actual boost level? avc-r
greetings!
this is my first post and yes,, i am super noob so i will need a lots of help from zilvians!! my currents mods are as following SR20DET (95 blacktop s13) HKS Racing Suction kit HKS front mount intercooler HKS downpipe HKS SSQV blowoff valve HKS Hi-power exhaust HKS DLI ignition HKS turbo timer L/S Automotive test pipe Denso 270lhp fuel pump GReddy intake manifold GRdddy Dump pipe GReddy cold pipe Koyo radiator FAL electric fan Unorthodox crank pulley SunAuto Hyperground wires Nismo engine mounts Nismo tranny mounts Nismo clutch slave cylinder i recently installed the apexi AVC-R, and i monitored the boost reading from the unit with solenoid deactivated to check the boost level. and it read 0.69-0.72 bar.. i am little confused because I thought the stock boost level should be around 0.5 bar?? I tried to search a lit bit, but couldn't find a definite answer but i found something similar in SR20FAQ "if the vac line is hooked up from wg to solenoid to TB, it restricts the airflow and brings up the boost to 11 psi" is this statement true? can i get a confirm by someone w/ avc-r or w/ solenoid? oh.. and 14 psi safe? i was going to set it at 12 psi.. but since i found out that i am running at 11 psi already.. I want to raise up a lil bit higher.. appreciate any comments thx!! |
well 14 psi on the stock turbo is a waste, it will be out of the efficiency range of the turbo and will just turn into a heat pump. no higher than 13. and when i turn my AVCR off, i hit about 10 psi consistently, not sure why, but i know thats the case. hope that hepls a little
