Old 04-10-2006, 11:57 AM   #1
Spec7
Spec7's Avatar
Spec7 is an unknown quantity at this point
SR Clicking under sustained boost
OK- Specs 1st:
Stock SR20det w/SMIC & HKS Super Suction kit.
Stock everything else
Issue:
Turbo spools up cleanly and boosts, but if you stay on the throttle for more than 2 or 3 seconds, there is a rapid clicking noise that sounds sort of like a card in bicycle spokes.
What do I need to be searching for in the threads that would help me out most? "Sounds" doesn't get ya too far and BOV, wastegate, or detonation gets lots of useless threads.
Thanks in advance
Not enough hours in the day to be nice all the time.
Spec7 is offline   Reply With Quote
Old 04-10-2006, 12:26 PM   #2
gotparts?
gotparts? is an unknown quantity at this point
sounds like the boost soleniod to me.
gotparts? is offline   Reply With Quote
Old 04-10-2006, 01:12 PM   #3
spawnofsatan
spawnofsatan's Avatar
spawnofsatan is an unknown quantity at this point
CA Ping
Sound like your car is pinging(Detonating). Play with the timing. Try higher octane petrol, or less boost. (Not good ) Higher octane petrol will solve this if it is pinging. Aviation or racing fuel is best or ad Taulene. Not sure on how much though... if it doesn't solve it try less boost or try water injection. Anyone else?
spawnofsatan is offline   Reply With Quote
Old 04-10-2006, 01:15 PM   #4
Maeda
Maeda's Avatar
Maeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura aboutMaeda has a spectacular aura about
NOS Octane+ works.
It sounds like it could be rod knock.
Maeda is offline   Reply With Quote
Old 04-10-2006, 01:26 PM   #5
supportTHEezln
supportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud ofsupportTHEezln has much to be proud of
Send a message via AIM to supportTHEezln
I second the ping. But then again, I always thought of pinging as having rocks in a coffee can. But that's just me.
supportTHEezln is offline   Reply With Quote
Old 04-10-2006, 01:57 PM   #6
Spec7
Spec7's Avatar
I'm running 92 octane plus an octane booster that should even it out around 100-104 octane. It did this prior to using the octane booster as well. Its running at stock boost, I do not have a boost controller.
As far as rod knock, I believe that would be occuring throughout all rpms as well as at idle. It only makes this noise under the previously mentioned conditions, this is boost specific as best I can tell.
Would a wastgate make any noises if it were going bad?
Old 10-25-2006, 12:28 PM   #7
silverarrow27
silverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud ofsilverarrow27 has much to be proud of
This bothered me, running 92 octane and a bottle of octane booster does not even out at around 100-104 octane. A bottle of octane booster only adds additional points so if you're running 92 octane + octane booster = 92.5 or something like that only.
Now if you went half tank of 92 and half tank of C16 then you're looking at high 90s octane.
1989 240sx XE|2002 Frontier SC CC LB 4wd|2011 Pathfinder LE V8 4wd
silverarrow27 is offline   Reply With Quote
Old 10-25-2006, 01:33 PM   #8
Spec7
Spec7's Avatar
Interesting. I know very little about about that stuff. Good to know though.
Old 04-10-2006, 02:22 PM   #9
neverlift
neverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymoreneverlift is not welcome here anymore
what is your timing set at
derp derp
neverlift is offline   Reply With Quote
Old 04-10-2006, 02:28 PM   #10
IAM_SO_sLOw
IAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choicesIAM_SO_sLOw has made poor choices
Send a message via AIM to IAM_SO_sLOw
i think the sound your describing is like the sound my car is making... lol my car makes that sound too...i was thinking its a gasket around the exhaust manifold or somewhere along the downpipe
IAM_SO_sLOw is offline   Reply With Quote
Old 04-10-2006, 02:31 PM   #11
Spec7
Spec7's Avatar
Timing is stock, never been touched as far as I know.
Old 04-10-2006, 02:37 PM   #12
neverlift
get the gun out and check it,then we will know more to wether this is ping or not
derp derp
Old 04-10-2006, 02:50 PM   #13
Spec7
Spec7's Avatar
hmm, ok. Never done that before, nor do I own a timing gun. Advance auto is just down the road though.
Old 04-10-2006, 03:08 PM   #14
g6civcx
g6civcx's Avatar
Have you ever rebuilt the turbo gasket? If not then my money is on that. The exhaust leak makes it sound like a ticking noise.
Old 04-10-2006, 03:20 PM   #15
Spec7
Spec7's Avatar
I have done absolutely nothing to it. I am in the process of checking everything out on the car to make sure everything is 100% before I start the power mods.
Old 04-10-2006, 04:27 PM   #16
IAM_SO_sLOw
spec7 this is what i think is... im going to check mine this week...i suggest you check yours too =) i doubt its your timming...because i thought i checked my timing and changed it to 15 and it still made the sound..
Old 04-10-2006, 04:38 PM   #17
Spec7
Spec7's Avatar
Agreed, makes the most sense to me as well.
Old 04-10-2006, 03:23 PM   #18
smithers584
smithers584 is an unknown quantity at this point
ok dude i think gotparts? is right. i think that you are talking about your boost solenoid. do you have a boost controller? i know that the solenoid from my apexi avcr does the same, its the valve fluttering inside. sounds exactly like what you are talking about. called apexi about it, they said some do it and some dont, so i am not worried about it. its just fluttering back and forth trying to maintain proper boost.
smithers584 is offline   Reply With Quote
Old 09-03-2006, 08:12 AM   #19
sepulchral
sepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymoresepulchral is not welcome here anymore
bump having same prob
sepulchral is offline   Reply With Quote
Old 09-03-2006, 09:03 AM   #20
g6civcx
g6civcx's Avatar
Rebuild your turbo gaskets.
Old 09-03-2006, 09:13 AM   #21
drifter808
drifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of lightdrifter808 is a glorious beacon of light
i had same problems and the turbo gasket from the manifold to turbo was missing a bolt and loose and the gasket from the 02 housing to turbo was missing all bolts except for 2. replaced them all and now runs cherry
drifter808 is offline   Reply With Quote
Old 10-22-2006, 04:28 PM   #22
Spec7
Spec7's Avatar
Yup, I took everything off today; exhaust mani to the cat. Blown manifold to turbo gasket, missing nuts on the dump tube and turbo/manifold, exhaust manifold was not torqued evenly so the head to manifold gasket was seized to the head on one end and nearly fell off on cylinder 4.
I hate those oil and coolant lines; much flesh and blood is missing due to them.
I had a small line of oil on the outside of the cool turbine. Should I go ahead and rebuild the turbo while its out?
Old 10-22-2006, 05:38 PM   #23
misfitsfreak81
misfitsfreak81's Avatar
misfitsfreak81 is an unknown quantity at this point
yes rebuild it while its out or good time for upgrade. the rebuild is super easy and you can find a complete kit on ebay for less than 80$.
misfitsfreak81 is offline   Reply With Quote
Old 10-22-2006, 05:57 PM   #24
Spec7
Spec7's Avatar
Here's the mani-turbo gasket :
Here's the Exhaust mani gasket:
Encouraging isn't it??
Old 10-25-2006, 11:36 AM   #25
Spec7
Spec7's Avatar
After all the searching and posting this thread, I run across this one today which is exactly the same issue:
http://www.zilvia.net/f/showthread.p...=turbo+rebuild
Old 10-26-2006, 01:14 AM   #26
silverarrow27
Don't waste your money away on those octane boosters...do you no good. I've ran 89 octane on my old cars before and never had any issues, your problem lies elsewhere so save your money.
