Old 03-26-2006, 08:21 PM   #1
HootAuto
HootAuto is an unknown quantity at this point
SR20 wont shift into gear...
Guys, I know you think i'm retarded, but my damn trans (SR20DET) won't shift into gear with the car running. Turn it off and it shifts fine. Start it in gear with the clutch pedal down and it launches.
Pulled the trans down to check the pressure plate, all I see is heat scoring. Put a KA slave cyl on it (right part or no?) and checked the fluid to make sure there were no gear/syncro parts in it. Throwout bearing still spins fine and looks to be in good condition.
Need some help people, help me out!!! Putting an 89 Maxima clutch kit in anyways just because I already bought one.
Hoot Automotive Technologies
www.hootauto.com
703.509.2242
Check out my Group Buys and Specials!
http://www.zilvia.net/f/showthread.php?t=103985
http://www.zilvia.net/f/showthread.php?t=103935
HootAuto is offline   Reply With Quote
Old 03-26-2006, 09:48 PM   #2
smithers584
smithers584 is an unknown quantity at this point
well it sounds like your clutch is not disengaging. if you already replaced your slave, then change your master. while you are doing that get a stainless steel line and take that second bleeder box out with the looped tube and run the fitting straight from your master to your slave. then bleed properly. also, you cannot look at a pressure plate and tell if it is good or not as far as the pressure it obtains. so if you have your tranny off, then go ahead and change that shit cuz you know what a pain in the ass it is to get the tranny off.
smithers584 is offline   Reply With Quote
Old 03-26-2006, 09:50 PM   #3
smithers584
i think that you should take out your clutch and say screw it and then try to shift. I bet that will work or maybe you could get an automatic. That might help too.
Old 03-26-2006, 09:58 PM   #4
smithers584
sorry, i got up to use the bathroom and my wife typed that. she gets a little jealous because i spend to much time on zilvia.
Old 03-27-2006, 01:45 PM   #5
X the big hit X
X the big hit X is an unknown quantity at this point
hahahaahhaha
X the big hit X is offline   Reply With Quote
Old 03-26-2006, 10:20 PM   #6
HootAuto
already replaced the clutch, waiting to put the trans back up on tue when I have access to a lift....if the master was bad, the slave wouldn't work though, I've watched it work, so it's not a hydraulic problem. Any other suggestions?
www.hootauto.com
703.509.2242
Old 03-27-2006, 02:35 AM   #7
SR20d2fourT
SR20d2fourT's Avatar
SR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura aboutSR20d2fourT has a spectacular aura about
Did you bleed the slave cylinder? Same exact problem w/ my friend and we did that and it worked.
My opinion gives me redboxes
SR20d2fourT is offline   Reply With Quote
Old 03-27-2006, 11:18 AM   #8
HootAuto
of course I bled it....tried bleeding twice but still nothing....
www.hootauto.com
703.509.2242
Old 03-27-2006, 12:00 PM   #9
Dousan_PG
Dousan_PG's Avatar
clutch stuff is pretty simple
if you got hydrolics then the clutch install is wrong or something isnt instlaled correctly
theres only a few things that can go wrong.
my friend got sent the wrong clutch part (i think they sent the wrong clutch disk), it fit fine but wouldnt go into gear when the car was running.
Aaron
Pink GodziRa
Old 03-27-2006, 12:09 PM   #10
autohan
autohan is an unknown quantity at this point
was the flywheel resurfaced flat or stepped?
autohan is offline   Reply With Quote
Old 03-27-2006, 01:31 PM   #11
HootAuto
The guy that had it before me said it was a gradual problem...then one day he couldn't shift any more....I'm gonna check it out tomorrow and repost up..
www.hootauto.com
703.509.2242
