#241 |
![]() Join Date: Nov 2008
Im pretty sure this has all been covered in this thread. I cant remember who it is but someone on here uses a maxima ecu.
I think the pins that need swapped is just a firing order thing. I think you have to change a few of the coil wires and a couple of the injector wires. Nothing major. If someone has it handy post it up, if not Ill see if andy can post up. |
#243 |
I used to know off the top of my head but since I dont really ever intend to own a rb (im not a fan unless I can ever come across a r32 gtr with the proper paper work for a decentish price) I tend to forget it.
I think you might find something on jim wolfs site about it possible. Or a google search for z32 ecu on a rb |
#245 | |
I plan on sending my board to you guys to have the daughter board soldered in. Could you guys also toss me a consult port just in case I need to wire mine up? Thanks |
#246 |
When you order youll just need to communicate that you need one at that time. I dont know if they will be available at that time or what the cost would be. Your car will have the port in the fuse panel and it can be removed and wired directly to the ecu if needed so you really shouldnt need one from us. We try to grab as many as we can when possible from the junk yard or whatever but we have run out of them before and your car will have one.
#247 | |
Thanks. |
#248 |
Man, I dont advertise on here so I have to tread very lightly about sales related things. Luckily for me I can answer your question honestly, I have no idea! lol
Your best best bet with the sales side of things would be to just send an email or leave it blank (which if thats wrong Andy will contact you) or leave a comment or something. I have obviously never had the need to order from the site, and I personally have nothing to do with sales, pricing, ordering, shipping ect. Im completely disconnected in that respect. All I do really is the tuning locally for the guys close enough to make the drive. If people have questions about the software or need some suggestions the call or email goes to me, and I answer questions about the capability and functionality on forums. Thats as far as I go personally. I personally have no monetary gain from sales and really dont whats involved and I apologize for not being able to give strait answers on that. Once you do get nistune setup and going, This thread is a good place to reach me and others if you come across any questions. |
#249 |
2.5 Download the pdf on the install instructions and head over to a TV repair shop. I had a guy do mine localy for $25.
95 240sx RB20 415whp 91 Nx2000 VVL yo |
#250 | |
My best suggestion though is to make sure they read it properly and understand it. Yes, they do things more tricky than this daily but for some reason we do still get ecus that dont have the jumpers moved, or moved to the wrong spot and or burnt traces. There is no excuse for this but it does happen. |
#252 | |
Exactly what i need you guys to do for me. Load a s1 RB25 base map with my supporting mods. You've done it previously for me and i know for a fact a TV repair shop can't do it lmao. |
#253 |
Nope no map sensor for nistune. NismoTronics will support map and a host of other upgrades when they release the firmware update. Tho it's only for the SR20 ODB1 ecu's.
#254 |
![]() Join Date: Feb 2007
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
Doesn't support MAP, but if you have something similar to a LM2 wideband you can add a map sensor to tune with and so to speak put a face to the "TP" values.
#257 |
![]() Join Date: Mar 2009
![]() Feedback Score: 9 reviews
I just bought a nistune ecu used from a local enthusiast
It's a type 4 board, he was running a s13 Kat. i have a 96 obdii kat, so does this plug and play? I don't think it will, but I already have a step down harness from empathy. Not installed. Will I need an obdi port to communicate? |
#259 |
![]() Join Date: Jun 2012
I love my nistune
One question, I have a converted wire harness and a sr20det blacktop. My question is....... 1- do I need a intake air temp sensor. 2- if yes do I have to tap into a ic pipe, or can I just mount it near the air filter..? Basically what is going on is, I got the nistune. Ran great till about a few weeks ago. Found my B.O.V was loose, the hose that connects bov to ic pipe rubbed through. One ic hose connector had a small hole, So checked replaced, and tightened all my clamps, now.... I'm running rich... |
#263 |
Nistune.com
#264 |
Would NIStune improve gas mileage for a daily driving aspect? Car is NOT a track car and never sees anything above 50% throttle and mostly city driving. Gas mileage is horrible atm (200 miles to a full s14 tank w/ stock RB25)
#265 |
Looking for sum one to tune my nistune but alot of shops that did do it are closed :/ anybody knw where I can go?? I've check the threads and called around but no luck.
Thnks for the help |
#268 |
![]() Join Date: Jan 2010
![]() ![]() ![]() ![]() Feedback Score: 10 reviews
yellow, whats shaking. sorry your fuel mileage sucks that bad.
http://www.240sxforums.com/forums/rb...ject-s-rb.html |
#269 |
Jim did you check out the calibrated maf sensors? Should make tuning for big power way easier now with the nistune.
