Old 04-16-2006, 08:18 PM   #1
sidewayz180
sidewayz180 is an unknown quantity at this point
ka24de wire harness
k guys i just bought a cut wire harness for my 93 ka24de motor the part where it was cut was the maf sensor plug and this one other plug right next to it and i am trying to figure out where that goes. and the wires to that connector is brown with a grey dot about every other inch and a black wire with a grey dot every other inch so if you guys know where that goes please heklp thanks
sidewayz180 is offline   Reply With Quote
Old 04-17-2006, 09:27 AM   #2
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
I just came back from checking my harness. The two wires(black with grey dot, brown with grey dot) goes to the power stering line.
NIK90s13 is offline   Reply With Quote
Old 04-17-2006, 04:35 PM   #3
sidewayz180
hey
is that really needed or no???
Old 04-17-2006, 04:41 PM   #4
mRclARK1
mRclARK1's Avatar
mRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfectionmRclARK1 is close to perfection
It is if you have power steering.
mRclARK1 is offline   Reply With Quote
Old 04-17-2006, 04:45 PM   #5
NIK90s13
NIK90s13's Avatar
I do'nt know, Whem I did my swap I was told to get the dohc lines, for the ps pump, the lines came with my harness, Does your car run without it?
Old 04-18-2006, 07:32 AM   #6
sidewayz180
hey
well im in the process of swaping my motor im just trying to figure out all my wirings before i take my other motor out.. and the power steering pump i havent moved it to the right yet and someone told me that you can move the powersteering pump lines over with out using the dohc power steering lines is that true?
Old 04-18-2006, 07:36 AM   #7
sidewayz180
oh
oh yeah if i dont run power steering and i have my power steering pump connected onto the belt, would that over heat?
Old 04-18-2006, 09:23 AM   #8
NIK90s13
NIK90s13's Avatar
I heard you can just switch the lines, I went ahead and got the lines from the rack, the whole ''nine''. Don't run the powerstering without fluid. I would get the connector from a junk yard.
Old 04-18-2006, 09:39 AM   #9
Johny5
Johny5's Avatar
dude if you're talkinga bout the line running RIGHT beside the maf then thats ambient air temp sensor. the wire for the power steering comes off the harness that runs over the driver side wheel well, it comes in through the hole in your chassis next to the master clutch cylinder, wraps around the strut tower and runs down to the hardline (where the pressure sensor is) and no it is NOT needed to run ps, it is only a pressure check. it will not make the system add or subtract pressure, its only to warn the driver of possible "low pressure".
www.stewartleask.com
Johny5 is offline   Reply With Quote
Old 04-19-2006, 07:12 PM   #10
sidewayz180
harness
i have another gay ass fucking problem with my harness the part where it also got cut was the headlight hanress that splits up with the main engine harness towards the headlights, that part was cut off so i bought a new one for it then i was told just to connect the wires together and all of the wires should match up and they all did, but the part that got me was there are two black wires with red stripes on them on the new one i bought and it goes from one wire then splits into two does it matter which specific one that i have to connect it with my old one or are both wires the same since it comes out of the same wire? and also there are three red wires that does the same thing and three black wires and i dont know if you have to put them into a certain wire or can they just connect to either one?
