im pump about whats coming Motec: M130 (gpr package with stage 2 loging) C127 dash Tc8 egt box And my all ready purshace pdm15 2019 here i come
02-14-2019, 04:03 PM | #174 | |
