![]() Join Date: Jan 2006
J30 or Q45 pumpkin
Hey i was looking through the threads and see people talking a lot about welded diffs, which looks like a good idea for drifting, which i plan on doin. But there have been a couple of people going with J30 diffs or Q45 or 300zx, whats the advantage of having one of those diffs?
R.I.P. Aya, always love
![]() Join Date: Nov 2001
Trader Rating: (215)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 215 reviews
Q45 differential will not work in our cars, if You had searched you would have found that out without me telling you. You would have also found out you can use the 300zx NA differential.
"Having a lot of tracks on a song is like putting stickers on a car to get more horsepower" New Video https://www.youtube.com/watch?v=uebV1OnbRsw Buy my mounts! http://zilvia.net/f/sale-items/51531...ns-mounts.html http://zilvia.net/f/tech-talk/317539...e-mouts-6.html |
#4 | |
#5 | |
![]() Join Date: Mar 2006
![]() 1997 240sx ------------------------- 1993 300zx TT |
#6 |
![]() Join Date: Mar 2002
Ive got a question on this subject if someone could answer it for me that would be awesome. If i have a z32 na dif and open it up, can i take the gearset off of my open diff and use the lsd in the open diff? The z32 diff I have access to is missing the output flanges. If I can just take out the center and make it work with the open setup that would be awesome. Thanks ahead of time.
#7 | |
And logic says yes. |
#9 |
![]() Join Date: Apr 2005
i have a different question but its related to the J30 diff...
I have an RB25 swapped into my s13 and i'm running a J30 diff. Now i am well aware that the RB is not meant for economy gas mileage but that doesn't mean that I want the engine to be at 3000RPMs in 5th gear and i'm only going 70mph. I put down 280whp and ~250wtq at .85 bar (stock turbo). If I were to swap in a diff with a lower final drive would it completely destroy any low RPM acceleration that I have?? I road race and autox the car and can't afford to lose all of my low end grunt but at the same time I can't be topping out my gearing half way down the straight at VIR or Summit Point either. Thanx in advance - Daniel
does your wife drive a wide-bodied sr-powered coupe??? |
#10 | |
#11 | |
so if i were to run the Z32TT diff i would have a 3.70 final drive correct? Right now I definitely run through the gears rather quickly and when driving on the street when I'm doing 45ish mph i'm in the high 2000RPM range and then shift into 5th....not really ideal for street travel ya know As for the autox, the car definitely hauls and I have yet to encounter an autox course where I'm out of my powerband. I haven't had a chance yet to go on any road courses but hope to be able to track the car in the coming month. I guess what my biggest question is if i were to switch out to a 3.70 or 3.54 final drive where will it shift my powerband? Will i lose tractability on an autox course or will it just haul a little less? - Daniel
#12 |
![]() Join Date: May 2003
^^^ Z32TT diff is NOT an otion for you...it's an R230, too big for your chassis.
A numerically lower diff would slow your acceleration, but increase top speed. You'll have MORE traction at lower RPM. Basically, it's less TQ multiplication...think of riding a bike...try to start in the big gear up front and smallest in back...that's a Q45 diff. Slow to start, but will get you going very fast eventually. Now do the same...but use the middle gear up front and (edit!) biggest in back ("granny gear")...that's the 180SX 4.36:1 diff...supper fast accel, but you're spinning your legs so fast by ~12mph that you can't go faster! See what I mean? - Brian
www.KA24DEvelopment.com |
#13 |
from your weblink Brian it states that the J30 diff has a 3.92 final while the z32na diff has a 4.08 final drive then wouldn't the z32 diff actually give me slightly shorter gearing when compared to the j30???
#14 |
Yes..stock is 4.083:1, J30 is 4% higher gearing (numerically lower).
It's hardly noticeable, but I like to try and stick with the 4.083 or higher...unless you need to do +150mph. - Brian
#15 | |
I had the stock open diff from the S13 with the 4.08, would do about 3500rpm at 80mph. Then I switched to the J30 diff with the 3.92 final drive and now I'm at around 3300rpm doing 80mph. Not that much difference. However, now that I've put 17s with 225/45/17 tires on, at 80mph I'm more closer to like 3100rpm. Will be going with 235/40/17s next, so that should bring the rpms right back up to around 3200-3300rpm @ 80mph. |
#16 |
hmmm.....so i'm pretty much screwed in terms of getting a taller final drive into the car right??
I'm going to be running either 245/45/17s or 255/40/17s in the rear here's another thing though, i'm running an RB25DET and tranny (of course) so my gear ratios are going to vary when compared to an SR20 tranny b/c of differrent ratios in the tranny yes?
#17 | |
I would say shoot for 3.70, or 3.92 aka J30, or research the different Skyline diffs. Which are actually all R200 cases and will bolt in our cars. GTS diffs were VLSD's , R32 GTR and R33 GTR were clutchpack and R34 GTR was helical.
#18 | |
#20 |
i'm not looking for a better locking diff right now...i'm looking for a lower final drive
