Old 02-04-2006, 11:13 AM   #1
blown331
blown331 is an unknown quantity at this point
Over heating problem! From head swap??
I did a search and couldn't find anything about this, so here goes....
Did a head swap on my '95 240sx. I replaced it with a freshly rebuilt one. However, when I was bolting it back on the valve cover didn't fit. Therefore I got a head with a different casting number! So, I went and found a '91-'93 valve/timing chain cover and it seems to have bolted up fine! Now, my car overheats! I have a new t-stat, waterpump, timing chain. I am thinking that it could be the head gasket (although the fitment seemed good). What do you all think or is there something else I need to do.
BTW, the casting number on my stock head 70f and the new head is 53f.
Thanks for the input!
blown331 is offline   Reply With Quote
Old 02-04-2006, 11:30 AM   #2
nrg
nrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud ofnrg has much to be proud of
Send a message via AIM to nrg
You warp the head because you torque it down wrong. have fun.
driftingisgay.com
nrg is offline   Reply With Quote
Old 02-04-2006, 11:53 AM   #3
blown331
What exactly does that mean? A warped head is causing the overheating? Trust me, I am having fun!
Old 02-04-2006, 12:07 PM   #4
DrtyRat
DrtyRat's Avatar
DrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfectionDrtyRat is close to perfection
yeah if the head is warped then it won't seal properly w/the hg...take the head to a machine shop and get it resurfaced if thats the prob
DrtyRat is offline   Reply With Quote
Old 02-04-2006, 12:12 PM   #5
blown331
trying to figure out why would it be warped, its a fresh reman. head.
Old 02-04-2006, 07:48 PM   #6
bb4_96
bb4_96 is an unknown quantity at this point
meesing around with different heads will get you in trouble. Think about all the engines nissan has made. you can botch the head by improper torquing so lay a rule atop the head on the mating surface and check with a feeler gauge to see if it's straight. otherwise...
bb4_96 is offline   Reply With Quote
Old 02-04-2006, 08:39 PM   #7
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
''bb4 96'' is right. Different heads have different cooling ports that may not line up with your block, restricting coolent flow. If you have the head off, check the cooling ''holes'' to the head gasket, and match them to the block. You probably are missed matched. BUT, Easy first!!!!! Rebleed the cooling system!!!!! We've all been through that hoop!
NIK90s13 is offline   Reply With Quote
