Old 02-20-2006, 10:58 PM   #1
Loofee95SE
Loofee95SE's Avatar
Loofee95SE is on a distinguished road
Send a message via Yahoo to Loofee95SE
electrical
What's up guys. I just bought an 89 coupe, automatic, base model. here's what we did to it. We put ka24de from a 96, 5 speed swap. The engine fire up and everything, BUT none of the electrical work. The only light that come on is the headlight, however, the head light doesn't flip up. We are using the top harness from 1992 240 5spd and the lowe harness from the car. The light didn't came on since we got the car. Also, the battery light is on as well. We check all the fuses got voltage but still no light at all(interior, brake light, signal lights, dash light, blower, absolutely nothing.) what do you guys think? After 3 days of work . I just can't think anymore. Please help
I need more Boost!
Loofee95SE is offline   Reply With Quote
Old 02-20-2006, 11:07 PM   #2
blazin13
blazin13 is an unknown quantity at this point
try checking the dimmer switch to see if its plugged in. thats a common for control for your interior lights.
blazin13 is offline   Reply With Quote
Old 02-20-2006, 11:52 PM   #3
Loofee95SE
Loofee95SE's Avatar
how about all the other light? the headlight is also not flipping up or the stop light won't come on neither
I need more Boost!
Old 02-21-2006, 01:26 AM   #4
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
Wiring a 96 into an s13 is not an easy task.
Trust me. I have this horrid motor/chassis combination.
I would swap the head for an s13 head and electronics.
No fuss no muss.
Oh and if it's interior you're worried about, you need to splice in 2 plugs BESIDE the big ecu plug on the interior.
Maeda is offline   Reply With Quote
Old 02-22-2006, 09:47 AM   #5
Loofee95SE
Loofee95SE's Avatar
the engine harness is from S13, still need help. C
I need more Boost!
Old 02-22-2006, 11:42 AM   #6
Maeda
Maeda's Avatar
Are you listening?
Old 02-22-2006, 07:01 PM   #7
Loofee95SE
Loofee95SE's Avatar
Yes Maeda, I am. but like I said..its not JUST the interior lights..it is the entire car. the only light that work are the head lights... and it won't even flip up.
and which plug exactly are u talking about?? is it the plugs by the fuse box?? the only plug by the ECU that needed to be modified was the plug for the cluster ( which i modified that, like i did on any other swap I've done color match every wires). and I have never had this problems on other engine swap. C
I need more Boost!
Old 02-23-2006, 12:41 AM   #8
g6civcx
g6civcx's Avatar
My car did something similar to this. It was a bad voltage regulator. Got a new alternator and it worked.
How's your voltage regulator?
Old 02-23-2006, 12:48 PM   #9
Loofee95SE
Loofee95SE's Avatar
problem sloved, whoever had the car before I did, hack the crap out of the wiring harness, and 1 of it came lose . thanks C
I need more Boost!
