Old 02-22-2006, 10:19 PM   #1
curbhuggerrps13
curbhuggerrps13's Avatar
curbhuggerrps13 is an unknown quantity at this point
Send a message via AIM to curbhuggerrps13
silvia oem brakes problems
i just installed some s13 silvia rotors and calipers....the install was perfect everything went smoothly...then when i bled the brakes with my buddy the brakes would hold stiffness. bled it bled it checked the lines no leaks...so im guess this may be a master cylinder issue but...the fluid comes out perfectly when we bled it.all lines were tighten securely.im wondering if this is a brake booster related problem...could i use the rhd booster on the lhd car.i looked at them and they seem to be the same. also since its bigger brakes and calipers am i just am lack of pressure with the stock cylinder? let me know.and btw i searched and there was nothin but 300 zx caliper conversion.if there is a link to faq about it too that would be great thx.
curbhuggerrps13 is offline   Reply With Quote
Old 02-22-2006, 10:36 PM   #2
g6civcx
g6civcx's Avatar
No, the RHD MC is only for RHD. The lines go the wrong way.
It's hard to say. I'm not sure if you bled it correctly. One little mistake and you'll be worse off than when you started. Follow the procedures listed in the FSM and bleed them in sequence. Do it twice to make sure there are no bubbles coming out.
Did you install the calipers the right way, with the bleeder screw pointed up?
Old 02-22-2006, 10:57 PM   #3
curbhuggerrps13
as i stated im not using the mastercylinder from the rhd ...i stated booster (booster) not mc ....im postive the needle bleeder is pionted up ..im not that idiotic. i started from rear passenger and worked my way around for 3 hours. i just need feedback on if the stock mc can handle the bigger calipers fine too. this isnt making me as stressed out as my hicas model though so thats a great thing.thanks for the reply g6civic but that isnt on the money
Old 02-22-2006, 11:01 PM   #4
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
if all fails....there a rod underneath the dash coming from the booster...u can adjust that.....its pretty much trial and error for this method....but only tighten or loosen just a little bit....good luck
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 02-22-2006, 11:14 PM   #5
curbhuggerrps13
bah! there is sooo much grease under there.that is not a good sign.in the morning tommorow im gonna pull of the booster and shoot it for a lil while and install my donor booster.n e one else do a s13 silvia oem brake install and notice a difference....the size is significantly bigger. thanks for the suggestion vut
Old 02-23-2006, 12:37 AM   #6
g6civcx
g6civcx's Avatar
Oh, my mistake. Sorry about that.
Yes, I have the JDM 180SX front brakes on there with the stock booster. It works just fine. Very firm pedal feel. Stops well. The calipers are the same as those that came on the mid-90s Altimas and Maximas.
The stock master cylinder leaks all the time so it's not a big surprise if yours is. Check up on this if you decide to open it up: http://www.advanceautoparts.com/engl...0020701bm.html
As far as LHD vs. RHD booster, I am not sure because I have no attempted this. You can try but be careful and read that link above before you try.
Maybe one of your calipers is leaking. Old crappy calipers will do that to you.
Good luck and let us know how it works out.
Old 02-23-2006, 01:39 PM   #7
curbhuggerrps13
turns out the booster went bad added with the driver side seal to the caliper leaked. i ahve to drop it off in anaheim to have a repair gasket kit custom made...unless someone else knows where i can get a kit for it. either that or i need someone with a spare driver side caliper for sale.either way my car is undriveable . should i repair them or should just go with stock ? i dont know if its worth all this trouble for an inch more of rotor...but a inch more is a inch more of cooling and sruface area. when i got the front clip the brakes were pretty clean as far as i can tell. but oh well. oh also the upgraded rotors seem to make friction with the dusk guard....should i hammer it back or dremel a tad bit off. jw about ur setup.thx
Old 02-23-2006, 01:58 PM   #8
g6civcx
g6civcx's Avatar
That's par for this course. Old crappy brakes will do that to you.
Every little bit helps, but stock brakes with good pads and discs will stop much much better than Z32 brakes with crappy discs and pads. I think at this point it's easier to go with stock if you still have them instead of trying to fix it.
I just took off the mud guard completely. If you want to keep it, you have to trim off the edges as it won't clear the bigger disc.
See if you can get a rebuild mid 90s Maxima/Altima caliper. They should be the same, but compare the two to see if you can use them. Rebuilding the caliper yourself isn't worth it if you can get rebuilt ones from the store.
Old 02-23-2006, 07:22 PM   #9
curbhuggerrps13
i called like 5 different shops in riverside and ...pretty much 951 area...and everyone said 240sx? and i said silvia! and they said whats a silvia...bwahahaha.ill check into the nissan altima caliper.thanks for the suggestion....might just go back to stock if worse comes to worse. oh the pads on the brakes are cermamic and the rotors have been resurfaced.
Old 02-23-2006, 07:24 PM   #10
g6civcx
g6civcx's Avatar
Of course. Don't say Silvia. A general repair shop won't know what it is. Just go to an auto parts store and get a rebuilt mid 90s maxima or altima caliper.
Old 02-24-2006, 12:05 AM   #11
SRprelude
SRprelude is an unknown quantity at this point
stop being a wuss and get Z brakes. theres almost no difference in stopping power with silvia brakes. Ive had Z brakes for 3 years and seen friends get silvia brakes,q45, altima or whatever, then kick themselves in the ass when i outbrake them in every corner.
Cool story Hansel.......
SRprelude is offline   Reply With Quote
Old 02-24-2006, 02:05 AM   #12
curbhuggerrps13
wuss? im sorry im a wuss for being poor .stock brakes went bad had access to silvia ones for free...so i tried it and yes i am kickin myself in the ass for it. as of now i actually am lookin into z brakes. but heck people charge up the ass for them...and i had no luck with them in the junkyard. but i keep on telling myself...lucky i got rid of the hicas model a few years back...parts were rediculously high and hard to get. thanks for the input fellas after i manage my finances i might say hello to some z brakes...hopefully
