Old 02-22-2006, 09:24 PM   #1
Hartley1080
Hartley1080 is an unknown quantity at this point
Send a message via AIM to Hartley1080
Control Arms
Ok so i pressed out the bushings in my control arm before i got the energy suspension bushings and the instructions. Which state in large bold letters DO NOT PRESS OUT THE SLEEVE just the rubber bushings. So i can't get the sleeve back in without bending the control arm because i have already bent it trying to get the sleeve in. So now i need a new control arm just want to make sure and see if anyone makes a aftermarket lower front control arm. Yea before anyone else says it i am a dumb shit.
S14
Thanks guys,
Jonathan Hartley
Hartley1080 is offline   Reply With Quote
Old 02-22-2006, 09:31 PM   #2
pwhitersxs
pwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enoughpwhitersxs will become famous soon enough
Send a message via AIM to pwhitersxs
Try splparts.com, I hear they are very good people.
s13 sr20det
pwhitersxs is offline   Reply With Quote
Old 02-22-2006, 09:58 PM   #3
projectRDM
projectRDM's Avatar
You're not experiencing anything new. The Whiteline bushings come with new sleeves and require them to be pressed in, just like you're trying now. The problem is you haven't thought it all the way through.
Take a wooden block or similiar object and wedge it into the control arm at the farthest point back, keeping it fully spread out. Now you can beat the sleeve in with nearly anything and keep the arm from bending in on itself. Use plenty of lithium grease to guide it in and keep it from seizing.
Your only other options for a new arms are splparts at $580/pair, Cusco at $830/pair, or the Nismo at about $320/pair unless you go back with OE.
Old 02-22-2006, 10:02 PM   #4
gotta240
and try freezing the metal sleeve... supposedly it will shrink it a little so it will go in easier.
Old 02-22-2006, 11:49 PM   #5
SirWarrior
SirWarrior is an unknown quantity at this point
next time use torch to burn them out
92 FastBack - Project
98 SE - Daily Driver
SirWarrior is offline   Reply With Quote
Old 02-23-2006, 03:25 AM   #6
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
I did the bushings a while ago but I don't remember reading that on the instructions. I am pretty sure the bushings are a part of the sleeve.
Jung918 is offline   Reply With Quote
Old 02-23-2006, 12:13 PM   #7
Hartley1080
yea the bushings are a part of the sleeve but, i was supposed to just press out the bushings. Oh well you live and you learn thats how it goes. I am giong to try again tonight and put the block in the middle so i don't bend the control arm anymore. I just got super frustrated and couldn't think so as usual i came to good ole zilvia. Thanks for all the help guys we will see what happens. Those freaking spl control arms are badass thanks for the site.
Thanks
Jonathan Hartley
