Old 04-09-2006, 04:12 PM   #1
nissandr1ft
nissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura aboutnissandr1ft has a spectacular aura about
Send a message via AIM to nissandr1ft
KA24DE power problem
To start off I've had 240's since about 98, and I know how my last ones have run. I've had this current 92 coupe since about December, and its been a piece of junk. The car was originally titled in Cali, so it has all the Cali emission options. The motor surges and stutters when I'm driving....below 4k it really lacks power, above 4k it starts building power, and 5500 on it runs like it should. Its like it comes in stages that are very noticeable. When your in neutral just revving it the cars stutters then catches and revs. Ive tried replacing nearly everything off a motor that runs well, or get it new. So far I've replaced the plugs, wires, cap, rotor button, fuel filter, and O2 sensor. Ive swapped over a different coil, distributer, coolent temp sensor, MAFS, fuel pump, and the ECU. The EGR is blocked, and the evaporative emissions is gone. The ECU I tried wasnt a Cali model, and they seem to run about the same. I've checked the codes with the cali ECU and it gave me a (14) speed sensor, (32) EGR, and (34) Detonation circuit. The EGR light was on with it connected and seems to run better lugged. The speed sensor is probably due to the digital dah only coming on randomly, because I checked it via the FSM procedure and it's fine. I've been wondering if its the knock sensor because that would make sense that the ECU is pulling timing and itd be runnin like this. I tried jumping the knock sensor plug to see if that helped or leave it unplugged. Anyone have any similer symptoms that theyve fixed? Any ideas on what to check.
Steven
www.carolinanissans.com
nissandr1ft is offline   Reply With Quote
Old 04-09-2006, 06:57 PM   #2
nissandr1ft
I heard from a freind to try regrounding my MAFS. I did that tonight with 10guage wire without any luck.
Old 04-10-2006, 12:35 AM   #3
Nizmo240_22
Nizmo240_22 is an unknown quantity at this point
Check your ignition timing.
Second check your throttle positioning sensor.
Nizmo240_22 is offline   Reply With Quote
Old 04-10-2006, 02:56 AM   #4
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
It could also be a huge vac leak.
Try and hook up a new maf while your poking around.
Maeda is offline   Reply With Quote
Old 04-10-2006, 06:19 AM   #5
nissandr1ft
alright, checked the timing and threw a third mafs on. Ill spray some intake cleaner around the back and see if its got a leak. Ill also throw a TPS on today.
Old 04-10-2006, 09:58 AM   #6
nissandr1ft
Just threw another fuel rail, and FPR on.....didnt help. But I found a leak in my fuel hose under my filter. Also checked for vacuum leaks, by spraying intake cleaner, but I didnt hear any change in the idle.
Old 04-10-2006, 11:05 AM   #7
nissandr1ft
yup replaced the hoses and it still doesnt want to run right. From what I understand if the TPS wasnt working then itd be an all the time thing. This problem sort of gets bad and better sometimees.
Old 04-10-2006, 01:00 PM   #8
nissandr1ft
Ive noticed that the power comes back a little on warm sunny days, and really lacks at night and cooler weather. My Digital dash doesnt work till the circuits in that warm up, but it comes on also on warm days. Itll run good even if the cluster hasnt come on yet though. I hear theres a certain board that has cold sauter joints in it that just need to be resautered for it to work right....anyone know which ones on that?
Old 04-10-2006, 01:02 PM   #9
Maeda
Maeda's Avatar
If you figure out the cold solder problem let me know.
How was the timing?
Old 04-10-2006, 07:01 PM   #10
krustindumm
krustindumm's Avatar
krustindumm is an unknown quantity at this point
Make sure your EGR isn't stuck, or remove the entire system.
Then go through the FSM check procedures on all major input sensors (MAFs, ECT, IAT, etc). Make sure you do checks from the ECM plug too, there's always a chance there is a bad wire sometimes.
ASE Master Technician
krustindumm is offline   Reply With Quote
Old 04-10-2006, 08:00 PM   #11
nissandr1ft
The EGR vacuum line is plugged, and the exhaust mani is plugged. I havent had a chance to check the timing....no timing light. Theres a big Nissan BBQ here on Saturday so Ill prob see if one of my freinds will bring theres. Im thinking since its throwing a knock code I may have the timing a tooth advanced and its only letting the timing back up top. So Ill try to retard it a tooth tommorrow and see how that goes.
