Old 11-03-2013, 01:18 AM   #1
hyper_boi
hyper_boi is an unknown quantity at this point
hyper_boi is offline   Reply With Quote
Old 11-03-2013, 06:45 PM   #2
StatticMyke
StatticMyke's Avatar
StatticMyke is an unknown quantity at this point
slideways40- very nice man. perfection.
StatticMyke is offline   Reply With Quote
Old 11-04-2013, 08:06 AM   #3
motteramm
motteramm's Avatar
motteramm is an unknown quantity at this point
Well here is my KA-T, on my 95 s14, still need to tuck and paint the bay :/
[IMG][/IMG]
"I have no cupholder"
motteramm is offline   Reply With Quote
Old 11-05-2013, 01:41 PM   #4
EnemyS15
EnemyS15 is an unknown quantity at this point
how hard was it to apply? I have the gold dei stuff. Very adhesive? How bendable and flexible is that? able to get into creases pretty easy? How many strips did you have to cut to get that all in? I might go and redo my firewall with this. just for fun.
Check out my build thread! http://zilvia.net/f/builds-builds-on...rhd-build.html
EnemyS15 is offline   Reply With Quote
Old 11-12-2013, 10:58 PM   #5
street_sleeper
street_sleeper is an unknown quantity at this point
Here is where I got mine from. Made in USA. Ships quick.
Lava Mat Adhesive Backed Heat Shield Mat by Heatshield Products - Lava Mat Adhesive Backed Heat Shield Mat by Heatshield Products 60" x 48"
It took about 4 hours to apply it right. I wanted to get it done in one shot. I used two pieces vs breaking it up. I wanted to make it seems as though it was one sheet and with a thin strip to cover where they meet in the middle (which is covered by the motor anyway). Get a torch. I bought one that is self starting propane for like $30.
Remove everything from the fire wall. Done worry about bolt holes. Once its on just shine a flash light from the inside and you can see them. If you lay it down tight enough you can run your fingers across it and ling them.
Grab some newspaper and lay it on the firewall. Make a template. Lay it on the lava mat. Cut out and hold it up to see if you can trim a little more. Then grab the torch and heat up the firewall and run the flame over the lava mat for only a few seconds, then peel off the back and apply it in the far corner. Once it is on, its on. With heating up the firewall and the material it makes this process very smooth. I held one end with my left hand and basically rubbed it down with a rag. It fit very well around the contours of the firewall.
street_sleeper is offline   Reply With Quote
Old 11-05-2013, 01:49 PM   #6
PeaceOnesxWai
PeaceOnesxWai's Avatar
Trader Rating: (34)
PeaceOnesxWai is an unknown quantity at this point
Feedback Score: 34 reviews
^DEI gold shield is not flexible at all.. you need about $200-300 worth of gold sheet to cover the entire firewall. Make sure you get everything out the way before you apply, that stuff looses its adhesive after the first application.
I heard the silver heat shield is half the price and twice the resistance of gold, look it up. Gold is really just for show
PeaceOnesxWai is offline   Reply With Quote
Old 11-05-2013, 01:54 PM   #7
EnemyS15
my dei heat shield was flexible, just was TOO flexible... too many creases when trying to smooth around a corner. But the price you are talking about it absurd . I spent maybe 130$ on 2 - 24x24 sections and I covered my entire firewall and frame rails approx 8 inches from the firewall. And I still have a small square left over.
Edit: From what I see, the lava mat is about 10-15 $ cheaper than dei gold. So there's not this huge difference in terms of money between the 2.
Old 11-05-2013, 05:04 PM   #8
jr_ss
Engine bay is complete... I may have a few things I've looked over, but nothing will change visibly.
Old 11-05-2013, 06:40 PM   #9
franklin93zx
franklin93zx is an unknown quantity at this point
I really need to clean this thing...
Originally Posted by deolio View Post
tucking rim looks clean and is just classy as fuck.
franklin93zx is offline   Reply With Quote
Old 11-08-2013, 11:55 PM   #10
Memberofthe600hpkaclub
Memberofthe600hpkaclub's Avatar
Memberofthe600hpkaclub is an unknown quantity at this point
Memberofthe600hpkaclub is offline   Reply With Quote
Old 11-09-2013, 01:30 AM   #11
PoorMans180SX
PoorMans180SX's Avatar
The latest in the evolution.
