Steering wheel shaking during braking over 70mph
I have a '95 se that has z32 30mm aluminum calipers with heavy throttle slotted/dimpled drilled rotors on the front w/ss lines and stock brakes on the rear. I have ABS/VLSD. I am having a problem with the steering wheel shaking during braking over 70mph. The steering wheel would shake at 65+ sometimes when not braking and sometimes during. I had the tires balance and a 4 wheel alignment and the shaking went away when not braking but it is still shaking during braking over 70. I also noticed that there is a clicking noise in the steering wheel, though, the steering feels the same as before. I think the car is still pulling to the left which it was before the alingment. I had the right front tension rod bracket replaced because I bottomed out on it or sometime a yr ago when I hit a curb hard on the left side. The place that worked on it said the car was fine just that one part was bent. After they did the alignment/balance they said the car drove good which was 2 wks ago. So I am not sure what to do now. The car defitnely drives better but I still have the vibration during braking at high speed.