Old 04-12-2006, 06:27 AM   #12
nissandr1ft
I put another igniter on last night, and a third coil. Also pulled the distributer and moved it back a tooth and forward. it's definatly the correct tooth, and set it back a tad advanced. The cars main problem now is that when you first try to drive it the car stutters and wants to stall for a few seconds then catches and goes.
Old 04-12-2006, 10:30 AM   #13
Nizmo240_22
What octane are you putting in it? If the ECU senses a knock it's going to do that.
Old 04-12-2006, 10:43 AM   #14
altitude
altitude's Avatar
altitude is an unknown quantity at this point
Are you using NGK spark plugs?
altitude is offline   Reply With Quote
Old 04-12-2006, 11:25 AM   #15
nissandr1ft
NGK platinum plugs put in 2 days ago, and those were regular NGK plugs that were in for about a month. I only run 93 octane in the car.
Old 04-12-2006, 07:21 PM   #16
jdm_s14_zenki
jdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of lightjdm_s14_zenki is a glorious beacon of light
Send a message via AIM to jdm_s14_zenki
im having a similar p roblem in my SR, bump!
jdm_s14_zenki is offline   Reply With Quote
Old 04-14-2006, 12:28 PM   #17
nissandr1ft
Anyone else have any ideas?
Old 04-14-2006, 10:00 PM   #18
bluuuurr
bluuuurr's Avatar
bluuuurr is an unknown quantity at this point
IACV? take it apart and clean it..
10 minute job that fixed 2 weeks worth of headaches for me
bluuuurr is offline   Reply With Quote
Old 04-15-2006, 02:40 PM   #19
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
I haven't delt with code 34 so I really couldn't tell you.
I have delt with code 32 and code 14. What I can put together from all this is that you are burning SUPER RICH. Code 32 dealing with the EGR/BPT will throw the ecu into safe mode, the On Board Diagnostic automatically switches the fuel curve to run rich. This is so that what ever problem is occuring with the code wont allow for any early detonation. This happens pretty much when any of the smog emissions aren't functioning correctly.
Code 14 for the speed sensor will also make the KA run richer in higher RPM's so chances are the fuel richness is probably very excessive from 2000RPM till about 5800RPM. Speed sensor does a few things. It regulates fuel in 4th and 5th gear for fuel economy, it also works as the speed governor. I know this as fact since the JWT stage 1 tune is just removal of speed governor and literally a 5HP gain at the wheels( I have a copy of this tune and it sucks). More than likely the wire/sensor underneth the transmission is just disconnected. If not look around the ecu for a snipped wire.
As for code 34 I looked up the diagnostic proceedure in the FSM, it says nothing about a faulty detonation circuit, and there is nothing like that stated as part of the Nissan ECCS discription. Code 34 reads that it is simply a leaky injector.
That is a good explination as to why you have a sever loss in power, the fuel richness is literally choking your engine.
BigVinnie is offline   Reply With Quote
Old 04-15-2006, 04:25 PM   #20
nissandr1ft
Well the car was originally an auto, and now its a 5sp....all the stuff is hooked up. The speed sensor reads when the cluster comes on just fine, and the code wont come on if the cluster is working. The code 34 has come on with both of the fuel rails Ive tried on the car. The EGR code has been going off since ive owned the car, and I deleted all of the EGR equipment. Is there a way to jump the EGR sensor to read that its working correctly, ior am I just screwed on that?
Old 04-15-2006, 05:39 PM   #21
BigVinnie
BigVinnie's Avatar
The only way to not get a code 32 to prevent fuel richness is to get a non cali model ecu. Only about 1/3 of the nissan production 240sx's were non cali. I wouldn't be able to find the ecu numbers either. Well I could, but that is like 2 hours of my time. But I will send you in the right direction. www.hybridka.com/eccs
Old 04-16-2006, 11:16 PM   #22
nissandr1ft
I have a non Cali ECU also, and it didnt seem to change anything. I've made sure the EGR wasnt leaking, and I sort of remote mounted a knock sensor. I had another plug and knock sensor so I plugged it up and taped it to the intake. Doesnt seem to run any better... would the lack of any knock make the ECU think its malfunctiong or is the intake causing a knock like sound. The main problem Ive noticed lately is that my car when first started and I back up. When I put it into first the car seems to want to stall and buck then start going. The power thing is stil happening, but the bucking and stalling problem seems to be the main concern now.