Old 11-12-2013, 10:56 PM   #12
street_sleeper
Old 11-22-2013, 07:06 PM   #13
tricky_ab
tricky_ab's Avatar
Old 11-22-2013, 07:57 PM   #14
yetijeff
yetijeff's Avatar
yetijeff is an unknown quantity at this point
Originally Posted by tricky_ab View Post
That's nutty. Turbo->supercharger? Wild
yetijeff is offline   Reply With Quote
Old 11-22-2013, 08:30 PM   #15
jduke
jduke is an unknown quantity at this point
jduke is offline   Reply With Quote
Old 11-25-2013, 06:32 PM   #16
noskcaj
noskcaj is an unknown quantity at this point
Finally took some pictures of the engine bay. Its a blueprinted ls1 w/ P&P heads, MS3 cam, ud pulley, LS6 intake, etc.
noskcaj is offline   Reply With Quote
Old 11-29-2013, 02:09 PM   #17
PoorMans180SX
A hazy vision of the distant future.
Old 11-22-2013, 08:37 PM   #18
240ss
240ss's Avatar
240ss is an unknown quantity at this point
How does that thing perform? quite interesting indeed
240ss is offline   Reply With Quote
Old 11-22-2013, 09:10 PM   #19
johnathanz32
johnathanz32 is an unknown quantity at this point
ill play my engine bay on my 800whp TTz32
johnathanz32 is offline   Reply With Quote
Old 11-23-2013, 04:43 PM   #20
Bushido
Bushido's Avatar
WOW^ where did everything go?
Old 11-24-2013, 11:30 PM   #21
s14fbs
s14fbs's Avatar
s14fbs is an unknown quantity at this point
Send a message via AIM to s14fbs
s14fbs is offline   Reply With Quote
Old 11-25-2013, 09:43 AM   #22
SlideOrDie831
SlideOrDie831 is an unknown quantity at this point
damn, that Z32 bay is clean as hell.
SlideOrDie831 is offline   Reply With Quote
Old 11-25-2013, 04:40 PM   #23
yetijeff
yetijeff's Avatar
+1 doesn't even look like it runs lol
Old 12-03-2013, 11:10 AM   #24
eklips3
eklips3's Avatar
eklips3 is an unknown quantity at this point
The latest before I put it away for the winter
1992 240sx (RB20. 362whp@16psi)
eklips3 is offline   Reply With Quote
Old 12-03-2013, 05:55 PM   #25
Dolph_KYAS13
Dolph_KYAS13's Avatar
Dolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond reputeDolph_KYAS13 has a reputation beyond repute
Got rid of the stock coil pack cover and got myself a matching oil cap
-Jordie Lewis
'93 Skyline Type M
Dolph_KYAS13 is offline   Reply With Quote
Old 12-03-2013, 06:34 PM   #26
eklips3
eklips3's Avatar
^^^ Nice!
msglgnth
Old 12-03-2013, 06:47 PM   #27
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
Not mine but its a freaking good kick in the ass to finish my ve set-up !
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 12-03-2013, 08:24 PM   #28
kyle1a2
kyle1a2 is an unknown quantity at this point
^omgomgomgomgomgomgomgomgomgomgomgomgomgomgomgomgo mgomgomgomgomgomgomgomgomgomgomgomgomgomgomgomgomg omgomgomgomgomgomgomgomgomgomgomgomgomgomgomgomgom gomgomgomgomgomgomgomgomgomgomgomgomgomgomgomgomgo mgomgomgomgomgomgomgomgomgomgomgomgomgomgomgomgomg omgomgomgomgomgomgomgomgomgomgomgomgomgomgomgomgom gomgomgomgomg
kyle1a2 is offline   Reply With Quote
Old 12-03-2013, 10:08 PM   #29
shogun!
shogun!'s Avatar
shogun! is on a distinguished road
My +700hp RS13
shogun! is offline   Reply With Quote
Old 12-04-2013, 10:49 AM   #30
Mikester
Mikester's Avatar
Originally Posted by shogun! View Post
Very shiny sir! I am a HUGE fan of aesthetics to go along with function- well done~
battery relocate
