06-06-2013, 07:13 PM | #2431 |
okay guys I think I found something but again bigger... let me know what you think.
18x11 et-11 18x12.5 et-12 What size over fenders would I need these would be going on an s13 Tires: 245/35/18, 285/30/18 Also how much camber if any needed? and or different tire set up? Input please! Thanks again! |
06-07-2013, 10:59 AM | #2432 | |
Man w/ CTSV & a Car Seat
"FUCK NO. Even with tubbing it, kiss your full lock to lock turn". And stop trying to put on beach ball sized tires on a tiny ass wheel welled S13. Do you even read anything I've posted up or am I wasting my damn time? Fuck it...you know what, buy it and make it fit. It will fit if you don't lower it...enjoy the DONK Status. |
06-07-2013, 11:17 AM | #2433 | |
Still running the same wheel setup, 18x9.5 +5 (effective) in the front and 18x9.5 +20 in the rear - but finally swapped the front tires to 215/40/18. No other changes other than replacing the tension rods and the car rubs much, much less. Certain long sweeping turns still lead to the tire hitting the top of the well, but otherwise, it's pretty radical. |
06-07-2013, 02:34 PM | #2434 | |
Last time was 19's!!! Lol theses are 18's I looked around and seemes like it would fit, I'm not sliding with them they are just for a slammed wide body dd.. |
06-08-2013, 08:21 PM | #2435 |
20mm s14 Origin front fenders with Varreston 18x10.5 +15 on 225/35
Do you guys think it will sit flush? I have a 25mm spacer but that might be to much.. maybe a 10mm-15mm ? edit: on fortune coils lowered- |
06-08-2013, 09:26 PM | #2436 | |
If it was on an S14, maaaaaaybe if you can dial the offset exactly to clear suspension and not rub. S13, no way in fucking hell...I'll give you a hint, 9.5j is the most you want on an S13 front. If you run a 10j, expect to rub all over the place if your wheel well isnt tubbed. You go 10.5j or larger, you're a retard. But like I said, the fuck do I know...not my money or my car. |
06-09-2013, 01:02 PM | #2437 |
I have a s13 with feal coilovers with no adjustable arms. I would like to run 18x9.5 +12/18x10.5 +15. I don't mind pulling or rolling fenders can you guys guide me. Tire size would be 225/40/18 and 255/35/18
I looked through about 10 pages but don't have time to read 82 pages of this thread. TIA Chris |
06-10-2013, 11:27 PM | #2439 |
S13 Coupe with +30mm Front and Rear overs. 18x9.5 +15 wheels. Looking for tucked tire, stretched "flush" but functional fitment with minimum to no camber rear, negative camber front.
What size tires should be purchased? |
06-11-2013, 12:03 AM | #2440 | |
18x10.5 +17 235/40 falken ziex fenders rolled n pulled very little to no rear camber -5 deg front Untitled by 2tone89?, on Flickr |
06-11-2013, 02:05 AM | #2443 |
Hey guys, I'm gonna be installing some 18x9.5 +12 and 17x9.5+12 on my s13 coupe with stock fenders. Will these wheels fit with aftermarket struts and spring combo? kby struts and tein s techs.
I was thinking about running some 215/40/18 and 215/40/17 in front. |
06-11-2013, 08:02 AM | #2444 |
Wheel Fitment Kings this is a question for you guys.
I have a Stockbody S14. I would like to know what offset I should run on... Front: 18x9.5 Rear: 18x9.5 Tire size is 225/40/18 (Only until these wear out (Bridgestone RE760's) then switch to 235's) I am looking for a Clean fitment (No poke or Sunken battleship) just even with the fenders. I have fully adjustable suspension and would like to keep my Camber at my current settings. Front (-1.2 Degrees) Rear (0.6 Degrees) Ive been reading threads and the correct offset would be around +15. But please let me know any suggestions and different ideas. I will roll my fenders.
06-11-2013, 09:28 AM | #2445 | ||
Trader Rating: (38)
Feedback Score: 38 reviews
Wide wheels with low offsets on STRUTS/SPRINGS? For the record, you should typically list specs from front to rear. Not in reverse. Will it fit? Yeah, sure but your wheels will be poking out because you'll need spacers to clear the fronts. Mexi-flush ftw. My input? Grab a set of coilovers and run the setup that you posted. It will work if you have adjustable arms for alignment purposes. Quote:
I think 225's are the ticket but 235's work too. |
06-11-2013, 10:11 AM | #2446 | |
06-11-2013, 10:17 AM | #2447 | |
06-14-2013, 06:43 AM | #2450 | |
You MIGHT need to run a hair more camber up front, depending on how 'flush' you want to be. Initially I ran my car at -2* up front and -2.5* rear. I'm sure that I could have gotten my rears back to stock with a bit more work on the inner fenders, but I was lazy. Also, at least for me, 225/40/18's were too big up front, no matter what I did they would still rub during compression and high steering angle stuff. I ended up stepping down to 215/40/18 and FINALLY don't rub (fronts are also 18x9.5 +5 (effective) at -4.5* camber) Here's my car with the 18x9.5 - 225/40 square setup: |
06-16-2013, 12:54 PM | #2451 |
My brain is hurting trying to do the math an figure this shit out so s13 fitment gurus help please.
Mickey thompson classic III what offset would I need to run for front and rear with a decent size lip. I want to stretch the tires and have slightly pulled fenders or over fenders.. kinda looking for a hella flush look.. idk , thx lol the american blot pattern equivalent is the 5.4 my options are 15X8 5X4.53 5/8 -22 mm 15X10 5X4.53 5/8 -45 mm 16X8 5X4.5 4 1/2 0 mm |
06-17-2013, 11:56 PM | #2452 |
I guess I should say can I run 16x10 -25 offset with 4 1/2 backspace f/r on a s13 coupe .. I need to know because I have to order the wheels so I cant test fit them. Thx
06-19-2013, 11:24 PM | #2453 | |
06-20-2013, 10:41 PM | #2454 | |
This is Exactlywhat I need to know. Much appreciated sir.
06-24-2013, 06:39 PM | #2455 |
Quick question, Just bought some 17X9 +25 wheels. I have agx with lowering springs.
What size tire would you guys get for this set up? I want same size tires all around so I can rotate. oh and I have a s14 |
06-24-2013, 08:57 PM | #2456 |
What are you trying to do with the car? Personally, for those sizing, I'd want a squared 245/40-17 setup.
I can't find a close up picture of it but this was my grip setup on 255/40-17 NT01s on 17x9 +22 Same wheels when I first had them on the wife's R33 but with 245/40-17 |
06-25-2013, 05:11 AM | #2458 |
18x9.5 +12
235/40/18 Will it fit on s14? How much fender mod needed How much camber? I am running 225 now but want to go wider Anyone with 235 setup all around pls post pics
240 with illegal engine mod. |
06-25-2013, 05:18 AM | #2459 | |
The car will be used just as a daily. No track. So 245/40R17 won't require any fender modification for the front or rear? Thanks for the quick replies |