Old 04-20-2006, 09:08 PM   #23
nissandr1ft
Alright new problems have shown up.....now the car idles HORRIBLY. Really bad popping and stumbling at idle. Also noticed with the idle screw closed it still idles right about 600 at times and 1100 at other times.
Old 04-20-2006, 09:46 PM   #24
BigVinnie
BigVinnie's Avatar
Clean your IACV.
Old 04-24-2006, 01:35 PM   #25
nissandr1ft
Well I cleaned the IACV, and it seemed to have fixed the fluxuating idle.....but the idle stioll has a constant popping. Ill try to get a sound clip and put it up soon. The car still has a serious stutter when revving until until the motor is directly in the middle of the temp guage.
Old 05-21-2006, 04:59 PM   #26
nissandr1ft
Update:
I put in a manual TPS, New NGK plugs (gapped .040), new fuel pump sock, checked fuel tank for rust, and new positive battery cable. Ive realised that if I rev it a bit from about 2k-4.5k for about 30seconds the stutter is gone....sometimes longer. If the car is warmed up completely ideling the problem is still there, until the motor is revved a few times. Before its revved the idle is horrible, low, and popping. After it idles pretty good, about where its supposed to be.
Old 05-21-2006, 05:54 PM   #27
wiggerman
wiggerman is an unknown quantity at this point
You really should sit down and read up about problems before ya start swapping tons and tons of parts out
wiggerman is offline   Reply With Quote
Old 05-22-2006, 06:28 PM   #28
nissandr1ft
Its not a big probl;em swapping parts out, I have 2 parts cars sittin around with known good parts. I know 2 Nissan Techs that I know take a look at it, and plenty of enthusiast look at it. Everything that we can think of thatd be causing a problem has been swapped, or tested. My other motor is about ready to drop in.... so if nothing else Ill throw that in and see if its just something internal. My timing chain is making tons of noise at the moment, so regardless it will be going in soon.
Old 06-04-2006, 04:19 PM   #29
nissandr1ft
Update:
I had my alternator checked and it was only reading 11 volts with my electric fan on at idle, so I threw a nissan quet 110 amp alternator in. Also had a grounding kit laying around, so I doubled up on all the factory grounds. It seems to idle fine now, but whenever I start driving it....it seems to almost cut off. When it does it I keep steady throttle, and it usually jumps back in after rolling about 20 feet. Its not dying just feels like its getting zero spark. The only thing I can think of is that my valve seals are going, because if it idles a while it smokes pretty bad, and its getting oil in the cylinder which is interupting my spark. Anyone have opinions on this. The next step since Ive replaced about everything I can think of, is drop my other motor in, which has all new gaskets, and timing chain. I was just hoping to have this problem solved before that. Heres the link on how to fix the HUD cluster.... http://multi-index.myonlinesite.com/...0sx_speedo.htm , I just got mine in and it works like new.
Old 06-22-2006, 07:57 PM   #30
nissandr1ft
Well my car is runnin pretty rough still....esp at startup. Ive rechecked pretty much everything easy so my only guess left is vacuum leak. Does anyone have a good diagram other than the FSM for vacuum lines on the back of the motor. I took the EGR stuff off, but Im thinkin I may have plugged the swirl control valve also. I also wondered about the pinhole in the bottom of the throttle body... I had to plug that on both ends to get the alternator in. There wasnt room for any lines under there with the quest alternator. All I can say is that with my car warm it has a real bad stumble at any RPM till Ive drivin the car quite a bit. When I first start it up, I have to stay in the car and watch the tach, otherwise sometimes itll die sometimes. Ive tried to adjust the idle air, and it doesnt seem to do much. With the TPS unplugged the car idles about 1200ish and 800ish with it plugged once the cars warm and runnin decent. When I pull out of the neighborhood in the mornings completely stops pulling like my key is off, then rolls about 10ft in gear and starts pulling again. I was thinkin bad MAFS on that, but Ive tried 3 in the last week, and moved my ground. Im gonna have to take it on a 5hr drive to TN next week, so Im hoping to get this resolved before then.
