Old 05-26-2006, 03:03 PM   #1
tdawg88
tdawg88 can only hope to improve
5 speed swap probs
Ok got the tranny in. Cant start the car. Tried looking for the relay spoken or referenced to in the swap thread. I have no relay box next to my batt that regards a "start while in park" relay. I do however on the opposite side have a relay box that has a N&P Clutch relay. Is that the one to tap? Either way, how is the tap done exactly? there are 4 holes to the wires so which ones do I tap into? Also about grounding it? do I connect a 3rd wire onto it and then to the body of the car? Help me out ASAP thanx
tdawg88 is offline   Reply With Quote
Old 05-26-2006, 06:11 PM   #2
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
i am assumeing that you have a 240sx correct? the next question is is it s S13 or an S14 the year would help. if it is a S14 i can tell you rigth off. Drift Freaq had a FAQ written up here on S13 here:
http://www.zilvia.net/f/showthread.php?t=21181
Tenchuu is offline   Reply With Quote
Old 05-26-2006, 07:28 PM   #3
tdawg88
no its an s13, and apologies to the mod who got mad at me for posting in 2 sections. Im working on the car so an immidiate response is more what I was going for. Irregardless of which, I can get the car to crank at all. I connected all the wiring and sensors that were once on the car and the car wont even crank now. Any ideas what could be the problem or issue? The Driftfreak guide does me no good because its for an s14 and I still dont see which is the harness or wire I need to tap.
Old 05-27-2006, 09:15 AM   #4
tdawg88
Anybody here got any insight? If so please hit me up. Thanx a bunch
Old 05-27-2006, 09:36 AM   #5
jim1234664
jim1234664's Avatar
jim1234664 is an unknown quantity at this point
its not a fuse or relay inside of the box next to the battery, its two wires that run under the box. the wires both go into the same plug and i believe that one is white with black stripe, simply cut the plug off and connect the two wire together
jim1234664 is offline   Reply With Quote
Old 05-28-2006, 01:06 AM   #6
tdawg88
OK I did that, and figure once jumped, car should start or atleast crank? but nothing. My question now is, which is the neutral or parking sensor so the car will crank? I cant find it. This really sucks
Old 05-28-2006, 03:17 AM   #7
SiI40sx
SiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfectionSiI40sx is close to perfection
Send a message via AIM to SiI40sx
have u tried clutch popping your car?? put clutch in roll the car up to like 5-10mph then quickly let go of the clutch while turning the key and giving it gas. Basically instead of the starting turning the crank, the tranmission (being turned by the roll of the car) moves the crank
SiI40sx is offline   Reply With Quote
Old 05-28-2006, 04:46 AM   #8
jdm538
jdm538's Avatar
Trader Rating: (30)
jdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfectionjdm538 is close to perfection
Feedback Score: 30 reviews
there should be a female plug beside the box that is 2 prong, loop it.
jdm538 is offline   Reply With Quote
Old 05-28-2006, 09:52 AM   #9
tdawg88
Ok did that, but no crank! I turn the key n no response. Also sorta did the pop clutch thing except instead of rolling it, I hotwired the starter. That didnt cut it either. Car will start if I hotwire it, but Im trying to do it as the write up entails. Anyone in the San Francisco Bay area got one of this Convertible or Auto to manual swaps who can show me their wiring?
