09-17-2010, 06:36 AM | #2791 |
09-17-2010, 06:38 AM | #2792 |
09-17-2010, 02:38 PM | #2794 |
I have a 1990 240sx hatchback with konig rewinds on it. 16x7 with a 0 offset.
As of right now, its not lowered but whenIi go to do so what mods do I have to do to the car to make the wheels work with the car? Besides stretching/rolling fenders. I.e. new brakes..etc
I'd walk a thousand miles with a broken spine before i'd change my mind. |
09-17-2010, 04:21 PM | #2796 | |
Just btw, The tires are 215or205?/45/16
09-17-2010, 08:26 PM | #2799 |
I was wondering what vac line to tap into for my Boost/Vac gauge? I have a Freddy intake and I wanted to do it the right the first time. Thanks for the help
Edit I just tapped into the FPR Vac line Last edited by Deviance; 10-12-2010 at 02:04 AM.. |
09-17-2010, 09:22 PM | #2800 |
Are these coupe trunk cloth thing uncommon or something? Every coupe I've seen never has it. My stock coupe didn't have it, maybe because it's an SE with spoiler? Anyone want to chime in that has it or seen it?
09-18-2010, 04:36 PM | #2801 |
it's something that is lost through out the years, just like the sunroof covers and all that.
street dancer. GLEAM |
09-18-2010, 04:37 PM | #2802 |
Does anyone sell the roof spoiler/rear window visor that is plastic and SEE THROUGH. I don't like the frp/cf/kevlar ones, i want something that i can see through, kinda like the window visors and what now. Its like a dark tinted plastic
09-19-2010, 01:09 AM | #2803 |
I havent seen anybody mention it but is there any way to make ABS work with the Z32 brake setup? I was talking with someone and they said only q45 and 180 setups keep ABS
Thanks |
09-19-2010, 02:32 PM | #2804 |
Help needed!!!
This morning I try to start my car and all I am getting is loud clicking noises, rpm jumps around also. What went wrong? I changed the battery, still nothing. Checked all my connections (starter, etc) everything seem to be intact. Can anyone tell me what went bad? Any advice will be appreciated thanks...
91 S13 Ka-t |
09-19-2010, 05:49 PM | #2805 |
quick question have any of you guys put s2000 ap1 rims on a s14? will it clear the hub..i dont care about the offset..i know i'll need spacers for those but just making sure the ap1 center bore rims is larger then the s14?
09-19-2010, 06:40 PM | #2806 |
Yanack ebrake kit install
Has anyone installed the Yanack rear inner drum e-brake cable kit or the GT-1 motorsports rear inner drum e-brake cable kit. I am preparing to install the Yanack kit and I was wondering what all is involved in it. Any pictures would be greatly appreciated.
-Brandon |
09-20-2010, 12:02 AM | #2807 |
Hello, I wasn't sure if this question was worthy enough to have it's own thread, so I figured I would ask here.
I recently bought an '89 Coupe from a friend, and it's got a brand new stereo in it. For some reason the stereo isn't working. Friend said he had bought the car like that, so he knows nothing about it. I had it looked over by a couple stereo experts and they came to the conclusion that it must be a bad factory amp. The stereo will turn on and everything but it's not making any sound. Everything is wired properly, the speakers are working correctly because it still makes that popping noise when it turns on and when you link two wires with a battery. Oh also it will sometimes once in a blue moon randomly start working. Only for a short time, then promptly stops again. Anyways, they said it was probably a bad factory amp and they didn't know where it was. I searched and searched for hours on the internet, Zilvia, Nico, Google, and I just couldn't find anything showing where it was located. I did find something on Nico showing where it is on the Hatch, but obviously that was no help to me. I even spent some time tearing up the car looking for it. Must be hidden pretty well, so if anyone knows where it's located on an '89 Coupe, please help! Or maybe if you think it's an issue with something else other than the factory amp, any info would be much appreciated. Thanks much
'89 Coupe |
09-20-2010, 10:46 AM | #2812 | |
09-20-2010, 10:46 AM | #2813 | |
09-20-2010, 10:56 AM | #2815 |
Dont quote me on this, but I believe the butterflies are there for better response at low rpm. Removing them would allow for better high end, at the sacrifice of the low rpm response. Basically if youre going KA-t, your whole powerband is gonna be in the upper rpm range, so you might as well remove the butterflies to aid in that. Keeping them would be like adding parts for high end, while retaining the restrictive parts aimed at better low end. Kind of contradictory. At least, thats my understanding of it.
09-20-2010, 11:41 AM | #2816 |
Trader Rating: (32)
Feedback Score: 32 reviews
anyone think this set up is safe?
s15 T28 @ 14psi(too much for stock headgasket?) or should i do 12-13psi? stock redtop 480cc injectors n60 maf fmic electric cutout at downpipe getting dyno tuned by EMANCE HALP!! |
09-20-2010, 12:15 PM | #2817 |
Rather then just reposting the same parts list that I've already replied to, why dont you elaborate on what exactly you want us to tell you? Obviously my response was less than satisfactory, so why not post some specific questions that I can give a more detailed response to. You sound like a little kid going "are we there yet?"
09-20-2010, 01:31 PM | #2818 | |
Trader Rating: (32)
sooo 14psi it is. Thanks man! |
09-20-2010, 01:41 PM | #2819 |
